• Announcements
    • admin
      Внимание! Постить только по теме "электроника"   09/02/16
      Внимание! В данном разделе разрешено создавать только темы связанные с электроникой. Для проблем с ПО не связанных с электроникой существует специальный раздел.
      Нарушители будут забанены на 5 суток!
finnan
не работает симуляция простого мигателя
4 posts in this topic
finnan    0
Нашел вот тут простую схемку мигателя диодом:
Решил попробовать ее съэмулировать в LTSpice. Не мигает!
Вот, что должно происходить в схеме с т.з. автора:
Quote
When the supply is connected, both transistors are off and the electrolytic charges via the 330k resistor and 22R. When the voltage on the base of Q1 rises to about .6v, the transistor begins to turn on and the resistance between its collector-emitter terminals is reduced. This allows current to flow in the collector-emitter circuit and Q2 is turned on via the 1k resistor. The 10n reduces the effect (the resistance) of the 1k resistor. Q2 conducts and the LED is illuminated. The current through the LED is limited by the 22R resistor and at this point in the cycle a voltage is developed across the 22R. The negative end of the electrolytic is `jacked up' by this voltage and the positive end pushes the charge on the electrolytic into the base of Q1 to turn it on even harder. In a very short time all the energy in the electrolytic has been delivered to Q1 and it cannot hold Q1 ON any longer. The transistor turns off slightly and this has the effect of turning off Q2 a small amount. The LED begins to turn off and the voltage across the 22R reduces. The negative lead of the electro drops a small amount and so does the positive lead. This action continues around the circuit until Q1 is fully turned off. This turns off Q2 and the LED is extinguished. The cycle starts again by the 10u charging. The charge-time is considerably longer than the discharge time and this gives the LED a very brief flash
У меня же получается так, что С2 заряжается, Q1 открывается, открывает Q2, загорается диод. Но дальше якобы вся энергия из C2 должна быстро выделиться на Q1, после чего Q1 должен закрыться по задумке.
В симуляции видно, что потенциал на базе Q1 не уменьшается значительно и транзистор далее остается вечно открытым.
Что тут не так?
Может быть полярность C2 неверна и он не может разрядиться через переход база-эмиттер Q1? Менял. Не помогло.
P.S. Я знаю, что в SPICE не работают некоторые экзотические эффекты, например лавинный пробой. Однако в этой схеме он не используется, насколько я понимаю.
Lexter    392
14 часа назад, finnan сказал:
Статьи, где оперируют такими "терминами", дальше можно не читать. :)
Чтобы транзистор закрылся, ток базы должен стать равным нулю. В вашей схеме этого не происходит никогда.
Изучайте работу мультивибратора по учебникам.
Бюджетные Wi-Fi-/ Bluetooth-решения для IoT-применения
Обзор основной линейки поставок и новинок Espressif Systems – экономически выгодных SoC Wi-Fi-/ Bluetooth-чипов и модулей для IoT-применений: от простых портативных устройств до промышленных решений
proba    172
В 11.06.2018 в 02:59, finnan сказал:
R3 увеличьте до 10к .
С2 лучше неполярный
Edited by proba
Create an account
Register a new account
Sign in
Sign In Now
    • Guest Иннокентий
      By Guest Иннокентий
      Добрый вечер.
      Н е получается найти готовое решение или то, из чего это можно сделать.
      Дано кнопка с подсветкой RGB светодиодом, у кнопки два контакта. У диода будет сколько угодно (выбираю между диодами и не принципиально какой) светодиод и кнопка никак не связаны.
      Нужно сделать так, по умолчанию диод светится белым, и нужно чтобы по нажатию этой кнопки светодиод менял свой цвет с белого на красный, после повторного нажатия на кнопку он становился опять белым.
      Что-то вроде выключено - горит белый, включено - горит красный.
      Не могу понять как сделать так, что бы по нажатию кнопки менялся цвет, регуляторы и прочие не подходят, как сделать именно переключатель двух цветов?
      Спасибо
    • By arsenden
      Всем здравствовать. Попал ко мне трёхлетний телек LG 32LF620U. С типичной проблемой в виде накрывшейся LED подсветки. Уже заказаны новые полоски на Алике. Но вот что меня смущает, при замере напряжения на разъёме к подсветке, выдаёт 470 вольт. Хоть с подключенными диодами, хоть без. Я не ремонтёр. Но телек достался на халяву и захотелось разобраться самому. Я понимаю, что такого напряжения не должно быть на выходе. Но вот разобраться с источником питания мне знаний уже не хватает. Буду благодарен за любую помощь.
    • By Виталий Тамбов
      Попалась мне остаток неизвестной круглой led-люстры. сказали светодиодная лента рабочая. хочу попробовать приспособить ее  для освещения. ток не могу разобраться какой подобрать драйвер  - напряжение,ток,мощность?
       Круг разделен на  6  участков соединенных последовательно перемычками. В каждом участке по 25 smd  2835 .  дорожки собраны   по 5  штук. фото  прилагаются.  Спс  кто откликнется
    • By aiv3006
      Всем привет ! Сгорел драйвер на прожекторе  прожекторhttps://viled.net/ru/road-lighting/ss-m2-k-n-64-350100130-4-0-67(не ремонтируемый залит компаундом) Матрица состоит из 36 светодиодов (модулей ) ,каждый модуль по 3шт. 6 вольт в паралель ,далее эти модули по 3 шт подключены последовательно ,итого 6*12=72вольт .на аликс прес не найду такой на 72 вольта .Хочу запаралелить 2 ряда питалово получится 6в*6=36вольт Хочу прикупить и запитать от БП 21-38 в 1,5 А (50Вт)
      Как думаете пойдет такой блок ? И если да то нужно ли гасящие сопротивление ставить последовательно ко всей матрице ?
      Скрины https://cloud.mail.ru/public/JKgX%2F8y34CwoJG
      P.S Была мысль заточить эту матрицу под 12 вольт ,но сдесь нужно минимум перемычек так как орг стекло тогда не содится герметично на прокладку
    • By cutty_sark
      Есть предняя панель для компа от алиэкспресс:
      https://ru.aliexpress.com/item/4-USB3-0-2-USB2-0-Desktop/32964723291.html
      Надо "прицепить" к ней светодиодные индикаторы активности/прием-передача данных для каждого порта как для USB 3.0 так и для USB 2.0 (сверху). Бывает очень нужно, особенно когда работаешь/загрузаешь систему с флэшки без индикатора - не видно идет ли обмен данными или нет.
      В Сети есть такая передняя панель с индикаторами от StarTech, но очень дорогая.
      https://www.amazon.com/USB-3-0-Front-Panel-Port/dp/B01L62I5HK/
      Помогите со схемой пожалуйста.
