Sign in to follow this
Кинг
Stm32F103 Ацп Измерение С 2Х Каналов
9 posts in this topic
Кинг    0
Пишу программу в Cocoox в нейй нашел пример для измерения с 6 каналов АЦП.
* @title main.c
* @author habed
* @date 22 Jan 2013
* @brief IN THE NAME OF GOD
*		 here in this example i used DMA for access d
*		 irectly to 6 ADC channel in regular mode
*		 "Hosein Abedini"<k.h65
*		 70@gmail.com>
*		 ask me ur questions about.
////// The above comment is automatically generated by CoIDE ///////////////////
#include<stm32f10x_adc.h>
#include<stm32f10x_rcc.h>
#include<stm32f10x_gpio.h>
#include<stm32f10x_dma.h>
ErrorStatus HSEStartUpStatus;
void Sys(void)
GPIO_InitTypeDef GPIO_InitStructure;
ADC_InitTypeDef ADC_InitStructure;
DMA_InitTypeDef DMA_InitStructure;
uint16_t ADCBuffer[] = {0xAAAA, 0xAAAA, 0xAAAA, 0xAAAA, 0xAAAA, 0xAAAA, 0xAAAA};
/* RCC system reset(for debug purpose) */
RCC_DeInit();
/* Enable HSE */
RCC_HSEConfig(RCC_HSE_ON);
/* Wait till HSE is ready */
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if (HSEStartUpStatus == SUCCESS)
 /* HCLK = SYSCLK */
 RCC_HCLKConfig(RCC_SYSCLK_Div1);
 /* PCLK2 = HCLK */
 RCC_PCLK2Config(RCC_HCLK_Div1);
 /* PCLK1 = HCLK/2 */
 RCC_PCLK1Config(RCC_HCLK_Div2);
 /* ADCCLK = PCLK2/4 */
 RCC_ADCCLKConfig(RCC_PCLK2_Div4);
 /* Flash 2 wait state */
 *(vu32 *)0x40022000 = 0x01;
 /* PLLCLK = 8MHz * 9 = 56 MHz */
 RCC_PLLConfig(0x00010000, RCC_PLLMul_9);
 /* Enable PLL */
 RCC_PLLCmd(ENABLE);
 /* Wait till PLL is ready */
 while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
 /* Select PLL as system clock source */
 RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
 /* Wait till PLL is used as system clock source */
 while (RCC_GetSYSCLKSource() != 0x08);
/* Enable ADC1 and GPIOC clock */
RCC_APB2PeriphClockCmd( RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOA
		 | RCC_APB2Periph_GPIOB
		 , ENABLE);
RCC_AHBPeriphClockCmd ( RCC_AHBPeriph_DMA1 , ENABLE ) ;
DMA_InitStructure.DMA_BufferSize = 6;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)ADCBuffer;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&ADC1->DR;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_Init(DMA1_Channel1, &DMA_InitStructure);
DMA_Cmd ( DMA1_Channel1 , ENABLE ) ;
RCC_ADCCLKConfig ( RCC_PCLK2_Div6 ) ;
RCC_APB2PeriphClockCmd ( RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO | RCC_APB2Periph_ADC1 ,
ENABLE ) ;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
ADC_InitStructure.ADC_NbrOfChannel = 2;
ADC_InitStructure.ADC_ScanConvMode = ENABLE;
ADC_Init(ADC1, &ADC_InitStructure);
ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_7Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 2, ADC_SampleTime_7Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 3, ADC_SampleTime_7Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 4, ADC_SampleTime_7Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 5, ADC_SampleTime_7Cycles5);
ADC_RegularChannelConfig(ADC1, ADC_Channel_15, 6, ADC_SampleTime_7Cycles5);
ADC_Cmd ( ADC1 , ENABLE ) ;
ADC_DMACmd ( ADC1 , ENABLE ) ;
ADC_ResetCalibration(ADC1);
while(ADC_GetResetCalibrationStatus(ADC1));
ADC_StartCalibration(ADC1);
while(ADC_GetCalibrationStatus(ADC1));
ADC_SoftwareStartConvCmd ( ADC1 , ENABLE ) ;
int main(void)
Sys();
while(1)
 /*you can read 6 channels of ADC1 in ADC buffer*/
мне нужен канал PA.0, PA.1.
ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_7Cycles5);//1 канал АЦП PA.0
ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_7Cycles5);//2 канал АЦП PA.1
забираю из ADCBuffer[0] и ADCBuffer[1].
