Arduino С Использованием Irremoute
код библиотеки?
* IRremote
* Version 0.11 August, 2009
* Copyright 2009 Ken Shirriff
* For details, see [url="http://arcfn.com/2009/08/multi-protocol-infrared-remote-library.html"]http://arcfn.com/200...te-library.html[/url]
* Modified by Paul Stoffregen <paul@pjrc.com> to support other boards and timers
* Modified  by Mitra Ardron <mitra@mitra.biz>
* Added Sanyo and Mitsubishi controllers
* Modified Sony to spot the repeat codes that some Sony's send
* Interrupt code based on NECIRrcv by Joe Knapp
* [url="http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1210243556"]http://www.arduino.c...?num=1210243556[/url]
* Also influenced by [url="http://zovirl.com/2008/11/12/building-a-universal-remote-with-an-arduino/"]http://zovirl.com/20...ith-an-arduino/[/url]
* JVC and Panasonic protocol added by Kristian Lauszus (Thanks to zenwheel and other people at the original blog post)
#include "IRremote.h"
#include "IRremoteInt.h"
// Provides ISR
#include <avr/interrupt.h>
volatile irparams_t irparams;
// These versions of MATCH, MATCH_MARK, and MATCH_SPACE are only for debugging.
// To use them, set DEBUG in IRremoteInt.h
// Normally macros are used for efficiency
#ifdef DEBUG
int MATCH(int measured, int desired) {
 Serial.print("Testing: ");
 Serial.print(TICKS_LOW(desired), DEC);
 Serial.print(" <= ");
 Serial.print(measured, DEC);
 Serial.println(TICKS_HIGH(desired), DEC);
 return measured >= TICKS_LOW(desired) && measured <= TICKS_HIGH(desired);
int MATCH_MARK(int measured_ticks, int desired_us) {
 Serial.print("Testing mark ");
 Serial.print(measured_ticks * USECPERTICK, DEC);
 Serial.print(" vs ");
 Serial.print(desired_us, DEC);
 Serial.print(": ");
 Serial.print(TICKS_LOW(desired_us + MARK_EXCESS), DEC);
 Serial.print(measured_ticks, DEC);
 Serial.println(TICKS_HIGH(desired_us + MARK_EXCESS), DEC);
 return measured_ticks >= TICKS_LOW(desired_us + MARK_EXCESS) && measured_ticks <= TICKS_HIGH(desired_us + MARK_EXCESS);
int MATCH_SPACE(int measured_ticks, int desired_us) {
 Serial.print("Testing space ");
 Serial.print(": ");
 Serial.print(TICKS_LOW(desired_us - MARK_EXCESS), DEC);
 Serial.println(TICKS_HIGH(desired_us - MARK_EXCESS), DEC);
 return measured_ticks >= TICKS_LOW(desired_us - MARK_EXCESS) && measured_ticks <= TICKS_HIGH(desired_us - MARK_EXCESS);
#endif
void IRsend::sendNEC(unsigned long data, int nbits)
 enableIROut(38);
 mark(NEC_HDR_MARK);
 space(NEC_HDR_SPACE);
 for (int i = 0; i < nbits; i++) {
if (data & TOPBIT) {
  mark(NEC_BIT_MARK);
  space(NEC_ONE_SPACE);
else {
  mark(NEC_BIT_MARK);
  space(NEC_ZERO_SPACE);
data <<= 1;
 mark(NEC_BIT_MARK);
 space(0);
void IRsend::sendSony(unsigned long data, int nbits) {
 enableIROut(40);
 mark(SONY_HDR_MARK);
 space(SONY_HDR_SPACE);
 data = data << (32 - nbits);
  mark(SONY_ONE_MARK);
else {
  mark(SONY_ZERO_MARK);
data <<= 1;
void IRsend::sendRaw(unsigned int buf[], int len, int hz)
 enableIROut(hz);
 for (int i = 0; i < len; i++) {
if (i & 1) {
  space(buf[i]);
else {
  mark(buf[i]);
 space(0); // Just to be sure
// Note: first bit must be a one (start bit)
void IRsend::sendRC5(unsigned long data, int nbits)
