8051F120 + Dac
krant
Не могу понять где загвоздка.
Всего 3 регистра:
- Конфигурации
- МЗР ЦАП
- СЗР ЦАП
так вот, при записи в эти регистры, изменения выходного уровня не происходит.
Мож я чего упустил ? (задержку в 10мкс для установления уровня учёл).
Вот код (экзампл, писал не я, код поставляется с MPLAB IDE):
#include "c8051f120.h"                 // SFR declarations
sfr16 RCAP4    = 0xca;                 // Timer4 capture/reload
sfr16 TMR4     = 0xcc;                 // Timer4
sfr16 DAC0     = 0xd2;                 // DAC0 data
sfr16 DAC1     = 0xd2;                 // DAC1 data
#define INTCLK       24500000          // Internal oscillator frequency in Hz
#define SYSCLK       49000000          // Output of PLL derived from (INTCLK*2)
#define SAMPLE_RATE_DAC 100000L        // DAC sampling rate in Hz
#define PHASE_PRECISION 65536          // range of phase accumulator
#define FREQUENCY 1000                 // Frequency of output waveform in Hz
unsigned int PHASE_ADD = FREQUENCY * PHASE_PRECISION / SAMPLE_RATE_DAC;
int code SINE_TABLE[256] = {
  0x0000, 0x0324, 0x0647, 0x096a, 0x0c8b, 0x0fab, 0x12c8, 0x15e2,
  0x18f8, 0x1c0b, 0x1f19, 0x2223, 0x2528, 0x2826, 0x2b1f, 0x2e11,
  0x30fb, 0x33de, 0x36ba, 0x398c, 0x3c56, 0x3f17, 0x41ce, 0x447a,
  0x471c, 0x49b4, 0x4c3f, 0x4ebf, 0x5133, 0x539b, 0x55f5, 0x5842,
  0x5a82, 0x5cb4, 0x5ed7, 0x60ec, 0x62f2, 0x64e8, 0x66cf, 0x68a6,
  0x6a6d, 0x6c24, 0x6dca, 0x6f5f, 0x70e2, 0x7255, 0x73b5, 0x7504,
  0x7641, 0x776c, 0x7884, 0x798a, 0x7a7d, 0x7b5d, 0x7c29, 0x7ce3,
  0x7d8a, 0x7e1d, 0x7e9d, 0x7f09, 0x7f62, 0x7fa7, 0x7fd8, 0x7ff6,
  0x7fff, 0x7ff6, 0x7fd8, 0x7fa7, 0x7f62, 0x7f09, 0x7e9d, 0x7e1d,
  0x7d8a, 0x7ce3, 0x7c29, 0x7b5d, 0x7a7d, 0x798a, 0x7884, 0x776c,
  0x7641, 0x7504, 0x73b5, 0x7255, 0x70e2, 0x6f5f, 0x6dca, 0x6c24,
  0x6a6d, 0x68a6, 0x66cf, 0x64e8, 0x62f2, 0x60ec, 0x5ed7, 0x5cb4,
  0x5a82, 0x5842, 0x55f5, 0x539b, 0x5133, 0x4ebf, 0x4c3f, 0x49b4,
  0x471c, 0x447a, 0x41ce, 0x3f17, 0x3c56, 0x398c, 0x36ba, 0x33de,
  0x30fb, 0x2e11, 0x2b1f, 0x2826, 0x2528, 0x2223, 0x1f19, 0x1c0b,
  0x18f8, 0x15e2, 0x12c8, 0x0fab, 0x0c8b, 0x096a, 0x0647, 0x0324,
  0x0000, 0xfcdc, 0xf9b9, 0xf696, 0xf375, 0xf055, 0xed38, 0xea1e,
  0xe708, 0xe3f5, 0xe0e7, 0xdddd, 0xdad8, 0xd7da, 0xd4e1, 0xd1ef,
  0xcf05, 0xcc22, 0xc946, 0xc674, 0xc3aa, 0xc0e9, 0xbe32, 0xbb86,
  0xb8e4, 0xb64c, 0xb3c1, 0xb141, 0xaecd, 0xac65, 0xaa0b, 0xa7be,
  0xa57e, 0xa34c, 0xa129, 0x9f14, 0x9d0e, 0x9b18, 0x9931, 0x975a,
  0x9593, 0x93dc, 0x9236, 0x90a1, 0x8f1e, 0x8dab, 0x8c4b, 0x8afc,
