Sign in to follow this
Guest Anna
Проблемы С Памятью
Guest Anna
Здравствуйте.
не могли бы Вы подсказать, как посмотреть,где именно он пишет в некорректную облать памяти.
#include <stdio.h>
#include <stdlib.h>
#include <avr/io.h>
#include <avr/pgmspace.h>
#include <avr/eeprom.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#include <inttypes.h>
#include "lcd_lib.h"
//define R2R port
#define R2RPORT PORTA
#define R2RDDR DDRA
//define button port and dedicated pins
#define BPORT PORTD
#define BPIN PIND
#define BDDR DDRD
#define DOWN 0//PORTD
#define LEFT 1//PORTD
#define START 2//PORTD
#define RIGHT 3//PORTD
#define UP 4//PORTD
//Define Highs Speed (HS) signal output
#define HSDDR DDRD
#define HSPORT PORTD
#define HS 5//PD5
//define eeprom addresses
#define EEMODE 0
#define EEFREQ1 1
#define EEFREQ2 2
#define EEFREQ3 3
#define EEDUTY 4
#define EEINIT E2END
#define RESOLUTION 0.095367431640625
#define MINFREQ 0//minimum frequency
#define MAXFREQ 65534//maximum DDS frequency
#define MN_No 5// number of menu items
//function prototypes
void delay1s(void);
void Timer2_Init(void);
void Timer2_Start(void);
void Timer2_Stop(void);
void Main_Init(void);
void Menu_Update(uint8_t);
void Freq_Update(void);
void Timer1_Start(uint8_t);
void Timer1_Stop(void);
void static inline Signal_OUT(const uint8_t *, uint8_t, uint8_t, uint8_t);
//adjust LCDsendChar() function for strema
static int LCDsendstream(char c, FILE *stream);
//----set output stream to LCD-------
static FILE lcd_str = FDEV_SETUP_STREAM(LCDsendstream, NULL, _FDEV_SETUP_WRITE);
//Menu Strings in flash
//menu 1
const uint8_t MN100[] PROGMEM="	 exp	 \0";
//Array of pointers to menu strings stored in flash
const uint8_t *MENU[]={
MN100 //menu 1 string
//various LCD strings
const uint8_t MNON[] PROGMEM="ON \0";//ON
const uint8_t MNOFF[] PROGMEM="OFF\0";//OFF
const uint8_t NA[] PROGMEM="	 NA	 \0";//Clear freq value
const uint8_t CLR[] PROGMEM="			 \0";//Clear freq value
const uint8_t MNClrfreq[] PROGMEM="		 \0";//Clear freq value
const uint8_t TOEEPROM[] PROGMEM="Saving Settings\0";//saving to eeprom
const uint8_t ONEMHZ[] PROGMEM="	 1MHz \0";//saving to eeprom
const uint8_t welcomeln1[] PROGMEM="AVR SIGNAL\0";
const uint8_t RND[] PROGMEM=" Random\0";
//variables to control TDA7313
struct signal{
volatile uint8_t mode; //signal
volatile uint8_t fr1; //Frequency [0..7]
volatile uint8_t fr2; //Frequency [8..15]
volatile int8_t fr3; //Frequency [16..31]
volatile uint32_t freq; //frequency value
volatile uint8_t flag; //if "0"generator is OFF, "1" - ON
volatile uint32_t acc; //accumulator
volatile uint8_t ON;
volatile uint8_t HSfreq; //high speed frequency [1...4Mhz]
volatile uint32_t deltafreq; //frequency step value
}SG;
//define signals
const uint8_t expwave[] __attribute__ ((section (".MySection1")))= //exp wave
0x00,0x09,0x12,0x1B,0x23,0x2c,0x34,0x3c,0x43,0x4B,0x52,0x59,0x60,0x67,0x6E,0x74,