 enableIROut(36);
 mark(RC5_T1); // First start bit
 space(RC5_T1); // Second start bit
 mark(RC5_T1); // Second start bit
  space(RC5_T1); // 1 is space, then mark
  mark(RC5_T1);
else {
  mark(RC5_T1);
  space(RC5_T1);
data <<= 1;
 space(0); // Turn off at end
// Caller needs to take care of flipping the toggle bit
void IRsend::sendRC6(unsigned long data, int nbits)
 enableIROut(36);
 mark(RC6_HDR_MARK);
 space(RC6_HDR_SPACE);
 mark(RC6_T1); // start bit
 space(RC6_T1);
 int t;
if (i == 3) {
  // double-wide trailer bit
  t = 2 * RC6_T1;
else {
  t = RC6_T1;
  mark(t);
  space(t);
else {
  space(t);
  mark(t);
data <<= 1;
void IRsend::sendPanasonic(unsigned int address, unsigned long data) {
enableIROut(35);
mark(PANASONIC_HDR_MARK);
space(PANASONIC_HDR_SPACE);
for(int i=0;i<16;i++)
	mark(PANASONIC_BIT_MARK);
	if (address & 0x8000) {
		space(PANASONIC_ONE_SPACE);
	} else {
		space(PANASONIC_ZERO_SPACE);
	address <<= 1;
for (int i=0; i < 32; i++) {
	} else {
	data <<= 1;
space(0);
void IRsend::sendJVC(unsigned long data, int nbits, int repeat)
enableIROut(38);
if (!repeat){
	mark(JVC_HDR_MARK);
	space(JVC_HDR_SPACE);
		mark(JVC_BIT_MARK);
		space(JVC_ONE_SPACE);
	else {
		mark(JVC_BIT_MARK);
		space(JVC_ZERO_SPACE);
	data <<= 1;
mark(JVC_BIT_MARK);
space(0);
void IRsend::mark(int time) {
 // Sends an IR mark for the specified number of microseconds.
 // The mark output is modulated at the PWM frequency.
 TIMER_ENABLE_PWM; // Enable pin 3 PWM output
 delayMicroseconds(time);
/* Leave pin off for time (given in microseconds) */
void IRsend::space(int time) {
 // Sends an IR space for the specified number of microseconds.
 // A space is no output, so the PWM output is disabled.
 TIMER_DISABLE_PWM; // Disable pin 3 PWM output
void IRsend::enableIROut(int khz) {
 // Enables IR output.  The khz value controls the modulation frequency in kilohertz.
 // The IR output will be on pin 3 (OC2B).
 // This routine is designed for 36-40KHz; if you use it for other values, it's up to you
 // to make sure it gives reasonable results.  (Watch out for overflow / underflow / rounding.)
 // TIMER2 is used in phase-correct PWM mode, with OCR2A controlling the frequency and OCR2B
 // controlling the duty cycle.
 // There is no prescaling, so the output frequency is 16MHz / (2 * OCR2A)
 // To turn the output on and off, we leave the PWM running, but connect and disconnect the output pin.
 // A few hours staring at the ATmega documentation and this will all make sense.
 // See my Secrets of Arduino PWM at [url="http://arcfn.com/2009/07/secrets-of-arduino-pwm.html"]http://arcfn.com/200...rduino-pwm.html[/url] for details.
 // Disable the Timer2 Interrupt (which is used for receiving IR)
 TIMER_DISABLE_INTR; //Timer2 Overflow Interrupt
 pinMode(TIMER_PWM_PIN, OUTPUT);
 digitalWrite(TIMER_PWM_PIN, LOW); // When not sending PWM, we want it low
 // COM2A = 00: disconnect OC2A
 // COM2B = 00: disconnect OC2B; to send signal set to 10: OC2B non-inverted
 // WGM2 = 101: phase-correct PWM with OCRA as top
 // CS2 = 000: no prescaling
 // The top value for the timer.  The modulation frequency will be SYSCLOCK / 2 / OCR2A.
