Перевести С Английского На Русский.
ЗДРАСТИ.КОМУ НИ ЛЕНЬ И КТО ХОЧЕТ ПОМОЧЬ ПОЖАЛУСТА ПЕРЕВЕДИТЕ ЭТОТ ТЕКСТ.
Pin Descriptions
VCC Supply voltage pin.
GND Ground pin.
Port B (PB7..PB0) Port B is an 8-bit bi-directional I/O port. Port pins can provide internal pull-up resistors
(selected for each bit). PB0 and PB1 also serve as the positive input (AIN0) and the
negative input (AIN1), respectively, of the On-chip Analog Comparator. The Port B output
buffers can sink 20 mA and can drive LED displays directly. When pins PB0 to PB7
are used as inputs and are externally pulled low, they will source current if the internal
pull-up resistors are activated. The Port B pins are tri-stated when a reset condition
becomes active, even if the clock is not active.
Port B also serves the functions of various special features of the AT90S2313 as listed
on page 51.
Port D (PD6..PD0) Port D has seven bi-directional I/O ports with internal pull-up resistors, PD6..PD0. The
Port D output buffers can sink 20 mA. As inputs, Port D pins that are externally pulled
low will source current if the pull-up resistors are activated. The Port D pins are tri-stated
when a reset condition becomes active, even if the clock is not active.
Port D also serves the functions of various special features of the AT90S2313 as listed
on page 56.
RESET Reset input. A low level on this pin for more than 50 ns will generate a Reset, even if the
clock is not running. Shorter pulses are not guaranteed to generate a Reset.
XTAL1 Input to the inverting Oscillator amplifier and input to the internal clock operating circuit.
XTAL2 Output from the inverting Oscillator amplifier.
4 AT90S2313
0839I–AVR–06/02
Crystal Oscillator XTAL1 and XTAL2 are input and output, respectively, of an inverting amplifier that can
be configured for use as an On-chip Oscillator, as shown in Figure 2. Either a quartz
crystal or a ceramic resonator may be used. To drive the device from an external clock
source, XTAL2 should be left unconnected while XTAL1 is driven, as shown in Figure 3.
Изменено пользователем robot-5
Электроника эта пламя страсти без неё никуда.
мне просто понять что там написана а то файлы качаю а понять не могу знаю только французский.может поможете этот текст перевести пожалуста очень надо.
Зачем тебе AT902313, он давно снят с производства!,
Вот инфа на русском про тиньку 2313, http://www.rlocman.ru/book/book.html?di=28474 ...
Электроника это целый океан творчества...
скажите пожалуста по какой именно причины он сняткасики наверное были или усоверншествовали прототип.
AT902313
Описание пинов(выводов).
Vcc Напряжение питания
Port B (PB7..PB0) Порт В - это 8 разрядный двунаправленный порт ввода/вывода. Выводы порта имеют внутренние
подключаемые резисторы подтяжки к питанию/пулл ап (подключение индивидуальное). РВ0 и РВ1 так же используются как
неинвертирующий (AIN0) и инвертирующий (AIN1) входы, соответственно, встроенного аналогового компаратора.
Выходные буферы порта В способны выдавать вытекающий ток 20 ма и могут обеспечить прямое подключение светодиодов.
Продолжать или отпала необходимость?
戦う前に相手のベルトの色に注目
Sorry, не сразу увидел ответ. Окончание перевода:
Когда пины PB0...PB7 используются как входы и имеют внешнюю подтяжку к земле, они создают вытекающий ток если подключена внутренняя подтяжка к питанию. Пины порта В находятся в третьем состоянии когда активирован сброс , даже если нет сигнала тактового генератора.
Так же порт В обслуживает различные специальные функции МК изложенные на странице 51.
Порт D - имеет семь двунаправленных линий ввода/вывода с внутренними подтягивающими резисторами. Буферы порта D могут обеспечить вытекающий ток в 20 мА. В качестве входного порта его пины создают вытекающий ток во внешней подтяжке к земле при включенной встроенной подтяжке к питанию. Пины порта D находятся в третьем состоянии когда активирован сброс , даже если нет сигнала тактового генератора.