0x7A,0x80,0x86,0x8C,0x91,0x97,0x9C,0xA1,0xA6,0xAA,0xAF,0xB3,0xB8,0xBC,0xC0,0xC3,
0xC7,0xCB,0xCE,0xD1,0xD4,0xD7,0xDA,0xDD,0xE0,0xE2,0xE4,0xE7,0xE9,0xEB,0xED,0xEF,
0xF0,0xF2,0xF3,0xF5,0xF6,0xF7,0xF8,0xF9,0xFA,0xFB,0xFC,0xFD,0xFE,0xFE,0xFE,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfe,0xfe,0xfd,0xfd,0xfc,0xfc,0xfb,0xfa,0xfa,
0xf9,0xf8,0xf7,0xf6,0xf5,0xf4,0xf3,0xf2,0xf1,0xf0,0xee,0xed,0xec,0xea,0xe9,0xe8,
0xe6,0xe5,0xe3,0xe2,0xe0,0xdf,0xdd,0xdb,0xda,0xd8,0xd6,0xd5,0xd3,0xd1,0xd0,0xce,
0xcc,0xca,0xc8,0xc7,0xc5,0xc3,0xc1,0xbf,0xbd,0xbb,0xba,0xb8,0xb6,0xb4,0xb2,0xb0,
0xae,0xac,0xaa,0xa8,0xa6,0xa4,0xa2,0xa1,0x9f,0x9d,0x9b,0x99,0x97,0x95,0x93,0x91,
0x8f,0x8e,0x8c,0x8a,0x88,0x86,0x84,0x82,0x80,0x7e,0x7d,0x7b,0x79,0x77,0x76,0x74,
0x72,0x70,0x6e,0x6d,0x6b,0x69,0x68,0x66,0x64,0x62,0x61,0x5f,0x5d,0x5c,0x5a,0x59,
0x57,0x55,0x54,0x52,0x51,0x4f,0x4e,0x4c,0x4b,0x49,0x48,0x46,0x45,0x44,0x42,0x41,
0x3f,0x3e,0x3d,0x3b,0x3a,0x39,0x37,0x36,0x35,0x34,0x31,0x30,0x2f,0x2e,0x2d,0x2b,
0x2a,0x29,0x29,0x28,0x27,0x26,0x25,0x24,0x23,0x22,0x21,0x20,0x1f,0x1e,0x1d,0x1c,
0x1b,0x1a,0x1a,0x19,0x18,0x17,0x16,0x15,0x15,0x14,0x13,0x12,0x11,0x11,0x10,0x0f,
0x0f,0x0e,0x0d,0x0d,0x0c,0x0b,0x0b,0x0a,0x09,0x09,0x08,0x08,0x07,0x07,0x06,0x06,
//array of pointers to signal tables
const uint8_t *SIGNALS[] ={
expwave
//adjust LCD stream fuinction to use with printf()
static int LCDsendstream(char c , FILE *stream)
LCDsendChar(c);
return 0;
//delay 1s
void delay1s(void)
uint8_t i;
for(i=0;i<100;i++)
_delay_ms(10);
//initialize Timer2 (used for button reading)
TCNT2=0x00;
sei();
//start timer2
TCCR2|=(1<<CS22)|(1<<CS21); //prescaller 256 ~122 interrupts/s
TIMSK|=(1<<TOV2);//Enable Timer0 Overflow interrupts
//stop timer 2
TCCR0&=~((1<<CS22)|(1<<CS21)); //Stop timer0
TIMSK&=~(1<<TOV2);//Disable Timer0 Overflow interrupts
//Initial menu
//show initial signal and frequency
//generator is off
void Menu_Update(uint8_t on)
LCDclr();
CopyStringtoLCD(MENU[(SG.mode)], 0, 0 );
LCDGotoXY(0, 1);
if (SG.mode==6)
CopyStringtoLCD(CLR, 0, 1 );
LCDGotoXY(0, 1);
printf(" %5uHz", (uint16_t)SG.deltafreq);
if (SG.mode==7)
CopyStringtoLCD(RND, 0, 1 );
if (SG.mode==8)
LCDGotoXY(0, 1);
printf(" %5uMHz", SG.HSfreq);
if((SG.mode==0)||(SG.mode==1)||(SG.mode==2)||(SG.mode==3)||(SG.mode==4)||(SG.mode==5))
LCDGotoXY(0, 1);
printf(" %5uHz", (uint16_t)SG.freq);
if (SG.mode!=6)
if(on==1)
CopyStringtoLCD(MNON, 13, 1 );
else
CopyStringtoLCD(MNOFF, 13, 1 );
//update frequency value on LCD menu - more smooth display
if (SG.mode==6)
LCDGotoXY(0, 1);
if (SG.mode==8)
//if HS signal
LCDGotoXY(0, 1);
LCDGotoXY(0, 1);
//External interrupt0 service routine
//used to stop DDS depending on active menu
//any generator is stopped by setting flag value to 0
//DDs generator which is inline ASM is stopped by setting
//CPHA bit in SPCR register
ISR(INT0_vect)