 TIMER_CONFIG_KHZ(khz);
IRrecv::IRrecv(int recvpin)
 irparams.recvpin = recvpin;
 irparams.blinkflag = 0;
// initialization
void IRrecv::enableIRIn() {
 cli();
 // setup pulse clock timer interrupt
 //Prescale /8 (16M/8 = 0.5 microseconds per tick)
 // Therefore, the timer interval can range from 0.5 to 128 microseconds
 // depending on the reset value (255 to 0)
 TIMER_CONFIG_NORMAL();
 //Timer2 Overflow Interrupt Enable
 TIMER_ENABLE_INTR;
 TIMER_RESET;
 sei();  // enable interrupts
 // initialize state machine variables
 irparams.rcvstate = STATE_IDLE;
 irparams.rawlen = 0;
 // set pin modes
 pinMode(irparams.recvpin, INPUT);
// enable/disable blinking of pin 13 on IR processing
void IRrecv::blink13(int blinkflag)
 irparams.blinkflag = blinkflag;
 if (blinkflag)
pinMode(BLINKLED, OUTPUT);
// TIMER2 interrupt code to collect raw data.
// Widths of alternating SPACE, MARK are recorded in rawbuf.
// Recorded in ticks of 50 microseconds.
// rawlen counts the number of entries recorded so far.
// First entry is the SPACE between transmissions.
// As soon as a SPACE gets long, ready is set, state switches to IDLE, timing of SPACE continues.
// As soon as first MARK arrives, gap width is recorded, ready is cleared, and new logging starts
ISR(TIMER_INTR_NAME)
 TIMER_RESET;
 uint8_t irdata = (uint8_t)digitalRead(irparams.recvpin);
 irparams.timer++; // One more 50us tick
 if (irparams.rawlen >= RAWBUF) {
// Buffer overflow
irparams.rcvstate = STATE_STOP;
 switch(irparams.rcvstate) {
 case STATE_IDLE: // In the middle of a gap
if (irdata == MARK) {
  if (irparams.timer < GAP_TICKS) {
	// Not big enough to be a gap.
	irparams.timer = 0;
  else {
	// gap just ended, record duration and start recording transmission
	irparams.rawbuf[irparams.rawlen++] = irparams.timer;
	irparams.timer = 0;
	irparams.rcvstate = STATE_MARK;
break;
 case STATE_MARK: // timing MARK
if (irdata == SPACE) {   // MARK ended, record time
  irparams.timer = 0;
  irparams.rcvstate = STATE_SPACE;
break;
 case STATE_SPACE: // timing SPACE
if (irdata == MARK) { // SPACE just ended, record it
  irparams.timer = 0;
else { // SPACE
  if (irparams.timer > GAP_TICKS) {
	// big SPACE, indicates gap between codes
	// Mark current code as ready for processing
	// Switch to STOP
	// Don't reset timer; keep counting space width
break;
 case STATE_STOP: // waiting, measuring gap
if (irdata == MARK) { // reset gap timer
  irparams.timer = 0;
break;
 if (irparams.blinkflag) {
  BLINKLED_ON();  // turn pin 13 LED on
else {
  BLINKLED_OFF();  // turn pin 13 LED off
void IRrecv::resume() {
// Decodes the received IR message
// Returns 0 if no data ready, 1 if data ready.
// Results of decoding are stored in results
int IRrecv::decode(decode_results *results) {
 results->rawbuf = irparams.rawbuf;
 results->rawlen = irparams.rawlen;
 if (irparams.rcvstate != STATE_STOP) {
return ERR;
#ifdef DEBUG
 Serial.println("Attempting NEC decode");
#endif
 if (decodeNEC(results)) {
return DECODED;
#ifdef DEBUG
 Serial.println("Attempting Sony decode");
#endif
 if (decodeSony(results)) {
return DECODED;
#ifdef DEBUG
 Serial.println("Attempting Sanyo decode");
#endif
 if (decodeSanyo(results)) {
return DECODED;
#ifdef DEBUG
 Serial.println("Attempting Mitsubishi decode");
#endif
 if (decodeMitsubishi(results)) {
return DECODED;
#ifdef DEBUG
 Serial.println("Attempting RC5 decode");
#endif
 if (decodeRC5(results)) {
return DECODED;
#ifdef DEBUG
 Serial.println("Attempting RC6 decode");
#endif
 if (decodeRC6(results)) {
return DECODED;
#ifdef DEBUG
Serial.println("Attempting Panasonic decode");
#endif
if (decodePanasonic(results)) {
	return DECODED;
#ifdef DEBUG
Serial.println("Attempting JVC decode");
#endif
if (decodeJVC(results)) {
	return DECODED;
 // decodeHash returns a hash on any input.