значения только есть в ADCBuffer[0] а в ADCBuffer[1] пусто
mail_robot    1502
чето я не понял что в листинге и что в прищепке. Зарисуй свой код как есть. То что на листе работать не будет
Edited by mail_robot
Кинг    0
void Sys(void)
RCC_DeInit();
/* Enable HSE */
	 /* HCLK = SYSCLK */
	 /* PCLK2 = HCLK */
	 /* Enable PLL */
	 RCC_PLLCmd(ENABLE);
					 , ENABLE);
RCC_APB2PeriphClockCmd ( RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO | RCC_APB2Periph_ADC1 ,
ENABLE ) ;
GPIO_Init(GPIOA, &GPIO_InitStructure);
int main(void)
uint16_t res1=0,res2=0;
Sys();
while(1)
	 res1=ADCBuffer[0] ;
	 res2= ADCBuffer[1];
mail_robot    1502
uint32_t ADCBuffer[2];
DMA_InitStructure.DMA_BufferSize = 2;
uint32_t res1=0,res2=0;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
для начала
ADC_DMARequestModeConfig(ADC1, ADC_DMAMode_Circular);
не увидел этой строчки нигде. Надо вставить перед
хотя код такой сумбурный, что хз где тут ее грамотнее ставить.
mail_robot    1502
чет подумал, наверн всетки строчку
надо поставить перед
тогда цикличные запросы должны пойти и массивчик начнет заливаться регулярно, иначе придется дергать вручную
и вот это вот
я бы поставил перед
потому как в мануале пишут, что калибровка должна быть выполнена до запуска АЦП
Кинг    0
ADC_DMARequestModeConfig(ADC1, ADC_DMAMode_Circular); этой строчки компилятор незнает
если калибровку ставить перед запуском АЦП то он зацикливается на while(ADC_GetResetCalibrationStatus(ADC1));
mail_robot    1502
ну тогда надо внимательно посмотреть мануал на тему порядка калибровки под свой камень. Выходит не все они похожи.
про первую строчку - посмотрите функцию в библиотеке, они бывает на одну буковку отличаются. Тут надо некоторую фантазию включать
Кинг    0
void ADCInit(void){
   //--Enable ADC1 and GPIOA--
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOA, ENABLE);
   GPIO_InitTypeDef GPIO_InitStructure; //Variable used to setup the GPIO pins
   //==Configure ADC pins (PA0 -> Channel 0 to PA7 -> Channel 7) as analog inputs==
   GPIO_StructInit(&GPIO_InitStructure); // Reset init structure, if not it can cause issues...
   ADC1->CR2 |= ADC_CR2_CAL; //Запуск калибровки АЦП
   while (!(ADC1->CR2 & ADC_CR2_CAL));
   //ADC1 configuration
   //We will convert multiple channels
   ADC_InitStructure.ADC_ScanConvMode = DISABLE;
   //select continuous conversion mode
   ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//!
   //select no external triggering
   //right 12-bit data alignment in ADC data register
   //8 channels conversion
   //load structure values to control and status registers
   //wake up temperature sensor
   //ADC_TempSensorVrefintCmd(ENABLE);
   //configure each channel
   ADC_Cmd(ADC1, ENABLE);
void get_adc (void)
unsigned int adc_res=0,adc_res2=0,voltage=0,voltage1=0; //Использовал переменную для отладки. Можно и без неё
unsigned char index=0;
unsigned int adc[7],adc1[7];
for(index=0;index<6;index++)
ADC_RegularChannelConfig(ADC1,ADC_Channel_0, 1,ADC_SampleTime_28Cycles5);
   ADC_ClearFlag (ADC1,ADC_FLAG_EOC);
   ADC_SoftwareStartConvCmd(ADC1, ENABLE);
   while (ADC_GetFlagStatus (ADC1,ADC_FLAG_EOC) == RESET);	    // wait for conversion to complete
   adc_res  = ADC_GetConversionValue (ADC1);
   ADC_RegularChannelConfig(ADC1,ADC_Channel_1, 1,ADC_SampleTime_28Cycles5);
 ADC_SoftwareStartConvCmd(ADC1, ENABLE);	    // start another
 adc_res2  = ADC_GetConversionValue (ADC1);
 adc[index]= adc_res;
 adc1[index]=adc_res2;
volt=adc[1]+adc[2]+adc[3]+adc[4]+adc[5];
voltage=volt;
volt=volt/5;
volt= (volt * 80) / 1000;
voltage=volt;
amper=adc1[1]+adc1[2]+adc1[3]+adc1[4]+adc1[5];
 voltage1=amper;
amper=amper/5;
amper=amper/0.02*10;
amper= (amper * 80) / 100000;
   voltage1=amper;
   wat=(volt*amper)/100;
этот заработал
LoKeR    0
этот заработал
а у меня не заработало ввыводит
source\main.c(24): error:  #268: declaration may not appear after executable statement in block
как можно избавиться от этой проблемы?