SG.flag=0;//set flag to stop generator
SPCR|=(1<<CPHA);//using CPHA bit as stop mark
//CopyStringtoLCD(MNOFF, 13, 1 );
SG.ON=0;//set off in LCD menu
loop_until_bit_is_set(BPIN, START);//wait for button release
//timer overflow interrupt service tourine
//checks all button status and if button is pressed
//value is updated
ISR(TIMER2_OVF_vect)
if (bit_is_clear(BPIN, UP))
//Button UP increments value which selects previous signal mode
//if first mode is reached - jumps to last
if (SG.mode==0)
SG.mode=MN_No-1;
else
SG.mode--;
//Display menu item
Menu_Update(SG.ON);
loop_until_bit_is_set(BPIN, UP);
if (bit_is_clear(BPIN, DOWN))
//Button Down decrements value which selects next signal mode
//if last mode is reached - jumps to first
if (SG.mode<(MN_No-1))
SG.mode++;
else
SG.mode=0;
//Display menu item
Menu_Update(SG.ON);
loop_until_bit_is_set(BPIN, DOWN);
if (bit_is_clear(BPIN, RIGHT))
//frequency increment
if(SG.mode==6)
if(SG.deltafreq==10000)
SG.deltafreq=1;
else
SG.deltafreq=(SG.deltafreq*10);
Freq_Update();
loop_until_bit_is_set(BPIN, RIGHT);
if (SG.mode==8)
//ifhigh speed signal
if(SG.HSfreq==8)
SG.HSfreq=1;
else
SG.HSfreq=(SG.HSfreq<<1);
Freq_Update();
if ((0xFFFF-SG.freq)>=SG.deltafreq)
 SG.freq+=SG.deltafreq;
Freq_Update();
uint8_t ii=0;
//press button and wait for long press (~0.5s)
do{
 _delay_ms(2);
 ii++;
}while((bit_is_clear(BPIN, RIGHT))&&(ii<=250));//wait for button release
if(ii>=250)
 do{
 Freq_Update();
 }while(bit_is_clear(BPIN, RIGHT));//wait for button release
if (bit_is_clear(BPIN, LEFT))
//frequency decrement
if(SG.mode==6)
if(SG.deltafreq==1)
SG.deltafreq=10000;
else
SG.deltafreq=(SG.deltafreq/10);
Freq_Update();
loop_until_bit_is_set(BPIN, LEFT);
if (SG.mode==8)
if(SG.HSfreq==1)
SG.HSfreq=8;
else
SG.HSfreq=(SG.HSfreq>>1);
Freq_Update();
if ((SG.mode==0)||(SG.mode==1)||(SG.mode==2)||(SG.mode==3)||(SG.mode==4)||(SG.mode==5))
if (SG.freq>=SG.deltafreq)
 SG.freq-=SG.deltafreq;
Freq_Update();
uint8_t ii=0;
do{
 _delay_ms(2);
 ii++;
}while((bit_is_clear(BPIN, LEFT))&&(ii<=250));//wait for button release
if(ii>=250)
 do{
 Freq_Update();
 }while(bit_is_clear(BPIN, LEFT));//wait for button release
if (bit_is_clear(BPIN, START))
if(SG.mode!=6)
//saving last configuration
SG.fr1=(uint8_t)(SG.freq);
SG.fr2=(uint8_t)(SG.freq>>8);
SG.fr3=(uint8_t)(SG.freq>>16);
if (eeprom_read_byte((uint8_t*)EEMODE)!=SG.mode) eeprom_write_byte((uint8_t*)EEMODE,SG.mode);
if (eeprom_read_byte((uint8_t*)EEFREQ1)!=SG.fr1) eeprom_write_byte((uint8_t*)EEFREQ1,SG.fr1);
if (eeprom_read_byte((uint8_t*)EEFREQ2)!=SG.fr2) eeprom_write_byte((uint8_t*)EEFREQ2,SG.fr2);
if (eeprom_read_byte((uint8_t*)EEFREQ3)!=SG.fr3) eeprom_write_byte((uint8_t*)EEFREQ3,SG.fr3);
//Calculate frequency value from restored EEPROM values
SG.freq=(((uint32_t)(SG.fr3)<<16)|((uint32_t)(SG.fr2)<<8)|((uint32_t)(SG.fr1)));
//calculate accumulator value