  0x89bf, 0x8894, 0x877c, 0x8676, 0x8583, 0x84a3, 0x83d7, 0x831d,
  0x8276, 0x81e3, 0x8163, 0x80f7, 0x809e, 0x8059, 0x8028, 0x800a,
  0x8000, 0x800a, 0x8028, 0x8059, 0x809e, 0x80f7, 0x8163, 0x81e3,
  0x8276, 0x831d, 0x83d7, 0x84a3, 0x8583, 0x8676, 0x877c, 0x8894,
  0x89bf, 0x8afc, 0x8c4b, 0x8dab, 0x8f1e, 0x90a1, 0x9236, 0x93dc,
  0x9593, 0x975a, 0x9931, 0x9b18, 0x9d0e, 0x9f14, 0xa129, 0xa34c,
  0xa57e, 0xa7be, 0xaa0b, 0xac65, 0xaecd, 0xb141, 0xb3c1, 0xb64c,
  0xb8e4, 0xbb86, 0xbe32, 0xc0e9, 0xc3aa, 0xc674, 0xc946, 0xcc22,
  0xcf05, 0xd1ef, 0xd4e1, 0xd7da, 0xdad8, 0xdddd, 0xe0e7, 0xe3f5,
  0xe708, 0xea1e, 0xed38, 0xf055, 0xf375, 0xf696, 0xf9b9, 0xfcdc,
// Function Prototypes
void main(void);
void OSCILLATOR_Init(void);
void DAC0_Init (void);
void DAC1_Init (void);
void TIMER4_Init(int counts);
void Set_DACs(void);
// MAIN Routine
void main (void)
  WDTCN = 0xde;                       // Disable watchdog timer
  WDTCN = 0xad;
  OSCILLATOR_Init ();                 // Initialize oscillator
  DAC0_Init ();                       // Initialize DAC0
  DAC1_Init ();                       // Initialize DAC1
  TIMER4_Init(SYSCLK/SAMPLE_RATE_DAC);// Initialize Timer4 to overflow
                                      // <SAMPLE_RATE_DAC> times per
                                      // second
  EA = 1;                             // Enable global interrupts
  while(1);
// Interrupt Service Routines
// TIMER4_ISR -- Wave Generator
// This ISR is called on Timer4 overflows.  Timer4 is set to auto-reload mode
// and is used to schedule the DAC output sample rate in this example.
// Note that the value that is written to DAC1 during this ISR call is
// actually transferred to DAC1 at the next Timer4 overflow.
void TIMER4_ISR (void) interrupt 16
  TF4 = 0;                            // Clear Timer4 overflow flag
  Set_DACs();
// Initialization Routines
// OSCILLATOR_Init
// Return Value : None
// Parameters   : None
// This function initializes the system clock to use the internal oscillator
// at 24.5 MHz multiplied by two using the PLL.
void OSCILLATOR_Init (void)
   int i = 0;
   SFRPAGE   = CONFIG_PAGE;
   OSCICN    = 0x83;
   CCH0CN    &= ~0x20;
   SFRPAGE   = LEGACY_PAGE;
   FLSCL     = 0x90;
   CCH0CN    |= 0x20;
   PLL0CN    |= 0x01;
   PLL0DIV   = 0x01;
   PLL0FLT   = 0x21;
   PLL0MUL   = 0x02;
   for (i = 0; i < 15; i++);  // Wait 5us for initialization
   PLL0CN    |= 0x02;
   while ((PLL0CN & 0x10) == 0);
   CLKSEL    = 0x02;
// DAC0_Init
// Configure DAC0 to update on Timer4 overflows and enable the the VREF buffer.
