TorAll
Hohner Contessa CA-200 / Sano GS-20
4 сообщения в этой теме
TorAll    2
Доброго всем времени!
Прочитал статью, описание вдохновляет
Скрытый текст
About 10 years ago, I saw this Hohner amp in a music store in upstate New York and I was smitten. The swirly grill cloth … interesting. The little Hohner emblem guy playing an accordion … dig it. The “Contessa” name … never heard of that one!
It turns out this amp was made by a New Jerseybased company called Sano. Sano amplification began shortly after WWII with a focus on amplifiers and electric pickups for accordions, but eventually branched out into guitar amps with all sorts of cool speaker configurations. Many people believe that Sano and Ampeg were in some way related companies, but the reality is that they were two separate entities with no real business relationship. Sano made amps primarily for their own brand, but did make amps under the Hohner and Excelsior names. One thing about Sano amps during this era: They were versatile and voiced to fit a wide range of different instruments, such as accordions and vocal microphones.
There are several legendary Sano amps out there, and this CA-200 is one of the best. Sano also made this amp under its own name and called it the GS-20. Driven by a pair of 6BQ5 (EL84) power tubes, the CA-200 has some truly milkshake-thick distortion. Combined with a large, well-built cabinet, the amp just projects like a cannon. When used with lower output pickups, there is some nice clean headroom to be found way up on the volume knob. But with hotter pickups, this amp is searing at about half-volume. This is a circuit that works well with pedals, but you really won’t need many because the onboard tremolo and long-pan reverb are outstanding.
The CA-200 sat right in the middle of the Hohner guitar amp lineup, weighing around 33 pounds and sporting a 12" speaker. These have one channel, but it’s a really good one. Pumping out about 20 watts of power, these amps have a really cool vintage garagerock tone. They somehow sound raw and refined at the same time. Also, I’ve found Sano amps in general to be some of the quietest operating amps on the vintage market. These make for excellent recording amps and every Sano I’ve owned or played has been very resistant to hum and noise.
After locating an old catalog, I found that in 1969 Hohner marketed four amp models: three for guitar and one large “general purpose” amplifier called the Orgaphon. The CA-200 was priced at $230 in 1969, but for the money you were getting a fine guitar amp — then and now.
По найденной на просторах схеме у меня возникла пара вопросов:
1) R38 (Tremolo Speed) – нижний по схеме вывод должен идти на "землю"?
2) SW2 замыкает реверберацию на землю, т.е. выключает эффект. Верно ли я думаю, что в нормальном рабочем положении без подключения внешней педали должны быть соединены "Send" и "Return"?
Liberampce.pdf
Быстрый заказ печатных плат
  • x
    мм
БАТУАЛО    186
1. Да, на землю. Можно через резистор 100-150кОм.
2. Нет. Два каскада на V4 предназначены для раскачки датчика, который преобразует электрические сигналы в механические колебания пружины ревербератора.
  • Лайк 1
TorAll    2
Только что, БАТУАЛО сказал:
Ясно, то-то я смотрю – модель не реагирует на потенциометры ревербератора и тремоло.
Другой вопрос – резистор R26. Это обратная связь? Модель с ним выдаёт полную ересь, без него – вроде как вполне вменяемая картина.
БАТУАЛО    186
Да R26 это ОООС. Обычно ее вводят в катодную цепь, а здесь в цепь сетки. Если хотите гитарный усилитель, то рекомендую делать годами проверенные схемы. Для хай-гейна я бы рекомендовал энгл, а со всеми остальными стилями легко справится Маршалл жсм800. Впрочем это дело вкуса. К сожалению в сети я бываю не часто(работа), ответит могу только через неделю.
  • Похожие публикации
    • Автор: Dima_08h
      Приветствую участников данного форума. В связи с наличием свободного времени решил осуществить свою давнюю мечту - собрать ламповый усилитель для гитары по мотивам Marshall JMC800 на лампах 6н2п-ев в преампе и 6п14п в оконечнике. Однако в отличие от оригинальной схемы хочу использовать пару выходных трансформаторов твз 1-9. Дросселя на 10 Генри у меня нет, есть дроссель др2,3-0,21II2 (3 Гн, 200 мА, 130 Ом). Такой вопрос - выходная мощность данного усилителя должна быть порядка 18Вт (согласно схемы), что необходимо изменить в схеме для использования имеющегося дросселя и выходных трансформаторов ? Будет ли кардинальная потеря в звуке ?
    • Автор: VSS
      Комплект КИТ для сборки УНЧ РР 6П14П на базе ТВЗ от Ригонды.
      В комплекте:
      1. Трансформатор силовой от Симфонии под 4 шт. 6П14П и 2 шт. 6Н2П новый в упаковке.
      2. Дроссель анодного питания Д49 5Гн 280мА новый в упаковке.
      3. Ёмкости в питание 2 шт. ЭГЦ 20мкф 450в воронежского завода, штамп ВП 0178 г/в. Новые, проверены ЕSP-метром.
      4. Ёмкости в питание 2 шт. JAMICON 100мкф 350в. Новые, проверены ЕSP-метром.
      5. Межкаскадные ёмкости К71-7 2шт. по 0,249мкф. Новые, проверены в норме.