SG.acc=SG.freq/RESOLUTION;
SG.flag=1;//set flag to start generator
SG.ON=1;//set ON on LCD menu
SPCR&=~(1<<CPHA);//clear CPHA bit in SPCR register to allow DDS
//Stop timer2 - menu inactive
Timer2_Stop();
//display ON on LCD
Menu_Update(SG.ON);
/*DDS signal generation function
Original idea is taken from
http://www.myplace.nu/avr/minidds/index.htm
small modification is made - added additional command which
checks if CPHA bit is set in SPCR register if yes - exit function
void static inline Signal_OUT(const uint8_t *signal, uint8_t ad2, uint8_t ad1, uint8_t ad0)
asm volatile( "eor r18, r18 ;r18<-0" "\n\t"
"eor r19, r19 ;r19<-0" "\n\t"
"1:"	 "\n\t"
"add r18, %0 ;1 cycle" "\n\t"
"adc r19, %1 ;1 cycle" "\n\t"
"adc %A3, %2 ;1 cycle" "\n\t"
"lpm ;3 cycles" "\n\t"
"out %4, __tmp_reg__ ;1 cycle" "\n\t"
"sbis %5, 2 ;1 cycle if no skip" "\n\t"
"rjmp 1b ;2 cycles. Total 10 cycles" "\n\t"
:"r" (ad0),"r" (ad1),"r" (ad2),"e" (signal),"I" (_SFR_IO_ADDR(PORTA)), "I" (_SFR_IO_ADDR(SPCR))
:"r18", "r19"
void Timer1_Start(uint8_t FMHz)
switch(FMHz){
case 1:
//start high speed (1MHz) signal
OCR1A=7;
break;
case 2:
OCR1A=3;//2MHz
break;
case 4:
OCR1A=1;//4MHz
break;
case 8:
OCR1A=0;//8MHz
break;
default:
OCR1A=7;//defauls 1MHz
break;}
//Output compare toggles OC1A pin
TCCR1A=0x40;
//start timer without prescaler
TCCR1B=0b00001001;
TCCR1B=0x00;//timer off
//main init function
//stderr = &lcd_str;
stdout = &lcd_str;
//--------init LCD----------
LCDinit();
LCDclr();
LCDcursorOFF();
//-------EEPROM initial values----------
if (eeprom_read_byte((uint8_t*)EEINIT)!='T')
eeprom_write_byte((uint8_t*)EEMODE,0x00);//initial mode 0 – OUT~~~~;
eeprom_write_byte((uint8_t*)EEFREQ1,0xE8);//initial frequency 1kHz
eeprom_write_byte((uint8_t*)EEFREQ2,0x03);
eeprom_write_byte((uint8_t*)EEFREQ3,0x00);
eeprom_write_byte((uint8_t*)EEINIT,'T');//marks once that eeprom init is done
//once this procedure is held, no more initialization is performed
//------restore last saved values from EEPROM------
SG.mode=eeprom_read_byte((uint8_t*)EEMODE);
SG.fr1=eeprom_read_byte((uint8_t*)EEFREQ1);
SG.fr2=eeprom_read_byte((uint8_t*)EEFREQ2);
SG.fr3=eeprom_read_byte((uint8_t*)EEFREQ3);
SG.flag=0;
//default 1MHz HS signal freq
SG.HSfreq=1;
SG.deltafreq=100;
//------------init DDS output-----------
R2RPORT=0x00;//set initial zero values
R2RDDR=0xFF;//set A port as output
//-------------set ports pins for buttons----------
BDDR&=~(_BV(START)|_BV(UP)|_BV(DOWN)|_BV(RIGHT)|_BV(LEFT));
BPORT|=(_BV(START)|_BV(UP)|_BV(DOWN)|_BV(RIGHT)|_BV(LEFT));
//---------set ports pins for HS output---------
HSDDR|=_BV(HS);//configure as output
//-----------Menu init--------------
SG.ON=0;//default signal is off
Menu_Update(SG.ON);
//-----------Timer Init-------------
Timer2_Init();
//Start Timer with overflow interrupts
Timer2_Start();
int main(void)
//Initialize
Main_Init();
