Велосипедный спидометр на Arduino
я немного переделал код для км/ч, сейчас не могу проверить, правильно ли получилось?
//bike speedometer
//by Amanda Ghassaei 2012
//http://www.instructables.com/id/Arduino-Bike-Speedometer/
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 3 of the License, or
* (at your option) any later version.
//outputs speed of bicycle to LCD
//calculations
//tire radius ~ 13.5 inches
//circumference = pi*2*r =~85 inches
//max speed of 35mph =~ 616inches/second
//max rps =~7.25
#define reed A0//pin connected to read switch
#include <LiquidCrystal.h>//установил обычный дисплей
LiquidCrystal lcd(12, 11, 5, 4, 3, 6);
//storage variables
int reedVal;
long timer = 0;// time between one full rotation (in ms)
float mph = 0.00;
float circumference;
boolean backlight;
int maxReedCounter = 100;//min time (in ms) of one rotation (for debouncing)
int reedCounter;
void setup(){
reedCounter = maxReedCounter;
circumference = 2095; //здесь явно задал окружность
pinMode(1,OUTPUT);//tx
pinMode(2,OUTPUT);//backlight switch
pinMode(reed, INPUT);
lcd.begin(16, 2);
Serial.write(12);//clear
// TIMER SETUP- the timer interrupt allows preceise timed measurements of the reed switch
//for mor info about configuration of arduino timers see http://arduino.cc/playground/Code/Timer1
cli();//stop interrupts
//set timer1 interrupt at 1kHz
TCCR1A = 0;// set entire TCCR1A register to 0
TCCR1B = 0;// same for TCCR1B
TCNT1 = 0;
// set timer count for 1khz increments
OCR1A = 1999;// = (1/1000) / ((1/(16*10^6))*8) - 1
// turn on CTC mode
TCCR1B |= (1 << WGM12);
// Set CS11 bit for 8 prescaler
TCCR1B |= (1 << CS11);
// enable timer compare interrupt
TIMSK1 |= (1 << OCIE1A);
sei();//allow interrupts
//END TIMER SETUP
ISR(TIMER1_COMPA_vect) {//Interrupt at freq of 1kHz to measure reed switch
reedVal = digitalRead(reed);//get val of A0
if (reedVal){//if reed switch is closed
if (reedCounter == 0){//min time between pulses has passed
mph = (3.6*float(circumference))/float(timer);//calculate miles per hour // и переделал формулу
timer = 0;//reset timer
reedCounter = maxReedCounter;//reset reedCounter
else{
if (reedCounter > 0){//don't let reedCounter go negative
reedCounter -= 1;//decrement reedCounter
else{//if reed switch is open
if (timer > 2000){
mph = 0;//if no new pulses from reed switch- tire is still, set mph to 0
else{
timer += 1;//increment timer
void displayMPH(){
lcd.clear();//clear
lcd.print("Speed =");
lcd.setCursor(0, 1);
lcd.print(mph);
//Serial.write(" MPH ");
//Serial.write("0.00 MPH ");
void loop(){
//print mph once a second
displayMPH();
delay(1000);
как можно добавить одометр?
версия номер два
//bike speedometer
//<a href="http://www.instructables.com/id/Arduino-Bike-Speedometer/" rel="nofollow">http://www.instructables.com/id/Arduino-Bike-Speedometer/</a>
//calculations
//max rps =~7.25
//storage variables
int reedVal;
int odo;//количество оборотов колеса
float mph = 0.00;
boolean backlight;
char vivod;
int reedCounter;
void setup(){
odo=0;
lcd.begin(16, 2);
//for mor info about configuration of arduino timers see <a href="http://arduino.cc/playground/Code/Timer1" title="http://arduino.cc/playground/Code/Timer1" rel="nofollow">http://arduino.cc/playground/Code/Timer1</a>
TCNT1 = 0;
// turn on CTC mode
//END TIMER SETUP
odo++;
else{
if (timer > 2000){
else{
void displayMPH(){
lcd.clear();//clear
lcd.print("Speed ");
lcd.setCursor(6, 0);
lcd.print(mph);
lcd.print(String(byte(odo*circumference/1000000))+"km "+int(odo*circumference/1000)+"m");
/* lcd.setCursor(9, 1);
lcd.print(int(odo*circumference/1000));*/
void loop(){
displayMPH();
delay(1000);
