Stm32f4 adc+dma+tim1
LoKeR
Есть исходная прошивка устройства, там один канал в ADC_TripleMode_Interl необходимо заменить этот режим на два обычных каналов (медленных). В случай замене адреса #define CDR_ADDRESS ((uint32_t)0x40012308) в результате ничего не выдает.
Вот исходник
void initialization_ADC(void) {
GPIO_InitTypeDef        GPIO_InitStructure;
ADC_InitTypeDef         ADC_InitStructure;
ADC_CommonInitTypeDef   ADC_CommonInitStructure;
DMA_InitTypeDef         DMA_InitStructure;
    ADC_StructInit(&ADC_InitStructure);
    ADC_CommonStructInit(&ADC_CommonInitStructure);
    DMA_StructInit(&DMA_InitStructure);
    /* Configure PB11, PB15 in pushpull mode */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_15;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
    /* Configure PB1, PB8 in output mode */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_8;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
#ifdef __ILX_751B
    GPIOB->BSRRH = GPIO_Pin_1;  // Set High ROG
    GPIOB->BSRRH = GPIO_Pin_8;  // Set High SHUT
#endif
#ifdef __ILX_1412S
    GPIOB->BSRRL = GPIO_Pin_1;  // Set Low HOLD
    GPIOB->BSRRL = GPIO_Pin_8;  // Set Low SI1
#endif
/*               ADCs interface clock and pin configuration                   */
// === DMA =====================================================================
    /* Enable peripheral clocks */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_ADC2 | RCC_APB2Periph_ADC3, ENABLE);
    /* Enable peripheral clocks *************************************************/
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 , ENABLE);
    /* Configure ADC Channel N pin as analog input *****************************/
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    /* DMA2 Stream0 channel0 configuration **************************************/
    DMA_InitStructure.DMA_Channel = DMA_Channel_0;
    DMA_InitStructure.DMA_PeripheralBaseAddr = CDR_ADDRESS;
    DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&t_data_0.e.data[0];
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
    DMA_InitStructure.DMA_BufferSize = 0;
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
    DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
    DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
    DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
    DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
    DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
    DMA_Init(DMA2_Stream0, &DMA_InitStructure);
    NVIC_SetPriority(DMA2_Stream0_IRQn, 1);
    NVIC_EnableIRQ(DMA2_Stream0_IRQn);
    /* ADC Common configuration *************************************************/
    ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
    ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_20Cycles;
    ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_2;
    ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div8;                 // ADC_clk = 30 000 000 (Triple sample = 30 000 000 / 5 = 6 000 000 [Hz])
    ADC_CommonInit(&ADC_CommonInitStructure);
    /* ADC1 regular channel N configuration ************************************/
    ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
    ADC_InitStructure.ADC_ScanConvMode = DISABLE;
    ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
#ifdef __ILX_751B
    ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_Rising;
#endif
#ifdef __ILX_1412S
#endif
    ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC2;
    ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
    ADC_InitStructure.ADC_NbrOfConversion = 1;
    ADC_Init(ADC1, &ADC_InitStructure);
    /* ADC1 regular channel configuration */
    ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_3Cycles);
    ADC_Init(ADC2, &ADC_InitStructure);
    /* ADC2 regular channel configuration */
    ADC_RegularChannelConfig(ADC2, ADC_Channel_0, 1, ADC_SampleTime_3Cycles);
    ADC_Init(ADC3, &ADC_InitStructure);
    /* ADC3 regular channel configuration */
    ADC_RegularChannelConfig(ADC3, ADC_Channel_2, 1, ADC_SampleTime_3Cycles);
    /* Enable ADC1 DMA */
    ADC_DMACmd(ADC1, ENABLE);
    /* Enable DMA request after last transfer (multi-ADC mode) ******************/
    ADC_MultiModeDMARequestAfterLastTransferCmd(ENABLE);
    /* Clear DMA2 Stream 0 flags */
    DMA2->LIFCR |= (uint32_t)(DMA_FLAG_HTIF0 | DMA_FLAG_TCIF0);
    /* Enable DMA Stream Transfer Complete interrupt */
    DMA_ITConfig(DMA2_Stream0, DMA_IT_TC, ENABLE);
/*               PWM interface clock and pin configuration                   */
#define __Timer_F_Freq          6000000                                         // Hz
#define __Period_F_Mid          ((SystemCoreClock) / __Timer_F_Freq)            // 1 / Hz
TIM_TimeBaseInitTypeDef     TIM_TimeBaseStructure;
TIM_OCInitTypeDef           TIM_OCInitStructure;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
    /* GPIOB Configuration: Channel 2N as alternate function push-pull */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource0, GPIO_AF_TIM1);
    // TIM1 Configuration ------------------CLK-----------------------------------
    /* TIM_1clock enable */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
    uint16_t Timer_F_period = __Period_F_Mid & ~0x01;
    /* Time Base configuration */
    TIM_TimeBaseStructure.TIM_Period = Timer_F_period - 1;
    TIM_TimeBaseStructure.TIM_Prescaler = 0;
    TIM_TimeBaseStructure.TIM_ClockDivision = 0;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
    TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
    /* Channel 2N Configuration in TIM_OCMode_PWM mode */
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
    TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
    TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
    TIM_OCInitStructure.TIM_Pulse = (uint16_t) (Timer_F_period >> 1);
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
    TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
    TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset;
    TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Set;
    TIM_OC2Init(TIM1, &TIM_OCInitStructure);
    TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable);
    /* TIM1 Main Output Enable */
    TIM_CtrlPWMOutputs(TIM1, ENABLE);
    • Шота дохрена. Это если мультик может на килогерце. Обычно нет, предел 400 Гц.
    • Платы материнки и УВ пока в брак.  - Семён Семёныч... (с) Вы ничего не забыли, сэр? Как вы собрались регулировать УВ по уровню выходного сигнала??? Решение уже есть, пока в процессе. Вот так оно лучше работает.