void DAC0_Init(void){
  char SFRPAGE_SAVE = SFRPAGE;        // Save Current SFR page
  SFRPAGE = DAC0_PAGE;
  DAC0CN = 0x94;                      // Enable DAC0 in left-justified mode
                                      // managed by Timer4 overflows
  REF0CN |= 0x03;                     // Enable the internal VREF (2.4v) and
                                      // the Bias Generator
  SFRPAGE = SFRPAGE_SAVE;             // Restore SFR page
// DAC1_Init
// Configure DAC1 to update on Timer4 overflows and enable the the VREF buffer.
void DAC1_Init(void){
  SFRPAGE = DAC1_PAGE;
  DAC1CN = 0x94;                      // Enable DAC1 in left-justified mode
// TIMER4_Init
// Parameters   :
//   1)  int counts - calculated Timer overflow rate
//                    range is positive range of integer: 0 to 32767
// Configure Timer4 to auto-reload at interval specified by <counts> using
// SYSCLK as its time base.
void TIMER4_Init (int counts)
  SFRPAGE = TMR4_PAGE;
  TMR4CN = 0x00;                      // Stop Timer4; Clear overflow flag (TF4);
                                      // Set to Auto-Reload Mode
  TMR4CF = 0x08;                      // Configure Timer4 to increment;
                                      // Timer4 counts SYSCLKs
  RCAP4 = -counts;                    // Set reload value
  TMR4 = RCAP4;                       // Initialzie Timer4 to reload value
  EIE2 |= 0x04;                       // Enable Timer4 interrupts
  TR4 = 1;                            // Start Timer4
// Set_DACs
// Calculates the update values for the two DACs using SINE_TABLE.  The DACs
// will actually be updated upon the next Timer4 interrupt.  Until that time,
// the DACs will hold their current value.
void Set_DACs(void)
  static unsigned phase_acc = 0;      // Holds phase accumulator
  int SIN_temp, COS_temp;             // Temporary 16-bit variables
  unsigned char index;                // Index into SINE table
  phase_acc += PHASE_ADD;             // Increment phase accumulator
  index = phase_acc >> 8;
  SIN_temp = SINE_TABLE[index];       // Read the table value
  index += 64;                        // 90 degree phase shift
  COS_temp = SINE_TABLE[index];
  // Add a DC bias to change the the rails from a bipolar (-32768 to 32767)
  // to unipolar (0 to 65535)
  // Note: the XOR with 0x8000 translates the bipolar quantity into
  // a unipolar quantity.
  //DAC0 = 0x8000 ^ SIN_temp;           // Write to DAC0
  DAC0 = SIN_temp;           // Write to DAC0
  DAC1 = 0x8000 ^ COS_temp;           // Write to DAC1
// End Of File
между DAC1 и землёй 310кОм в рабочем режиме. Нагрузкой является щуп осцилографа, у него входное сопротивление 1МОм.
Меня просто смущает то, что код из примера проработал всего 1 раз, показал красивый синус, в предпоследний раз он показал мне кривой меандр, с фронтаму пропущеными буд-то через ФНЧ (с красивым переходным процессом), и после этого уже всё, кердык, вижу только шув в 250мВ.
p.s. В режиме ПРОГРАМИРОВАНИЯ дебаггером, на этом пине появляется 0.8В, и держится до включения процессора (из под компилятора нажимаем на Run)
Изменено пользователем krant
Всему виной моя невнимательность. Оказывается для ЦАП именно 8051F120 нужно обязательно ВНЕШНЕЕ питание , которое подключается к VREFD. Подключил - всё заработало.
Вернусь к теме. Когда собирал в корпус, оторвал ножку на ЦАП0. ну думаю не беда, перекину на ЦАП1, не тут то было, почему-то постоянный уровень ЦАП1 держать отказывается.
Посмотрел по ДЩ, инициализаируются оба ЦАПА абсолютно идентично, Только почему-то один не держит постоянку, это чего такое весёлое ?
Генерировал Пилу (5Гц), спады по экспоненте, как будто конденсатор разряжается
p.s. проблема разрешилась перепайкой контактного провода, введением заголовка SFRPAGE=DAC1_PAGE перед обьявлением значение регистров DA1L && DA1H. Всё заработало :)