Так же порт D обслуживает различные специальные функции МК изложенные на странице 56.
Вход сброса. Низкий уровень на этом входе в течении более чем 50 нс сгенерирует сигнал Сброса МК даже если нет сигнала системного генератора. Более короткие импульсы не гарантируют генерацию сигнала сброса.
XTAL1 - Вход инвертирующего усилителя системного генератора и вход внешних системных тактирующих импульсов.
XTAL2 - Выход инвертирующего усилителя системного генератора.
Резонатор присоединяют к XTAL1 и XTAL2 как входу и выходу соответственно, инвертирующего усилителя и устанавливают в конфигурации МК встроенный генератор, как показано на черт.2 Может быть использован как кварцевый, так и керамический резонатор. При работе МК от внешнего тактирования XTAL1 используется как вход, в то время как XTAL2 оказывается не подключенным как показано на черт.3
戦う前に相手のベルトの色に注目
здрасти если можно переведите пожалуста этот текст-
DUSB
Full speed / Low Speed Negative Data Upstream Port. Should be connected to the USB Dconnector
pin with a serial 22 Ohms resistor.
2.2.11 D+
USB Full speed / Low Speed Positive Data Upstream Port. Should be connected to the USB D+
connector pin with a serial 22 Ohms resistor.
2.2.12 UGND
USB Pads Ground.
2.2.13 UVCC
USB Pads Internal Regulator Input supply voltage.
2.2.14 UCAP
USB Pads Internal Regulator Output supply voltage. Should be connected to an external capacitor
(1μF).
2.2.15 VBUS
USB VBUS monitor and OTG negociations.
буду вам очень признателен за это.
  • 1 год спустя...
Здравствуйте,извиняюсь что ни так ни в тему залез,напишу тут.
Короче говоря прислали мне по почте сообшения,прочесть ни могу последние,
(Part no: HL-A-3528S35FC Red Luminous intensity(mcd) @ 20mA=160-355mcd price: 28.6$/kpcs.)что вот это обозначает,тоесть ка оно расшифровывается-(kpcs).
  • 5 лет спустя...
Сдравствуйте,люди добрые,обьясните пожалуйста что пишут,
Hi dear, thanks a lot for the kind inquiry to us, the price of FYLS-3528UWC is of USD20/k based on the MOQ of 10K pcs, if you have big quantity, we can offer the discount, or if you do not want so high brightness, we have other version for the choice.
Да, правильно, только минимальная партия 10000 штук, т.е. меньше чем за 200 долларов покупку не сделать.
И ещё написано, что если не нужны такие яркие, то у них есть другие варианты.
Изменено пользователем Yurkin2015
Вас благодарят за то, что вы сделали запрос. Ваш светодиод стоит 0,02 доллара (20/k=20/1000) за штуку при заказе 10000 штук и если вы закажете больше, то вам предоставят скидку. Если вам не нужна такая высокая яркость, то они могут предложить взамен что-нибудь другое.
  • 6 месяцев спустя...
Готовлю доклад для выступления технической конференции .. Есть пара выписок из научной статьи, которые хотелось бы зачитать в докладе, но они на английском языке. Нужно перевести, там текста на половину листа, кто сможет помочь?
Ну а Промтом воспользоваться религия не позволяет. Там все тематики настраиваются и формируются пользовательские словари. Так что перевод после некоторого шаманства получается достаточно адекватный.
Перевод научной статьи в технической тематики. Можно, конечно и Промтом перевести, но если вы сделаете кривой перевод, над вами смеяться будут. Если не хотите рисковать то вам дорога к техническому переводчику, к Олег Носов, как раз по вашей части, через интернет шаманит... Я к нему обращался когда дипломную писал, не за бесплатно естественно.
Я как то еще не рассматривал вариант с переводчиком, по началу сам пытался, но понял что дело не выгорает. Он возьмется за небольшой объем работы, и какова цена вопроса?
Знаете, я ему заказывал переводить выписки из журналов а там всего на 500 слов было, перевел без проблем. Расценка у него 0.05 евро за слово. Вот вам его почта nossov@comtv.ru можете сами с ним связаться уточнить.
