77 сообщений в этой теме
MOHAX    9
Да я знаю вот выставляю так вот ошибка
Connecting to MPLAB PICkit 3...
Currently loaded firmware on PICkit 3
Firmware Suite Version.....01.48.18
Firmware type..............Midrange
PICkit 3 is trying to supply 4,500000 volts from the USB port, but the target VDD is measured to be 4,250000 volts. This could be due to the USB port power capabilities or the target circuitry affecting the measured VDD.
The target circuit may require more power than the debug tool can provide. An external power supply might be necessary.
Connection Failed.
2017-05-22 22:49:02 +0300 - Read failed
Быстрый заказ печатных плат
  • x
    мм
Zhuk72    12
Внутрисхемное подключение? Что-то подсаживает питание в схеме.
