Не Работает Приём Usart
Гость Victor
Плата Sstm32f4discovery. Использую HAL. Стандартная инициализация не вырезана.
Тактирование настраивается так:
RCC_ClkInitTypeDef RCC_ClkInitStruct;
RCC_OscInitTypeDef RCC_OscInitStruct;
// Enable Power Control clock
__PWR_CLK_ENABLE();
// The voltage scaling allows optimizing the power consumption when the
// device is clocked below the maximum system frequency, to update the
// voltage scaling value regarding system frequency refer to product
// datasheet.
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
// Enable HSE Oscillator and activate PLL with HSE as source
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
// This assumes the HSE_VALUE is a multiple of 1MHz. If this is not
// your case, you have to recompute these PLL constants.
RCC_OscInitStruct.PLL.PLLM = (HSE_VALUE/1000000u);
RCC_OscInitStruct.PLL.PLLN = 336;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLQ = 7;
HAL_RCC_OscConfig(&RCC_OscInitStruct);
// Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
// clocks dividers
RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK
| RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5);
То есть тактируемтся от 16 MHz HSI, все делители - 1.
Сам код передачи/приёма тоже HAL:
#include <stm32f4xx_hal.h>
UART_HandleTypeDef comp;
uint8_t for_send[] = {0};
uint8_t for_receive[] = {1};
void init_led ( void ) {
GPIO_InitTypeDef led;
__HAL_RCC_GPIOD_CLK_ENABLE( );
led.Mode = GPIO_MODE_OUTPUT_PP;
led.Pin = GPIO_PIN_14 | GPIO_PIN_15;
led.Speed = GPIO_SPEED_LOW;
led.Pull = GPIO_NOPULL;
HAL_GPIO_Init( GPIOD, &led );
void HAL_UART_MspInit ( UART_HandleTypeDef * huart ) {
   __HAL_RCC_USART1_CLK_ENABLE( );
   __HAL_RCC_GPIOB_CLK_ENABLE( );
   GPIO_InitTypeDef gpio;
   gpio.Mode = GPIO_MODE_AF_PP;
   gpio.Pin = GPIO_PIN_6 | GPIO_PIN_6;
   gpio.Pull = GPIO_PULLUP;
   gpio.Alternate = GPIO_AF7_USART1;
   gpio.Speed = GPIO_SPEED_MEDIUM;
   HAL_GPIO_Init( GPIOD, &gpio );
   HAL_NVIC_EnableIRQ( USART1_IRQn );
int main ( void ) {
   comp.Init.BaudRate = 9600;
   comp.Init.Mode = UART_MODE_TX_RX;
   comp.Init.HwFlowCtl = UART_HWCONTROL_NONE;
   comp.Init.WordLength = UART_WORDLENGTH_8B;
   comp.Init.OverSampling = UART_OVERSAMPLING_16;
   comp.Init.Parity = UART_PARITY_NONE;
   comp.Init.StopBits = UART_STOPBITS_1;
   comp.Instance = USART1;
   comp.State = 0;
   HAL_UART_Init( &comp );
   __HAL_USART_ENABLE_IT( &comp, UART_IT_TXE );
   __HAL_USART_ENABLE_IT( &comp, UART_IT_RXNE );
   init_led( );
   HAL_GPIO_WritePin( GPIOD, GPIO_PIN_15, SET );
   while ( 1 ) {
    for( volatile int i = 0; i < 100000; i ++ ) { ; }
    HAL_GPIO_TogglePin( GPIOD, GPIO_PIN_14 );
void USART1_IRQHandler( void ) {
if ( __HAL_UART_GET_FLAG( &comp, UART_FLAG_TXE ) ) {
 __HAL_UART_DISABLE_IT( &comp, UART_IT_TXE );
 HAL_UART_Transmit( &comp, for_send, 1, 0 );
 __HAL_UART_CLEAR_FLAG( &comp, UART_FLAG_TXE );
if ( __HAL_UART_GET_FLAG( &comp, UART_FLAG_RXNE)) {
 __HAL_UART_DISABLE_IT( &comp, UART_FLAG_RXNE );
 HAL_UART_Receive( &comp, for_receive, 1, 0 );
 HAL_GPIO_WritePin( GPIOD, GPIO_PIN_15, RESET );
 __HAL_UART_CLEAR_FLAG( &comp, UART_FLAG_RXNE );
Всё просто. Включаем передачу, приём. Передаём, в приёмнике забираем информацию и гасим включенный светодиод.
ЗАходит в прерывание по TXE отправляет данные (Должны ли мы увидеть изменение регистра DR в отладчике, просто он остаётся пустой)
Отослал, вышел из прерывания, начитает мигать светодиодом( просто как индикатор что схема работает).
Но приёма не происходит.
Все инициализации сверены с user_manual. По всему коду прошёлся с отладчиком, все биты HAL выставляет правильно.
PB6 и PB7 просто перемычкой соединены.
Народ, помогите. Не работает элементарная отправка единицы по UARTу и не знаю где ошибка. Подскажите, пожалуйста. Плата stm32f051
#include <stm32f0xx.h>
int main(void)
RCC->APB2ENR |= 0x00020000; //RCC_AHBENR_GPIOAEN;
GPIOA->MODER |= 0x00080000; //GPIO_MODER_MODER9_1;
GPIOA->OSPEEDR |= 0x000C0000; //~GPIO_OSPEEDER_OSPEEDR9;
RCC->APB2ENR |= RCC_APB2ENR_USART1EN;
USART1->CR1 |= USART_CR1_UE;
USART1->CR2 |= 0x0;
USART1->BRR=0x1388;
USART1->CR1 |= USART_CR1_TE;
while (1)
{ //if ((GPIOA->IDR & GPIO_Pin_0) != 0)
while(!(USART1->ISR & 0x40)){}; //USART_SR_TC
USART1->TDR=1;
Изменено пользователем ProtonM16
  • 1 год спустя...
#define APBCLK 48000000UL
#define BAUDRATE 115200UL
void Usart_init (void)
      RCC->AHBENR |= RCC_AHBENR_GPIOAEN;
      RCC->APB2ENR|=RCC_APB2ENR_USART1EN;
      GPIOA->MODER &= ~(GPIO_MODER_MODER1 | GPIO_MODER_MODER10 |GPIO_MODER_MODER9);
      GPIOA->MODER |=  GPIO_MODER_MODER1_0 | GPIO_MODER_MODER10_1 |GPIO_MODER_MODER9_1;
      GPIOA->AFR[1] |=(1<<(4*1)) |(1<<(4*2));
      USART1->BRR =(APBCLK+BAUDRATE/2)/BAUDRATE; //usart
      USART1->CR1 |= USART_CR1_TE |USART_CR1_RE|USART_CR1_RXNEIE; // USART1
      USART1->CR1 |= USART_CR1_UE; //   USART1
      NVIC_SetPriority(USART1_IRQn, 0);
      NVIC_EnableIRQ(USART1_IRQn);
 void Usart_Transmit(uint8_t Data)
  while(!(USART1->ISR & USART_ISR_TC));
  USART1->TDR = Data;
void USART1_IRQHandler(void)
    uint8_t rx;
    if(USART1->ISR & USART_ISR_RXNE)
    rx = USART1->RDR; // Receive data, clear flag
void USART1_str (const char * data)
    while((*data )){
      Usart_Transmit (*data);
        data++;
Для F0 ...
Изменено пользователем dosikus
  • Похожий контент