while(1)//infinite loop
if (SG.flag==1)
GICR|=(1<<INT0);//set external interrupt to enable stop
if (SG.mode==7)
//Noise
do
R2RPORT=rand();
}while(SG.flag==1);
//set signal level to 0
R2RPORT=0x00;
//display generator OFF
Menu_Update(SG.ON);
//stop external interrupt
GICR&=~(1<<INT0);
//start timer menu active
Timer2_Start();
/* else if (SG.mode==6)
//freq step
while((SG.flag==1))
//not implemented
CopyStringtoLCD(NA, 0, 1 );
R2RPORT=0x00;
Menu_Update(SG.ON);
GICR&=~(1<<INT0);//|(1<<INT1);//stop external interrupt
Timer2_Start();
else if (SG.mode==8)
//High speed signal
Timer1_Start(SG.HSfreq);
while((SG.flag==1))
//not implemented
Timer1_Stop();//timer off
//set HS pin to LOW
HSPORT&=~(1<<HS);
Menu_Update(SG.ON);
Timer2_Start();
else
//start DDS
Signal_OUT(SIGNALS[sG.mode],
 (uint8_t)((uint32_t)SG.acc>>16),
 (uint8_t)((uint32_t)SG.acc>>8),
 (uint8_t)SG.acc);
R2RPORT=0x00;
Menu_Update(SG.ON);
Timer2_Start();
return 0;
ошибка section .MySection1 loaded at [000016ce,000017cd] overlaps section .data loaded at [000016ce,000016f5]
Подскажите пожалуйста,где посмотреть, по какой причине он так записывает в память.
Гуглила, ничего толкого не нашла.
Заранее спасибо.
Безмостовые ККМ для 99% КПД!
Схема коррекции коэффициента мощности (ККМ) на основе так называемого «тотемного столба» (Totem Pole) обладает минимально возможными потерями и потенциально может обеспечить самые жесткие требования к энергоэффективности источников питания. Компания Wolfspeed представляет референсную разработку – плату ККМ CRD-02AD065N на базе собственных карбид-кремниевых MOSFET и диодов с наилучшими в отрасли характеристиками.
Предположительно не хватает памяти. Для эксперимента удалите две трети данных из mysection, и посмотреть, исчезнет ли ошибка или нет. Могут быть другие причины. Разумеется с удалённой частью массива даже если скомпилируется, работать неизвестно как будет.
Ещё как вариант, перекрытие блоков:
секция MySection1, загруженная в адреса 16ce-17cd, перекрывает секцию .data, загруженную на адреса 16се-16f5.
MySection1 вот здесь
0xC7,0xCB,0xCE,0xD1,0xD4,0xD7,0xDA,0xDD,0xE0,0xE2,0xE4,0xE7,0xE9,0xEB,0xED,0xEF,.............
А секцию .data не видать что-то в коде.
Edited by tcoder
Гибридные IGBT - сила Si и SiC в одном корпусе!
Компания Infineon представила новые гибридные IGBT-транзисторы на 650 В, которые сочетают в себе преимущества технологий TRENCHSTOP и CoolSiC. Использование SiC-диода Шоттки позволяет значительно расширить возможности IGBT и снизить уровень энергии, необходимой для включения транзистора (Eon), а также уменьшить потери на переключение.
Секция .data является стандартной судя по всему. Значит проблема скорее всего с объявлением секции .MySection1, ибо адреса перекрываются.... может есть смысл её на .data переименовать? Как вариант... Тогда весь блок данных будет по идее в .data загружен, конфликтовать будет нечему.