 // Thus, it needs to be last in the list.
 // If you add any decodes, add them before this.
 if (decodeHash(results)) {
return DECODED;
 // Throw away and start over
 resume();
 return ERR;
// NECs have a repeat only 4 items long
long IRrecv::decodeNEC(decode_results *results) {
 long data = 0;
 int offset = 1; // Skip first space
 // Initial mark
 if (!MATCH_MARK(results->rawbuf[offset], NEC_HDR_MARK)) {
return ERR;
 offset++;
 // Check for repeat
 if (irparams.rawlen == 4 &&
MATCH_SPACE(results->rawbuf[offset], NEC_RPT_SPACE) &&
MATCH_MARK(results->rawbuf[offset+1], NEC_BIT_MARK)) {
results->bits = 0;
results->value = REPEAT;
results->decode_type = NEC;
return DECODED;
 if (irparams.rawlen < 2 * NEC_BITS + 4) {
return ERR;
 // Initial space
 if (!MATCH_SPACE(results->rawbuf[offset], NEC_HDR_SPACE)) {
return ERR;
 offset++;
 for (int i = 0; i < NEC_BITS; i++) {
if (!MATCH_MARK(results->rawbuf[offset], NEC_BIT_MARK)) {
  return ERR;
offset++;
if (MATCH_SPACE(results->rawbuf[offset], NEC_ONE_SPACE)) {
  data = (data << 1) | 1;
else if (MATCH_SPACE(results->rawbuf[offset], NEC_ZERO_SPACE)) {
  data <<= 1;
else {
  return ERR;
offset++;
 // Success
 results->bits = NEC_BITS;
 results->value = data;
 return DECODED;
long IRrecv::decodeSony(decode_results *results) {
 long data = 0;
 if (irparams.rawlen < 2 * SONY_BITS + 2) {
return ERR;
 int offset = 0; // Dont skip first space, check its size
 // Some Sony's deliver repeats fast after first
 // unfortunately can't spot difference from of repeat from two fast clicks
 if (results->rawbuf[offset] < SONY_DOUBLE_SPACE_USECS) {
// Serial.print("IR Gap found: ");
results->bits = 0;
results->decode_type = SANYO;
return DECODED;
 offset++;
 // Initial mark
 if (!MATCH_MARK(results->rawbuf[offset], SONY_HDR_MARK)) {
return ERR;
 offset++;
 while (offset + 1 < irparams.rawlen) {
if (!MATCH_SPACE(results->rawbuf[offset], SONY_HDR_SPACE)) {
  break;
offset++;
if (MATCH_MARK(results->rawbuf[offset], SONY_ONE_MARK)) {
else if (MATCH_MARK(results->rawbuf[offset], SONY_ZERO_MARK)) {
  data <<= 1;
else {
  return ERR;
offset++;
 // Success
 results->bits = (offset - 1) / 2;
 if (results->bits < 12) {
results->bits = 0;
return ERR;
 results->decode_type = SONY;
 return DECODED;
// I think this is a Sanyo decoder - serial = SA 8650B
// Looks like Sony except for timings, 48 chars of data and time/space different
long IRrecv::decodeSanyo(decode_results *results) {
 long data = 0;
 if (irparams.rawlen < 2 * SANYO_BITS + 2) {
return ERR;
 int offset = 0; // Skip first space
 // Initial space
 /* Put this back in for debugging - note can't use #DEBUG as if Debug on we don't see the repeat cos of the delay
 Serial.print("IR Gap: ");
 Serial.println( results->rawbuf[offset]);
 Serial.println( "test against:");
 Serial.println(results->rawbuf[offset]);
 if (results->rawbuf[offset] < SANYO_DOUBLE_SPACE_USECS) {
results->bits = 0;
return DECODED;
 offset++;
 // Initial mark
 if (!MATCH_MARK(results->rawbuf[offset], SANYO_HDR_MARK)) {
return ERR;
 offset++;
 // Skip Second Mark
return ERR;
 offset++;
if (!MATCH_SPACE(results->rawbuf[offset], SANYO_HDR_SPACE)) {
  break;
offset++;
if (MATCH_MARK(results->rawbuf[offset], SANYO_ONE_MARK)) {
else if (MATCH_MARK(results->rawbuf[offset], SANYO_ZERO_MARK)) {
