помогите модифицировать код attiny85
скетч
#include "TrinketHidCombo.h"
#define PIN_ENCODER_A 0
#define PIN_ENCODER_B 2
#define TRINKET_PINx  PINB
static uint8_t enc_prev_pos = 0;
static uint8_t enc_flags    = 0;
void setup()
  // set pins as input with internal pull-up resistors enabled
  pinMode(PIN_ENCODER_A, INPUT);
  pinMode(PIN_ENCODER_B, INPUT);
  digitalWrite(PIN_ENCODER_A, HIGH);
  digitalWrite(PIN_ENCODER_B, HIGH);
  TrinketHidCombo.begin(); // start the USB device engine and enumerate
  // get an initial reading on the encoder pins
  if (digitalRead(PIN_ENCODER_A) == LOW) {
    enc_prev_pos |= (1 << 0);
  if (digitalRead(PIN_ENCODER_B) == LOW) {
    enc_prev_pos |= (1 << 1);
void loop()
  int8_t enc_action = 0; // 1 or -1 if moved, sign is direction
  // note: for better performance, the code will now use
  // direct port access techniques
  // http://www.arduino.cc/en/Reference/PortManipulation
  uint8_t enc_cur_pos = 0;
  // read in the encoder state first
  if (bit_is_clear(TRINKET_PINx, PIN_ENCODER_A)) {
    enc_cur_pos |= (1 << 0);
  if (bit_is_clear(TRINKET_PINx, PIN_ENCODER_B)) {
    enc_cur_pos |= (1 << 1);
  // if any rotation at all
  if (enc_cur_pos != enc_prev_pos)
    if (enc_prev_pos == 0x00)
      // this is the first edge
      if (enc_cur_pos == 0x01) {
        enc_flags |= (1 << 0);
      else if (enc_cur_pos == 0x02) {
        enc_flags |= (1 << 1);
    if (enc_cur_pos == 0x03)
      // this is when the encoder is in the middle of a "step"
      enc_flags |= (1 << 4);
    else if (enc_cur_pos == 0x00)
      // this is the final edge
      if (enc_prev_pos == 0x02) {
        enc_flags |= (1 << 2);
      else if (enc_prev_pos == 0x01) {
        enc_flags |= (1 << 3);
      // check the first and last edge
      // or maybe one edge is missing, if missing then require the middle state
      // this will reject bounces and false movements
      if (bit_is_set(enc_flags, 0) && (bit_is_set(enc_flags, 2) || bit_is_set(enc_flags, 4))) {
        enc_action = 1;
      else if (bit_is_set(enc_flags, 2) && (bit_is_set(enc_flags, 0) || bit_is_set(enc_flags, 4))) {
        enc_action = 1;
      else if (bit_is_set(enc_flags, 1) && (bit_is_set(enc_flags, 3) || bit_is_set(enc_flags, 4))) {
        enc_action = -1;
      else if (bit_is_set(enc_flags, 3) && (bit_is_set(enc_flags, 1) || bit_is_set(enc_flags, 4))) {
        enc_action = -1;
      enc_flags = 0; // reset for next time
  enc_prev_pos = enc_cur_pos;
  if (enc_action > 0) {
    TrinketHidCombo.pressMultimediaKey(MMKEY_VOL_UP);
  else if (enc_action < 0) {
    TrinketHidCombo.pressMultimediaKey(MMKEY_VOL_DOWN);
  else {
    TrinketHidCombo.poll(); // do nothing, check if USB needs anything done
нужно чтобы вместо MMKEY_VOL_UP  и MMKEY_VOL_DOWN
на двух свободных пинах мигнул светодиод  в зависимости от
if (enc_action > 0) { ******* } вспышка светодиода на одном пине
  else if (enc_action < 0) {*********}; вспышка светодиода на другом пине
встроить короче что то вроде
pinMode(3, OUTPUT);
void loop() {
digitalWrite(3, HIGH);
delay(100);
digitalWrite(3, LOW);
Изменено пользователем dimanoid
