STM32F100RBT6B + STM32F103C8 + SPI
Anton01
Добрый день пытаюсь настроить обмен сообщениями между контролерами STM32F100RBT6B(Slave) и STM32F103C8(Master) по шине SPI.
Прошивка STM32F103C8(Master)
#include "stm32f10x.h"
#include "stm32f10x_gpio.h"
#include "stm32f10x_rcc.h"
#include "stm32f10x_spi.h"
int main()
	GPIO_InitTypeDef GPIOStructure;
	SPI_InitTypeDef SPIStructure;
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1 ,ENABLE);
	GPIO_StructInit(&GPIOStructure);
	GPIOStructure.GPIO_Pin= GPIO_Pin_4 |  GPIO_Pin_5 | GPIO_Pin_6 |GPIO_Pin_7;
	GPIOStructure.GPIO_Speed = GPIO_Speed_10MHz;
	GPIOStructure.GPIO_Mode = GPIO_Mode_AF_PP;
	GPIO_Init(GPIOA, &GPIOStructure);
	SPI_StructInit(&SPIStructure);
	SPIStructure.SPI_Direction=SPI_Direction_2Lines_FullDuplex;
	SPIStructure.SPI_Mode = SPI_Mode_Master;
	SPIStructure.SPI_DataSize = SPI_DataSize_8b;
  SPIStructure.SPI_CPOL = SPI_CPOL_Low;
  SPIStructure.SPI_CPHA = SPI_CPHA_2Edge;
  SPIStructure.SPI_NSS = SPI_NSS_Soft;
  SPIStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
  SPIStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  SPIStructure.SPI_CRCPolynomial = 7;
	SPI_Init(SPI1, &SPIStructure);
	SPI_Cmd(SPI1,ENABLE);
	while(1)
		while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_BSY) == SET);
		SPI_I2S_SendData(SPI1, 0x21);
	return 0;
Прошивка STM32F100RBT6B(Slave)
uint8_t data;
uint8_t needUpdate;
uint8_t spi_receve() {
    while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);  // ???? ???? ?????? ???????
    uint8_t received = SPI_I2S_ReceiveData(SPI1);
    return received;
void Delay(int ms)
	for (int i=0;i<ms;i++);
int main()
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE);
	GPIOStructure.GPIO_Pin= GPIO_Pin_4 |  GPIO_Pin_5 | GPIO_Pin_6 |GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9;
	GPIOStructure.GPIO_Pin= GPIO_Pin_10 | GPIO_Pin_11;
	GPIOStructure.GPIO_Mode = GPIO_Mode_Out_PP;
	GPIO_Init(GPIOC, &GPIOStructure);
	SPIStructure.SPI_Mode = SPI_Mode_Slave;
	while(1)
				Delay(1000);
				data = spi_receve();
				GPIO_ResetBits(GPIOC, GPIO_Pin_10 | GPIO_Pin_11);
				if (data == 0x21)
				GPIO_SetBits(GPIOC, GPIO_Pin_10);
				if (data == 0x22)
				GPIO_SetBits(GPIOC, GPIO_Pin_11);
				needUpdate = 0;
	return 0;
Распиновка:
PA7->PA7(MOSI), PA6->PA6(MISO), PA5->PA5(SCK), PA4->PA4(NSS)
Снимок анализатора прикрепил.
Но ничего не работае, Slave получает всякий мусор....., но не значение 0x21. Я скорее всего делаю какие-то базовые ошибки, но не могу найти что не так. Буду благодарен за посдказки. Спасибо.
Изменено пользователем Anton01
у меня вопрос - почему надо было использовать именно эту шину для не свойственной ей задачи? Есть же UART. Для особых ценителей USART
9 минут назад, Zhuk72 сказал:
Разве MOSI и MISO не нужно перекрещивать?
нет, переведите и поймете
ТС:
посмотрите на сигнала клока. У вас что только 3 тактовых импульса ?
Ничего странным не кажется?
Расшифровку аббревиатуры я знаю, потому и спрашиваю. Передача для одного является приёмом для другого и наоборот.
Update!
Да, верно, их надо параллелить. Почему-то решил, что в ведомом режиме МК меняется функционал пина. Мануал помог.
MISO - master input slave output
по моему все предельно ясно.
Зачем задавать такие вопросы. Просто для "поболтать"
SPI изъезжан уже давно и много хороший статей
Изменено пользователем hasl