  data <<= 1;
else {
  return ERR;
offset++;
 // Success
results->bits = 0;
return ERR;
 return DECODED;
long IRrecv::decodeMitsubishi(decode_results *results) {
 // Serial.print("?!? decoding Mitsubishi:");Serial.print(irparams.rawlen); Serial.print(" want "); Serial.println( 2 * MITSUBISHI_BITS + 2);
 long data = 0;
 if (irparams.rawlen < 2 * MITSUBISHI_BITS + 2) {
return ERR;
 // Initial space
 /* Not seeing double keys from Mitsubishi
 if (results->rawbuf[offset] < MITSUBISHI_DOUBLE_SPACE_USECS) {
results->bits = 0;
results->decode_type = MITSUBISHI;
return DECODED;
 offset++;
 // Typical
 // 14200 7 41 7 42 7 42 7 17 7 17 7 18 7 41 7 18 7 17 7 17 7 18 7 41 8 17 7 17 7 18 7 17 7
 // Initial Space
 if (!MATCH_MARK(results->rawbuf[offset], MITSUBISHI_HDR_SPACE)) {
return ERR;
 offset++;
if (MATCH_MARK(results->rawbuf[offset], MITSUBISHI_ONE_MARK)) {
else if (MATCH_MARK(results->rawbuf[offset], MITSUBISHI_ZERO_MARK)) {
  data <<= 1;
else {
  // Serial.println("A"); Serial.println(offset); Serial.println(results->rawbuf[offset]);
  return ERR;
offset++;
if (!MATCH_SPACE(results->rawbuf[offset], MITSUBISHI_HDR_SPACE)) {
  // Serial.println("B"); Serial.println(offset); Serial.println(results->rawbuf[offset]);
  break;
offset++;
 // Success
 if (results->bits < MITSUBISHI_BITS) {
results->bits = 0;
return ERR;
 return DECODED;
// Gets one undecoded level at a time from the raw buffer.
// The RC5/6 decoding is easier if the data is broken into time intervals.
// E.g. if the buffer has MARK for 2 time intervals and SPACE for 1,
// successive calls to getRClevel will return MARK, MARK, SPACE.
// offset and used are updated to keep track of the current position.
// t1 is the time interval for a single bit in microseconds.
// Returns -1 for error (measured time interval is not a multiple of t1).
int IRrecv::getRClevel(decode_results *results, int *offset, int *used, int t1) {
 if (*offset >= results->rawlen) {
// After end of recorded buffer, assume SPACE.
return SPACE;
 int width = results->rawbuf[*offset];
 int val = ((*offset) % 2) ? MARK : SPACE;
 int correction = (val == MARK) ? MARK_EXCESS : - MARK_EXCESS;
 int avail;
 if (MATCH(width, t1 + correction)) {
avail = 1;
 else if (MATCH(width, 2*t1 + correction)) {
avail = 2;
 else if (MATCH(width, 3*t1 + correction)) {
avail = 3;
 else {
return -1;
 (*used)++;
 if (*used >= avail) {
*used = 0;
(*offset)++;
#ifdef DEBUG
 if (val == MARK) {
Serial.println("MARK");
 else {
Serial.println("SPACE");
#endif
 return val;
long IRrecv::decodeRC5(decode_results *results) {
 if (irparams.rawlen < MIN_RC5_SAMPLES + 2) {
return ERR;
 int offset = 1; // Skip gap space
 long data = 0;
 int used = 0;
 // Get start bits
 if (getRClevel(results, &offset, &used, RC5_T1) != MARK) return ERR;
 if (getRClevel(results, &offset, &used, RC5_T1) != SPACE) return ERR;
 int nbits;
 for (nbits = 0; offset < irparams.rawlen; nbits++) {
int levelA = getRClevel(results, &offset, &used, RC5_T1);
int levelB = getRClevel(results, &offset, &used, RC5_T1);
if (levelA == SPACE && levelB == MARK) {
  // 1 bit
else if (levelA == MARK && levelB == SPACE) {
  // zero bit
  data <<= 1;
else {
  return ERR;
 // Success
 results->bits = nbits;
 results->decode_type = RC5;
