Тест Для Fifo
metallbublick
Добрый день, уважаемые эксперты. Прежде чем использовать FIFO в проекте, решил написать для него простенький тест.
Итак, при помощи IP Core Generator получил FIFO следующего вида:
Код для тестирования:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
library UNISIM;
use UNISIM.VComponents.all;
entity fifo_testbench is
end fifo_testbench;
architecture Behavioral of fifo_testbench is
component fifo_16x4
 port(
	 rst: IN STD_LOGIC;
	 wr_clk: IN STD_LOGIC;
	 din: IN STD_LOGIC_VECTOR(7 DOWNTO 0);
	 wr_en: IN STD_LOGIC;
	 full: OUT STD_LOGIC;
	 rd_en: IN STD_LOGIC;
	 dout: OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
	 empty: OUT STD_LOGIC;
	 rd_clk: IN STD_LOGIC
end component;
signal rst: STD_LOGIC;
signal wr_clk: STD_LOGIC;
signal din: STD_LOGIC_VECTOR(7 DOWNTO 0);
signal wr_en: STD_LOGIC;
signal full: STD_LOGIC;
signal rd_en: STD_LOGIC;
signal dout: STD_LOGIC_VECTOR(7 DOWNTO 0);
signal empty: STD_LOGIC;
signal rd_clk: STD_LOGIC;
signal clk: STD_LOGIC;
begin
FIFO_INIT: fifo_16x4 port map(
rst => rst,
wr_clk => wr_clk,
din => din,
wr_en => wr_en,
full => full,
rd_en => rd_en,
dout => dout,
empty => empty,
rd_clk => rd_clk);
FIFO_TEST: process
begin
 -- сброс FIFO
 rst <= '0'; wait for 1 ns; rst <= '1'; wait for 1 ns;
 -- заполняем FIFO
 rst <= '0'; rd_clk <= '0'; rd_en <= '0'; wr_en <= '1';
 wr_clk <= '0'; wait for 1 ns;
 wr_clk <= '1'; din <= "10010001"; wait for 10 ns;
 wr_clk <= '1'; din <= "10110010"; wait for 10 ns;
 wr_clk <= '1'; din <= "00010011"; wait for 10 ns;
 wr_clk <= '1'; din <= "10010100"; wait for 10 ns;
 wr_clk <= '1'; din <= "11110101"; wait for 10 ns;
 wr_clk <= '1'; din <= "10010110"; wait for 10 ns;
 -- читаем из FIFO
 rd_en <= '1';
 rd_clk <= '1'; wait for 10 ns;
 rd_clk <= '0'; wait for 1 ns;
end process;
end Behavioral;
Симуляция на ISim дала следующие результаты:
То есть судя по полученным данным после сброса FIFO полное (full = '1'), затем, по переднему фронту третьего импульса записи (wr_clk) full сбрасывается в ноль. При этом флаг empty постоянно установлен в '1', даже когда full также равен единице. Догадываюсь, что должно быть совсем не так :-)
Я новичок в программировании ПЛИС. Подскажите, пожалуйста, в чем может быть ошибка?
1) Если RST в "1", то происходит сброс (???), поэтому поставил в "ноль".
2) Интервалы наносекундные - там на шкале 0, потом 10 000, 20 000 и т.д. (мало ???).
С интервалами понятно, хотя и странно, ведь запятая - десятичный разделитель. Сброс по умолчанию работает по активному нулю, как и все D-триггеры, которые являются основой любого буфера. Вы не смотрели что RTL синтезировал? Как я понял, буфер построен с помощью визарда.
