Подскажите Чего Не Делаю Правильно
StasRadeon
здравствуйте, вот хотел сделать маленький blinking led в ассемблере с нажатием кнопкой. подскажите чего не делаю правильно ?
#include p16f887.inc
ORG	 0x000
goto main
cblock 0x20
d1
endc
main
bsf STATUS, RP0	 ;//bank 1
movlw b'00010000'	 ;
movwf TRISB	 ;
bcf STATUS, RP0		 ;//bank 0
knop
btfss PORTB,4
call Loop;
goto knop;
Loop
clrf PORTB
bsf PORTB,0
call delay
bcf PORTB,0
call delay
goto Loop
delay
movlw 0x85 ; //400us
movwf d1
delay_0
decfsz d1,f
goto delay_0
return
End
Изменено пользователем StasRadeon
шапки программ в мплабе для кого на каждый камень лежат?
;   This file is a basic code template for assembly code generation   *
;   on the PIC16F887. This file contains the basic code			   *
;   building blocks to build upon.								    *
;   Refer to the MPASM User's Guide for additional information on	 *
;   features of the assembler (Document DS33014).					 *
;   Refer to the respective PIC data sheet for additional			 *
;   information on the instruction set.							   *
;    Filename:        xxx.asm										   *
;    Date:														    *
;    File Version:												    *
;    Author:														  *
;    Company:														 *
;    Files Required: P16F887.INC									  *
;    Notes:														   *
   list        p=16f887    ; list directive to define processor
   #include    <p16f887.inc>    ; processor specific variable definitions
; '__CONFIG' directive is used to embed configuration data within .asm file.
; The labels following the directive are located in the respective .inc file.
; See respective data sheet for additional information on configuration word.
   __CONFIG    _CONFIG1, _LVP_OFF & _FCMEN_ON & _IESO_OFF & _BOR_OFF & _CPD_OFF & _CP_OFF & _MCLRE_ON & _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUT
   __CONFIG    _CONFIG2, _WRT_OFF & _BOR21V
;***** VARIABLE DEFINITIONS
w_temp        EQU    0x7D        ; variable used for context saving
status_temp    EQU    0x7E        ; variable used for context saving
pclath_temp    EQU    0x7F        ; variable used for context saving
   ORG	 0x000			 ; processor reset vector
   nop
     goto    main			  ; go to beginning of program
   ORG	 0x004			 ; interrupt vector location
   movwf   w_temp		    ; save off current W register contents
   movf    STATUS,w		  ; move status register into W register
   movwf    status_temp	   ; save off contents of STATUS register
   movf    PCLATH,w      ; move pclath register into w register
   movwf    pclath_temp      ; save off contents of PCLATH register
; isr code can go here or be located as a call subroutine elsewhere
   movf    pclath_temp,w      ; retrieve copy of PCLATH register
   movwf    PCLATH          ; restore pre-isr PCLATH register contents
   movf    status_temp,w	 ; retrieve copy of STATUS register
   movwf    STATUS		    ; restore pre-isr STATUS register contents
   swapf   w_temp,f
   swapf   w_temp,w		  ; restore pre-isr W register contents
   retfie				    ; return from interrupt
main
; remaining code goes here
; example of preloading EEPROM locations
   ORG    0x2100
   DE    5, 4, 3, 2, 1
   END					   ; directive 'end of program'
где возврат из процедуры Loop?
хоть убей не понимаю
возврат понимаю когда я убираю руку лед долженъ погасица и назад в кноп й ждать пока я нажиму ешё раз
delay
movlw d'100' ;
movwf d1
поставил так , чтобы не мочится
на вопрос , когда я нажимаю он тогда должен заработать ,а он сразу зарабатываетса и не реагиривает на кнопку.
исправленный код покажи
ORG	 0x000
goto main
cblock 0x20
d1
endc
main
movlw b'00010000'	 ;
movwf TRISB^0x80	 ;
knop
btfss PORTB,4
call Loop;
goto knop;
Loop
clrf PORTB
bsf PORTB,0
call delay
bcf PORTB,0
call delay
goto knop
delay
movlw D'100' ;
movwf d1
delay_0
decfsz d1,f
goto delay_0
return
Nop
End
в пост #27 шапка оформления кода для кого выложена?
#include p16f887.inc // где указание компилятору с каким камнем работаем?
					 // где биты конфигурации?
ORG	 0x000
goto main
cblock 0x20 // <- где должен описывается блок переменных?
d1
endc
main
movlw b'00010000'	 ;
movwf TRISB^0x80	 ; <- что это?
knop
btfss PORTB,4
call Loop;
goto knop;
Loop
clrf PORTB
bsf PORTB,0
call delay
bcf PORTB,0
call delay
goto knop // возврат из процедуры return
delay
movlw D'100' ;
movwf d1
delay_0
decfsz d1,f
goto delay_0
return
Nop
End
и инициализации портов АЦП кто выключать будет?
быть я в configuration bit установил
movwf TRISB^0x80 стоба сообщение про банк 0 не появлялось
d1
endc
ORG	 0x000
goto main
movlw b'00010000'        ;
clrf ANSEL
вот так правильно
:wall: ну конечно мы тут ясновидящие... Стас сделайте в конце концов шапку как положено...
это сообщение - напоминание что TRISB находится в банке 1 на скорость полета не влияет, не нравятся напоминания
после инклюда ставим:
errorlevel  -302			  ; suppress message 302 from list file
знал про
errorlevel -302
но не задумался поставити
подумал ^0x80
_CONFIG _CP_OFF & _WDT_OFF & _PWRTE_ON & _WRT_OFF & _LVP_ON & _CPD_OFF