 return DECODED;
long IRrecv::decodeRC6(decode_results *results) {
 if (results->rawlen < MIN_RC6_SAMPLES) {
return ERR;
 // Initial mark
 if (!MATCH_MARK(results->rawbuf[offset], RC6_HDR_MARK)) {
return ERR;
 offset++;
 if (!MATCH_SPACE(results->rawbuf[offset], RC6_HDR_SPACE)) {
return ERR;
 offset++;
 long data = 0;
 int used = 0;
 // Get start bit (1)
 if (getRClevel(results, &offset, &used, RC6_T1) != MARK) return ERR;
 if (getRClevel(results, &offset, &used, RC6_T1) != SPACE) return ERR;
 int nbits;
 for (nbits = 0; offset < results->rawlen; nbits++) {
int levelA, levelB; // Next two levels
levelA = getRClevel(results, &offset, &used, RC6_T1);
if (nbits == 3) {
  // T bit is double wide; make sure second half matches
  if (levelA != getRClevel(results, &offset, &used, RC6_T1)) return ERR;
levelB = getRClevel(results, &offset, &used, RC6_T1);
if (nbits == 3) {
  if (levelB != getRClevel(results, &offset, &used, RC6_T1)) return ERR;
if (levelA == MARK && levelB == SPACE) { // reversed compared to RC5
  // 1 bit
else if (levelA == SPACE && levelB == MARK) {
  // zero bit
  data <<= 1;
else {
  return ERR; // Error
 // Success
 results->decode_type = RC6;
 return DECODED;
long IRrecv::decodePanasonic(decode_results *results) {
unsigned long long data = 0;
int offset = 1;
if (!MATCH_MARK(results->rawbuf[offset], PANASONIC_HDR_MARK)) {
	return ERR;
offset++;
if (!MATCH_MARK(results->rawbuf[offset], PANASONIC_HDR_SPACE)) {
	return ERR;
offset++;
// decode address
for (int i = 0; i < PANASONIC_BITS; i++) {
	if (!MATCH_MARK(results->rawbuf[offset++], PANASONIC_BIT_MARK)) {
		return ERR;
	if (MATCH_SPACE(results->rawbuf[offset],PANASONIC_ONE_SPACE)) {
	} else if (MATCH_SPACE(results->rawbuf[offset],PANASONIC_ZERO_SPACE)) {
		data <<= 1;
	} else {
		return ERR;
	offset++;
results->value = (unsigned long)data;
results->panasonicAddress = (unsigned int)(data >> 32);
results->decode_type = PANASONIC;
results->bits = PANASONIC_BITS;
return DECODED;
long IRrecv::decodeJVC(decode_results *results) {
long data = 0;
// Check for repeat
if (irparams.rawlen - 1 == 33 &&
	MATCH_MARK(results->rawbuf[offset], JVC_BIT_MARK) &&
	MATCH_MARK(results->rawbuf[irparams.rawlen-1], JVC_BIT_MARK)) {
	results->bits = 0;
	results->decode_type = JVC;
	return DECODED;
// Initial mark
if (!MATCH_MARK(results->rawbuf[offset], JVC_HDR_MARK)) {
	return ERR;
offset++;
if (irparams.rawlen < 2 * JVC_BITS + 1 ) {
	return ERR;
// Initial space
if (!MATCH_SPACE(results->rawbuf[offset], JVC_HDR_SPACE)) {
	return ERR;
offset++;
for (int i = 0; i < JVC_BITS; i++) {
	if (!MATCH_MARK(results->rawbuf[offset], JVC_BIT_MARK)) {
		return ERR;
	offset++;
	if (MATCH_SPACE(results->rawbuf[offset], JVC_ONE_SPACE)) {
	else if (MATCH_SPACE(results->rawbuf[offset], JVC_ZERO_SPACE)) {
		data <<= 1;
	else {
		return ERR;
	offset++;
//Stop bit
if (!MATCH_MARK(results->rawbuf[offset], JVC_BIT_MARK)){
	return ERR;
// Success
results->bits = JVC_BITS;
return DECODED;
* hashdecode - decode an arbitrary IR code.
* Instead of decoding using a standard encoding scheme
* (e.g. Sony, NEC, RC5), the code is hashed to a 32-bit value.
* The algorithm: look at the sequence of MARK signals, and see if each one
* is shorter (0), the same length (1), or longer (2) than the previous.