Вебинар «Параметры выше, цена ниже. Обновление в линейке AC/DC- и DC/DC-преобразователей MORNSUN» (26.01.2021)
Приглашаем 26 января на бесплатный вебинар, посвящённый преимуществам и отличиям новых источников питания и DC/DC-преобразователей Mornsun. На вебинаре будут рассмотрены изолированные и неизолированные DC/DC-преобразователи последнего, четвертого, поколения (R4) и компактные модульные источники питания второго и третьего поколений (семейства LS/R3 и LD/R2) на плату. Рассмотрим новую группу продукции – встраиваемые источники питания в кожухе.
Guest Anna
вариант неплохой, но к сожалению ошибка ignoring changed section attributes for .data говорит что нельзя туда записывать ту матрицу
Guest Anna
удалить часть данных не вариант, а то что проблемы связанны с нехваткой памяти, это да,если ставить при компиляции другой МК,то там уже ошибки лишь с нераспознаванием пары команд. Но данный код заточен под схему именно с atmega16. сейчас он конечно изменен, но основное осталось нетронутым
Guest Anna
а под сполер что убрать не судьба на всю страницу растянул
Спасибо за замечание, учту в следующий раз
А если вот эту часть совсем удалить?
Может кто поопытнее ответит. Кто-то же должен был с этим столкнуться. Ещё желательно строку с ошибкой целиком копировать, а не только её смысловую часть.
*просто непонятно, почему для этого блока данных используется отдельная секция памяти, декларации которой кстати не видать в коде. Насколько мне известно, что атрибуту section нужно подавать заранее задекларированную секцию. И собственно использование самого этого массива в коде тоже не видать. Всё либо в инклудах...
Как вариант, попробуйте изучить неизменённый проект, там же всё рабочее, как я понимаю)
Edited by tcoder
Guest Anna
Спасибо,это помогло, но вот корректно ли это. Будем испытывать, спасибо Вам.
Испытайте. Разгадка заключается только в том, почему это в отдельную секцию было вынесено, и какой области памяти она собственно относится.... насколько мне известно, там не к каждой области можно идентично обращаться. Но судя по всему всё это должно к SRAM относится (раз конфликт возник). По идее должно прокатить. Отпишитесь о результатах испытаний по возможности. :)
Guest Anna
в отделюную секцию вынесено наверное,для простоты работы в дальнейшем, так вроде отработало нормально и в файле с map расширением все отобразилось и записалось после уже секции .data
    • Помогите опознать транзистор, поиск в интернете не дал результатов. Маркировка N65KAE.
    • Возможно что еще проблема в библиотеках. Какая-то из них разрослась в новой версии и места уже не хватает.
    • Это всё-таки не техническая наука. Наверное, ближе к формальной, как и математика. Я разговаривал с математиком. Он кроме математики больше ничем не интересуется. Но это было ещё до вброса о лунной афере. Химики тоже нифига ничего не знают ни о космосе, ни о Аполлоне, хотя это естественная наука.  А вот люди инженерных профессий, если даже ничего и  не слышали о лунных фальсификациях, то очень быстро ориентируются в предоставленной информации противоборствующих сторон и разоблачают сторонников лунной аферы. Я для этого прикидывался дилетантом и выкладывал самые распространенные "факты" обмана, с просьбой разобраться и разьяснить положение дел. Как правило, почти никто не вникал в тонкости предоставленной информации от НАСА. Все довольно быстро заостряли своё внимание и замечали фальшивки из длинного списка  "фактов обмана" и после двух - трех разоблаченных фейковых доводов, остальные уже не рассматривали, вынося окончательный вердикт. ))  Среди астрономов вообще нет "немогликов". И нет таких, кто бы не знал о полете Аполлона с высадкой на Луну. Ну это и понятно, почему. Я утверждал именно о вранье, а не о заблуждении.  А какое может быть у наших  специалистов заблуждение по Аполлону??? Это люди, далекие от космонавтики могут в чем то заблуждаться, а у наших академиков и докторов подобные заблуждения исключены. Точно!  Это философское словечко встречается ещё и в математике.   Да какая разница, имела или не имела редакционная коллегия полномочий выступать авторами ?????  Ты хочешь сказать, что в этой книге, отредактированной академиками и докторами, описана конструкция Сатурна,  Аполлона, которые не летали на Луну и ровера, который не бороздил просторов её поверхности??    Остальное, чистой воды демагогия. Это не моё. В книге имеются все ссылки на литературу.