      6. ТВЗ 2 шт. от двухтактной Ригонды выход 8/4 Ом (4 Ома это отвод от перемычки) с рабочих аппаратов.
      7. 6П14П 4 шт. б/у, накал звонится попарно две 61 и две 73 г/в, также с рабочих аппаратов.
      8. 6Н2П-ЕВ 2 шт. вроде новые штамп ВП, накал звонится.
      9. Панельки под лампы 4 шт под 6П14П и 2 шт с экранами под 6Н2П.
      10. Входные гнезда под тюльпан 2 шт черн/красн.
      11. Выходные зажимы 4 шт. 2 красн/2 черн.
      12. Регулятор резистор переменник на 2 канала 50К.
      13. Выключатель сет ТВ-4 (контакты серебро).
      14. Корпус сталь/алюминий толстый.
      Самовывоз от м. Новокосино 10 мин пешком, в приоритете. Возможна отправка ПЭК, почта по согласованию.
    • Автор: fishbone
      Добрый день уважаемые пользователи форума. Я собрался собрать копию головы ORANGE OR120 но есть множество вопросов т.к. прежде не строил ничего лампового.
      Вот схема по которой я хочу собирать:
      Т.к. ничего лампового я прежде не строил я решил не тратиться для первого опыта на квартет EL34 и дорогие трансформаторы. Было решено использовать отечественные 6Н2П-ЕВ и квартет 6П3С. В качестве трансформаторов: На питание ТС-180-2 и на выход перемотанный ТС-180. Было решено использовать именно их т.к. они у меня есть в наличие.
      Вопрос по лампам: 12ax7 на сколько я знаю можно легко и без изменений заменить на 6Н2П, главное распиновку учесть. Можно ли EL34 так же заменить без трудностей на 6П3С? Т.е. собрать всё по схеме но воткнуть не елки34 а 6п3с? На сколько я знаю такое можно проделать с 6L6 и 5881, но не уверен насчёт EL34.
      По силовому трансформатору: Можно на ТС-180-2 собрать БП способный питать всю схему и добавить смещение как в схеме?? Или проще сделать вовсе без смещения а на оконечник поискать готовую схему на 4х 6П3С?
      По выходному трансформатору: Хочу сделать выход на 4-8-16 Ом. Наматывать буду на ТС-180. Я сам не рассчитывал но мне подсказали что для 4х 6п3с и таким выходом на ТС180 нужно 5000 витков первички и 288-120-170 витков вторички. Нужный ПЭЛ для этого у меня есть, но хотел бы уточнить пойдёт ли такой трансформатор для моих целей перед тем как возьмусь мотать.
      Хочу добавить то что собирать в качестве первого опыта ЧАМПы, Маршалл 18 ватт, Тини Террор не хочу т.к. они мне не нужны и покупать детали для одного потом для другого не хочу ещё больше.
      Спасибо
    • Автор: fenrikus
      На лампе 6п14п, или других распростаранённых.
      Максимально простую, без сложной настройки.
      Выходники буду использовать ТС-160
    • Листья на сакуре не из бумаги Ах, если бы можно было писать проги как стихи!
    • Схема. Может есть у кого какие пожелания? Job1.PDF
    • в интернете нет простой примера   про звук или есть только на codevis   хотел  бы  примера на языке си AVR STUDIO 6.0 примерно при окончание  работы таймера  в конце подавался  звук  пик-пик как на микроволновке или другой вариант при нажаты кнопку первой выдавался один пик на второй два пик, и третий вариант при работы таймера когда переменный i дойдет до какого значение допустим i=20 подавался один раз пик при i=10 подавался 2 раза пик-пик а таймер еще дальше  работает считает до нуля при обратном отчете.  Этот вариант кто если ответит ответ будет универсальный для изучения звука,если можно еще другой вопрос есть 4-х разрядный 7 сегментный индикатор динамическая индикация на наго подается два разных переменный i и r спасибо за ответ как это сделать я получил ответ у меня вопрос такой при обратном отчете когда таймер  считает до нуля     чтобы загорелся на индикаторе слово  как на микроволновке  End то ист занимает три разряда один разряд получаеться с переменного i а два другой с переменного r.Заранее спасибо за ответ это всем пригодиться будет универсальный ответ!!!
    • Опять яйцо в огненном шаре
    • спасибо    не выдержит эта схема ток в 5-7 ампер.
    • Почитал тут. Стабилизатор при напруге менее 160 вольт работать не будет, улетит в защиту, только с сервоприводом, попадались при 120 нормально пашут. при такой просадке делай хорошее заземление,  оно компенсирует огромное сопротивление нулевой линии,  при качественной земмле отключай ноль до счетчика, на место его земля, напруга будет намного стабильней,  если земля позволит варить то просадки у соседей будут в 2 раза меньше. соеденять землю и ноль не советую, у меня напруга падает до 160 вольт, ток кз земля- ноль более 10А и заземление быстро сгорит. Для начала забей метровый штырь в землю и замерь напряжение фаза- земля и ноль - земля. на крайний случай 3 аккумулятора + зарядное, и вари по немногу на постоянке.   Не советую стабилизатор на такой хреновой линии. при сварке  подключай заземление к нулевому проводу, напруга у соседей немного поднимется, при сварке часть тока потечет через землю если поздно ответил, то может кому то поможет мой совет