* Do the same with the SPACE signals.  Hszh the resulting sequence of 0's,
* 1's, and 2's to a 32-bit value.  This will give a unique value for each
* different code (probably), for most code systems.
* [url="http://arcfn.com/2010/01/using-arbitrary-remotes-with-arduino.html"]http://arcfn.com/201...th-arduino.html[/url]
// Compare two tick values, returning 0 if newval is shorter,
// 1 if newval is equal, and 2 if newval is longer
// Use a tolerance of 20%
int IRrecv::compare(unsigned int oldval, unsigned int newval) {
 if (newval < oldval * .8) {
return 0;
 else if (oldval < newval * .8) {
return 2;
 else {
return 1;
// Use FNV hash algorithm: [url="http://isthe.com/chongo/tech/comp/fnv/#FNV-param"]http://isthe.com/cho.../fnv/#FNV-param[/url]
#define FNV_PRIME_32 16777619
#define FNV_BASIS_32 2166136261
/* Converts the raw code values into a 32-bit hash code.
* Hopefully this code is unique for each button.
* This isn't a "real" decoding, just an arbitrary value.
long IRrecv::decodeHash(decode_results *results) {
 // Require at least 6 samples to prevent triggering on noise
 if (results->rawlen < 6) {
return ERR;
 long hash = FNV_BASIS_32;
 for (int i = 1; i+2 < results->rawlen; i++) {
int value =  compare(results->rawbuf[i], results->rawbuf[i+2]);
// Add value into the hash
hash = (hash * FNV_PRIME_32) ^ value;
 results->value = hash;
 results->bits = 32;
 results->decode_type = UNKNOWN;
 return DECODED;
/* Sharp and DISH support by Todd Treece ( [url="http://unionbridge.org/design/ircommand"]http://unionbridge.o...esign/ircommand[/url] )
The Dish send function needs to be repeated 4 times, and the Sharp function
has the necessary repeat built in because of the need to invert the signal.
Sharp protocol documentation:
[url="http://www.sbprojects.com/knowledge/ir/sharp.htm"]http://www.sbproject...ge/ir/sharp.htm[/url]
Here are the LIRC files that I found that seem to match the remote codes
from the oscilloscope:
Sharp LCD TV:
[url="http://lirc.sourceforge.net/remotes/sharp/GA538WJSA"]http://lirc.sourcefo...sharp/GA538WJSA[/url]
DISH NETWORK (echostar 301):
[url="http://lirc.sourceforge.net/remotes/echostar/301_501_3100_5100_58xx_59xx"]http://lirc.sourcefo..._5100_58xx_59xx[/url]
For the DISH codes, only send the last for characters of the hex.
i.e. use 0x1C10 instead of 0x0000000000001C10 which is listed in the
linked LIRC file.
void IRsend::sendSharp(unsigned long data, int nbits) {
 unsigned long invertdata = data ^ SHARP_TOGGLE_MASK;
 enableIROut(38);
if (data & 0x4000) {
  mark(SHARP_BIT_MARK);
  space(SHARP_ONE_SPACE);
else {
  space(SHARP_ZERO_SPACE);
data <<= 1;
 delay(46);
if (invertdata & 0x4000) {
else {
invertdata <<= 1;
 delay(46);
void IRsend::sendDISH(unsigned long data, int nbits)
 enableIROut(56);
 mark(DISH_HDR_MARK);
 space(DISH_HDR_SPACE);
if (data & DISH_TOP_BIT) {
  mark(DISH_BIT_MARK);
  space(DISH_ONE_SPACE);
else {
  space(DISH_ZERO_SPACE);
data <<= 1;
Изменено пользователем Alex
Вывод частоты реализует макрос TIMER_CONFIG_KHZ, а его реализации нет.
В общем, сделайте просто свою функцию, по типу sendRaw, а space и mark замените на вывод нуля/единицы на PIN, с задержкой в buf микросекунд.
Не, вру, нашёл :
#define TIMER_CONFIG_KHZ(val) ({ \
const uint8_t pwmval = SYSCLOCK / 2000 / (val); \
TCCR2A			 = _BV(WGM20); \
TCCR2B			 = _BV(WGM22) | _BV(CS20); \
OCR2A			 = pwmval; \
OCR2B			 = pwmval / 3; \
Никаких ограничений. Так что, как поведёт себя библиотека при нулевом значении - хз...