    • Мдя... ИИ не обманешь. Любимый вами Яндекс видимо хорошо вас изучил и выдаёт то, что вам действительно надо. Смиритесь и не дёргайтесь.
    • Питать сетевую ламповую радиолу от батареек - глупость и утопия. Так как аутентичный внешний вид уже похерен  (), то никакой антикварной ценности аппарат не представляет. Поэтому предлагаю следующее: Найти на месте специалиста с руками и головой, который удалит из неё ламповое шасси и внедрит вместо него схему современного тюнера с усилителем, которая потребляет в десятки раз меньше энергии, да и ловит радиостанции куда лучше. Органы управления и переднюю панель при этом сохранить. Заодно и внутри куча места освободится, хоть автомобильный аккумулятор можно будет засунуть.
  • 4-х контактный переключатель, 2 шт.
    • By Обычный Человек
      Микроконтроллер ATmega328p, внешний кварц 16МГц. Компилятор avr-gcc с оптимизацией O1
      Написал код для управление шаговым двигателем. Работает так: требуемая скорость задается переменной STP1_ReqSpeed, дальше с частотой 100Гц срабатывает таймер TIM0, который высчитывает с какой частотой надо подавать сигналы на вход шагового драйвера. TIM1 работает в режиме частотно импульсной модуляции и по прерыванию меняет значение пина на противоположное.
      Управление работает, скорость регулируется, но по какой то причине случаются пропуски шагов. Чаще всего во время ускорения. Количество пропусков от 0 до 4, обычно 2-3, длятся 32мс.
      Из кода вырезал неиспользуемое. Заменить прерывания на аппаратный ШИМ возможности нет. Как убрать эти пропуски?
      Осциллограммы:
    • By Артур Измаилов
      1.Создать схему в которой два светодиоды загораются в следующей последовательности:  1 и 2, 2 и 3, 3 и 4, …, 15 и 16, 1 и 2 и т.д. (т.е. создается эффект движения двух светодиодов).
      Дано условие выше. Решение задачи нужно представить в Proteus. Код для программирования пишу в AtmelStudio 7. Схему собрал в Proteus. Вывел 16 светодиодов через 2 порта (Порт B и Порт D). МК использовал ATMEGA 8 вариации в корпусе DIP с 28 ножками (SPDIL28).
      До этого смог написать схему, чтобы работали светодиоды в последовательности 1.2.3.4.5....16.1.2.3.4 и тд. Делал через оператор FOR. Однако с этим кодом начались проблемы. Помогите пожалуйста.
      Нижу представил изображение кода.
      Заранее спасибо!
    • By Lisitsin
      Собираем компьютер ZX Spectrum на микроконтроллерах AVR своими руками!
      Проект открытый, все исходники и информация проекта по ссылке
      https://yadi.sk/d/9S2S0ZmNqsLykQ
      Проект печатной платы выполнен в PCAD-2006, программное обеспечение разработано в AVRStudio  4b401
      Здесь отвечу на все возникающие вопросы и помогу со сборкой и запуском
    • By O5-14
      По поводу этого https://cxem.net/mc/mc220.php девайса. Как напоминалка паролей думал сделать, только в моих краях 1604 нету( Под wg12864 нет случаем модификации ?
      И что такое значит "Текстовые файлы должны быть в обычном txt формате и без форматирования" - первая часть понятна. А без форматирования ? Одна длинная строка ? Пробелы-то хоть можно ?
    • By Karl-Ieronim
      Коллеги, всем привет.
      Увидел вот такой проект.
      Несмотря на явную привлекательность что-то совсем мало повторивших.
      Может кто-то из завсегдатаев форума делал этот проект?
      Интересует ваше мнение: хочу повторить, но не силен в программировании, поэтому беспокоюсь на счёт подводных камней с которыми не смогу справиться.
