yura717
Mpc55Xx Конвертация Hex В Bin
3 posts in this topic
yura717    0
Добрый день !
Есть файл как я думаю в Intel HEX формате ... как его перевести в BIN format?
D322
<compatibility_header><calibration_version>8.0.0.82</calibration_version><module_name>CM87x</module_name><first_prod_cfg_file_version>2003.1.1.0</first_prod_cfg_file_version><product_id>BAC</product_id><module_part_number>3954430</module_part_number><interface_level>4.5.4.2</interface_level><creation_date>2011-01-19</creation_date><start_boot_loader_version>4.8.4.3</start_boot_loader_version><end_boot_loader_version>4.8.9.9</end_boot_loader_version><byte_order>BigEndian</byte_order><index_table_address>00010068</index_table_address><file_descriptor>Core-II Software Copyright 2010 Cummins Inc. - Cummins Confidential - HDCPS-X07-C18.00.00.08-ISX-8.0.0.82_00</file_descriptor><harness_key_mask>0000</harness_key_mask><harness_key_compatibility_list>0000000000000000</harness_key_compatibility_list>
</compatibility_header>
:020000040001F9
:2000000000000001000A7F2C00000000000000074DFC000A7F3E0000000000000000000013
:200020000000000000000000000000000000000000000000000000000000000000000000C0
:2000400000000000000000000000000000000000000000000000000000000006C3A8000629
:20006000C4C40006C4DC000000000B23000000010000000100000003000000010000000A14
:20008000000000010000001200000001000000160000000200000019000000010000001DFD
:2000A0000000000600000028000000060000002F000000020000003800000004000000415E
:2000C0000000000100000043000000020000004600000002000000490000000100000082C6
:2000E00000000003000010000000000100001016000000010000102D000000020000103442
:200100000000000100001036000000010000103B00000001000010420000000100001046A2
:20012000000000010000104900000001000010550000000100001058000000010000105F26
:2001400000000001000010680000000200001077000000050000107D00000005000010896D
С чего начать?
Спасибо.
окончание файла
:00000001FF
Хотелось бы понять формат ....
Edited by yura717
yura717    0
с какой строки начать конвертацию с первой или со второй?
данные занимают 32 байта /10 системе / и 13 - это CRC
а вот что такое первая строка ?
:020000040001F9
с концом файла... ясно
:00000001FF
Edited by yura717
DC/DC-преобразователи MORNSUN R3. Повышенная надёжность - сниженная стоимость!
Особенностью преобразователей R3 являются улучшенные технические характеристики, повышенная надёжность и сниженная стоимость. Электрическая прочность изоляции представленных преобразователей не менее 1500 В, а температурный диапазон применения -40…105ºС.
Create an account
Register a new account
Sign in
Sign In Now
    • Если чуточку погуглить, можно найти схему на датчик движения, из которой становится понятно, что фоторезистор просто шунтирует 9 ногу микросхемы датчика на общий провод и встроенный компаратор запрещает её работу. (Темновое сопротивление ФР несколько МОм, освещённое - несколько кОм.) Следовательно, можно завести в ДД вместо фоторезистора выход датчика освещённости, если он имеет соответствующие уровни или типа "открытый коллектор" либо применить дополнительный ключ на транзисторе.
      Как вариант - запаять таки фоторезистор и отрегулировать чувствительность резистором R8. Или не лезть в датчик, а управлять исполнительным устройством - ведь на выходе всё равно будет какой-то ключ с реле или что-то подобное.
    • прорисовал печатку ,устранил ошибки ,добавил еще по 1 тыс.мкф конденсатор ,гляньте - может что еще поправить ? увеличил зазор под землю - хочу попробовать стыки сделать припоем.
    • Растворить канифоль в спирте и наносить на место пайки кисточкой. Канифоли будет меньше, дыма тоже, пайка чище.
    • БП не уходит в защиту, а тупо вырубается, т.к. дежурка не держит нагрузку (какую, кстати?), а от неё запитан основной контроллер ШИМ и некоторые вспомогательные цепи. В дежурке всего пять конденсаторов, можно поменять, не дожидаясь ESR метра, т.к дежурка работает круглосуточно и деградация в ней максимальна.
    • Тема про чудеса советской радиопромышленности http://rt21.getbb.ru/viewtopic.php?f=36&t=159401
    • Чтобы кошки ловили кого-то кто с них размером? Тогда уж ежика. Помню в детстве сосед бабушки принес ежа из леса. тот всю живность в округе давил начиная от насекомых и заканчивая крысами. Насчет кротов не знаю как-то в Сибири они редкость. У нас шахтеры их заменяют
    • rommon Я предполагаю что вы скажите " большая задержка сигнала " но в передачи через wifi используется четыре протокола и один из них отвечает за быстрый обмен информации ( быстрота обмена сопоставима с беспроводными наушниками )  - можно смартфон использовать для дополнительных вспомогательных функций   например; чертить разные графики ( возможно в три Д режиме ) , система навигации  и много другие нераскрытые перспективы .