А вот реализация функций mark и space :
Собственно, как и предполагалось - просто вкл/выкл ШИМа и задержка на time микросекунд.
//TIMER_ENABLE_PWM; // Enable pin 3 PWM output
PORTD &= ~(1<<3);
//TIMER_DISABLE_PWM; // Disable pin 3 PWM output
PORTD |= 1<<3;
// See my Secrets of Arduino PWM at <a data-cke-saved-href="<a href="http://arcfn.com/2009/07/secrets-of-arduino-pwm.html" rel="nofollow">http://arcfn.com/2009/07/secrets-of-arduino-pwm.html</a>" href="<a href="http://arcfn.com/2009/07/secrets-of-arduino-pwm.html" rel="nofollow">http://arcfn.com/2009/07/secrets-of-arduino-pwm.html</a>" rel="nofollow"><a href="http://arcfn.com/2009/07/secrets-of-arduino-pwm.html" rel="nofollow">http://arcfn.com/2009/07/secrets-of-arduino-pwm.html</a></a> for details.
//TIMER_DISABLE_INTR; //Timer2 Overflow Interrupt
pinMode(3, OUTPUT);
digitalWrite(3, HIGH); // When not sending PWM, we want it low
//TIMER_CONFIG_KHZ(khz);
Вот похоже что-то на решение проблемы, но я когда пробовал не получилось
void setup() {
pinMode(113, OUTPUT);
void loop()
digitalWrite(13, HIGH);
delayMicroseconds(9000);
digitalWrite(13, LOW);
delayMicroseconds(4500);
delayMicroseconds(560);
delayMicroseconds(1600);
// zdes
delayMicroseconds(600);
delay(5000);
вот так написал, через светодиод теперь не работает, и не включает кондиционер, хотя все сделано по протоколу, скажите, а светодиоду не пофигу шим или просто вкл/выкл, что бы такую команду послать? Щас уже не получится, но завтра сниму плату и попробую воткнуть этот сигнал прямо на вход, какой все таки способ лучше использовать для развязки их по току, или лучше вообще снять напряжение для питания друины прямо с платы кондиционера?
через светодиод теперь не работает, .....
а светодиоду не пофигу шим или просто вкл/выкл...?
:wall: и не должно - несущей ведь нет!
Светодиоду пофигу, а ИК-приемнику - нет. Вы опять ничего не поняли про несущую и ее роль?
Питание можете брать откуда угодно, если выход ардуины будете напрямую соединять (без опторазвязки), то "массы" устройств должны быть соединены.
Все, попробовал, ничего не получается, ставил третье число в irremoute библиотеке sendRow равное ноль, ничего не происходит, тот скетч, простейший, что вверху написан тоже не запускает, пробовал и напрямую соединять нули и сигнал подавать на выход фотоприемника, и через маленький керамический конденсатор, ноль эмоций((((Может есть еще какие-то мысли?
Меня вот какие мысли посещают. У Вас, после всех этих эксперементальных тыков, вообще заработает ли хоть что-то ? Хотя бы, то, что уже работало до этого :)
Прошло еще немного времени, с тех пор не отходил от нее, получилось, все работает, через пень-колоду правда но работает... Вместо фотика стоит транзистор 2n4401, на базу генерится код с друины а сам он пропускает все необходимое дальше. Если код повторяется три-четыре раза, то она срабатыает, если код нагрудается еще чем-то, например пишу что через serial придет единица и тогда включи кондиционер, уже начинаются проблемы... Очень интересно. Сделал отдельную функцию, которая включает, вызываю ее - включается норм, пижу если в serial пришла "1" то serialprint ("пришла единица") и вызвать функцию включение, в сериал пишет что единица пришла кондей не включает. весь вечер возился, добавлял запрет на прерывания, ничего не помогает. Получилось сделать с микрушкой на другой порт, если нажал кнопку, то на кондиционере вкл. А с com портом так и не связал((( Спасибо огромное всем, было очень интересно... Буду дальше разбираться, развиваться, надеюсь тоже когда - нибудь буду полезен ;)
Значит, нужно инвертировать посылки (нули с единицами поменять местами) и включить без транзистора.
