К1055хп1р Datasheeet
Hello!
Searching for any datasheet for the device: К1055ХП1Р
..is use in to an electronic ignition for motorcycle....
The producer is Russian company COATЭ....
The device controls ignition timing, and have problems with temperature…
Any information is welcome!
Thank you!
…my mail is drobuster@gmail.com
  • 2 месяца спустя...
