Sony Ericsson W810i
Help!!! :( что может быть при включ Sony Ericsson W810i мигает экран белым цветом и все подключал к компу через usb тоже-самое
можно-ли что зделать в дом условиях.
4asto eto problema w Software. Otnesi w service ili proschei sam. :ph34r:
wot sto ja naril u druga ( eto otwet ot SonyEricsson):
This document is applicable for W810...
but there is also the possibility that products of W300, W710, K310 & K510 can be returned with that problem.
Introduction
Units equipped with ST memory chip set may be returned due to On/Off and flickering white LCD.
Most affected product is W810 as it has dynamic/floating memory area for FS and CXC.
Problem show itself when unit is powered on and off repeatedly. The unit can go into a non-recoverable state
where the LCD flickers white on and off.
For all other products mentioned, the problem is much more difficult to provoke.
Claiming instruction
When claiming in WCMS, please always use the symptom code 'Can't power on' and put the letters (capital) 'WS'
for White Screen in the beginning of the remark field.
This is extremely important in order to get the data about the return volumes due to this fault!
Comments
It is important that everyone is following these instructions carefully!
Recovery
A patch to fix that problem is currently under development (planned for w44/45) and you will be informed
officially when it's been released!
Until then, please don't escalate such units but keep them aside until the patch is available!
:lol:
Изменено пользователем P@te
Да, по всей видимости это софт слетел!
Sony Ericsson к этим вещам , как ни кто склонен!
Может и брак заводской, может и флэш с микро трещиной менять возможно надо, блютуз контролер реболить!
Одним словом, несите в сервис, там поправят!
Как я понимаю БОКСА нет!?!
О,брат!Это прошивка.Болезнь ериков,и мой постоянный хлеб.Аккумулятор на горячую не вытаскивал?А вообще его недо прошить.Бесплатно это не получиться.Или спец центр,или Давинчитим.Думай!
Павлик чушь ты не много напиал ! Ну на счет того что ето прошивка на 99,9% угадал (а может и чтонить другое). На счет акумулятора на горчуюю руку ето чушь полная, это не DB2020 (давинчитайм или кибершот) а DB2010 (walkman) его фришным софтом можно прошить но не желательно потомушто фришный софт делает очень криво финализацию файловой системы аппарата а также не корректо проливают EEPROM что ведёт к критичной работоспособности аппарата, но при маргунчике EEPROM лить обязательно восновном в нём неполядки и происходят !
Угадал говоришь!А можно поподробнее про фришный софт на эту модель,чем можно его так запросто финализировать!!!!!
А?И если даже есть такой софт,то нах им вообще аппарат трогать если он после этого криво работает? :angry:Чушь в данном случае поришь ты!
Изменено пользователем Павлик
Ну, ссорится из-за Эрика не стоит!
Ни кто, его в руках не держал и однозначно сказать, что с ним не может!
Всё это, такие мелочи!.......
Снесёт в сервис и там решат! И поправят! :)
Изменено пользователем sergej7777
Угадал угадал ! На скока помню semctool хотя я етой гадастью не шью !!! Логику ПИОНЭРА есчо нихто не разгодал ! :)
А так не нада злиться !! Нервы ну купишь ! МИР ?
Изменено пользователем swmobile
у иоей жены на w800i такая же тема была,причем дважды...в первый раз в сервисном центре нам поменяли ПО а во второй сделали общий сброс настроек! я так понимаю что нужны инженерные коды(для форматирования телефона в выключенном состоянии)-я таких искал рно до сих пор ничего не нашел..так что не пугайся я сейчас хожу с этой трубой все работает! А вообще мне Sony ericsson не очень нравиться...
Да ерики последние,начиная с к750,это вобще беда.Сдернул аккумулятор на горячую.Получай труп!Аккумулятор разрядился,тоже труп.Прикольно,с магазинов тащат еще не побывавшие в продаже телефоны.Они идут с еле заряженными аккумуляторами,их пробуют включать и все,пипец труп!А вот К790 это вообще венец брака.Никому не советую покупать.Пару своих друзей отгаваривал,всеравно купили.Одному уже восстанавливали.Насмотрятся блин Джеймса Бонда.Я когда увидал что у него К790 смеялся долго.Но радует только то что работой надолго обеспечили.Это как когдато валом шли Siemens C60 и т.д. моргающие.Вот денег налохматили.
2electron84
А вот кодов там никаких нет.Скорее всего его и второй раз прошивали.
2swmobile
а вот ломаный семктул эту модель не тянет.Я тоже когда то начинал с таких прог.Но быстро понял что лучше платное решение.
Платный совт рулит !!
Блин с магазина припёрли 50 сониерисонов маргунчиков k750, w800, w810,w550 красота иногда я начинаю любить сониерисонов (в хорошем смысле етого слова) !!
Все кто платно шьют, это люди ленивые зашли бы http://tuner.moy.su/ посмотрели научились, заодно бы и сами прошили!!!!!! Леньтаи!!!!!
Ссылка удалена модератором Влад
Какой еще платный софт? Вы чо народ?
Гоните на сайт Topsony.com и качаете оттуда прошивку последнюю для тела - main и fs. Потом в YANDEX - туда вводите Phone XS 2.1 Beta - качаете это все дело - потом заряжаете аккум в течении 2 часов - вставляете в тело - берете стандартный data кабель DCU-60 который идет в комплекте, пускаете прогу - выбираете порт usb - шмаляете кнопарь С на мобилке и подсоединяете тело не отпуская кнопку - пока на табло проги не побегут буквы, потом отпускаете! =)
Дальше в строку Main - ставим например W550_EMEA1_R4CB020_Main.bin а в FS - W550_EMEA1_R4CB020_FS.bin. Дальше выбираем кустопак для тела - финализацию тоесть! Для русского тела ставим EMEA1 (CDA) - там все просто разберетесь! И шьете тело! Сама прошивка льёца минут 5, потом процесс финализации еще пару..............а то и 5 часиков - и все! Я так свое тело поднял не затратив ни копья - чего и Вам советую! Удачи! SE Walkman - Рулез Полный!
Просто люди привикли жить правильно, нахрен платно, если можно бесплатно!!!!! :D
скупой и разумный вещи разные! я восстанавливал W550i CID 49
а кстати зачем платить за то, что можно сделать бесплатно!
я и давинчем нахаляву пользуюсь!
подтверждаю. умер телефон без причины. бегать по сервис-центрам терять время не хотелось. да и давинчи не очень понятно за что деньги берет.
прошвка у сонериков на сайте есть (нужно зарегится), а дальше MAIN и FS (у сонериков на сайте) части плюс кустомайзинг (xml файл и всякое разное - в форумах поройтесь ) плюс апдейт для прописывания сертификата халмера плюс сертификат плюс нормальный драйвер (тоже ссылки на форумах) плюс Phone XS или XC или XS++ плюс куча терпения и золотой ключик у вас в кармане.
я пользовал XC6, говорят XS++ k750 на раз без взлома финализирует.
а еще видел патч для прошивки, которая не требует финализации, так как вся кустомизация прописывается на MemoryStick.
а хитрецы на дураках всегда будут зарабатывать...
