Ремонт камеры Techege
Доброго вечера. Помогите пожалуйста с ремонтом камеры. Камера не работает по Lan и Wifi. Вот лог прочитан через UART. Спасибо большое.
U-Boot 2014.01-v1.2 (Jun 26 2018 - 09:08:13)
Board: IPCAM RTS3903 CPU: 500M :rx5281 prid=0xdc02
force spi nor mode
DRAM:  64 MiB @ 1066 MHz
Skipping flash_init
Flash: 0 Bytes
flash status is 0, 0
SF: Detected MX25L6433F with page size 256 Bytes, erase size 64 KiB, total 8 MiB
Using default environment
In:    serial
Out:   serial
Err:   serial
Net:   Realtek PCIe GBE Family Controller mcfg = 0024
no hw config header
new_ethaddr = 4C:B0:08:39:04:10
r8168#0
no hw config header
Hit any key to stop autoboot:  0
SF: 1769472 bytes @ 0x50000 Read: OK
## Booting kernel from Legacy Image at 80100000 ...
get header OKimage_get_kernel check hcrc
image_get_kernel print contents
   Image Name:   linux_3.10
   Created:      2018-07-16   9:28:42 UTC
   Image Type:   MIPS Linux Kernel Image (uncompressed)
   Data Size:    1522556 Bytes = 1.5 MiB
   Load Address: 80454140
   Entry Point:  80454140
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
Starting kernel ...
[    0.000000] Linux version 3.10.27 (xkwy@ubuntu-hw-1404) (gcc version 4.8.5 20150209 (prerelease) (Realtek RSDK-4.8.5p1 Build 2521) ) #62 PREEMPT Mon Jul 16 17:28:39 CST 2018
[    0.000000] prom cpufreq = 500000000
[    0.000000] prom memsize = 67108864
[    0.000000] hw_ver: 0x2, hw_rev: 0x1, isp_ver: 0x1
[    0.000000] prom eth mac = 4C:B0:08:39:04:10
[    0.000000] bootconsole [early0] enabled
[    0.000000] CPU revision is: 0000dc02
[    0.000000] FPU revision is: 01730001
[    0.000000] Determined physical RAM map:
[    0.000000]  memory: 04000000 @ 00000000 (usable)
[    0.000000] Reserved contiguous memory at 0x470000(0x1500000)
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x00000000-0x03ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x00000000-0x03ffffff]
[    0.000000] icache: 32kB/32B, dcache: 16kB/32B, scache: 0kB/0B
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
[    0.000000] Kernel command line: console=ttyS1,115200 rts-quadspi.channels=dual mtdparts=m25p80:256k(boot),64k(conf),1728k(kernel),1M(rom),2M(rootfs),3008k(ipc),64k(conf.bak),-@0(all) root=/dev/mtdblock4 ro rootfstype=squashfs
[    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Memory: 38884k/65536k available (3400k kernel code, 26652k reserved, 827k data, 188k init, 0k highmem)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:57
[    0.004000] Calibrating delay loop... 497.66 BogoMIPS (lpj=995328)
[    0.036000] pid_max: default: 32768 minimum: 301
[    0.040000] Mount-cache hash table entries: 512
[    0.044000] pinctrl core: initialized pinctrl subsystem
[    0.048000] regulator-dummy: no parameters
[    0.052000] NET: Registered protocol family 16
[    0.056000] Init force reset registers
[    0.060000] rtsxb2 registered with IRQs
[    0.060000] INFO: initializing ISP memory ...
[    0.064000] INFO: initializing ISP device ...
[    0.068000] ISP camera platform devices added
[    0.072000] INFO: initializing SD controller ...
[    0.076000] INFO: initializing snd device ...
[    0.080000] snd resvd mem size : 1048576
[    0.084000] INFO: initializing USB host ...
[    0.088000] INFO: initializing spi host ...0
[    0.092000] spi platform id is ffffffff
[    0.092000] INFO: initializing I2C master ...
[    0.096000] INFO: initializing DMA controller ...
[    0.100000] INFO: initializing adc ...
[    0.100000] INFO: initializing pinctrl device ...
[    0.104000] pinctrl_platform rts3903-pinctrl: rtspc registered with IRQs
[    0.108000] INFO: initializing ethernet devices ...
[    0.112000] INFO: initializing USB phy ...
[    0.116000] INFO: initializing watchdog controller ...
[    0.120000] INFO: initializing pmu device ...
[    0.124000] INFO: initializing cpu dvfs device ...
[    0.128000] bio: create slab <bio-0> at 0
[    0.132000] rts_dmac rts3903-dmac: DesignWare DMA Controller, 4 channels
[    0.136000] INFO: realtek DMA engine inited
[    0.140000] usbcore: registered new interface driver usbfs
[    0.144000] usbcore: registered new interface driver hub
[    0.148000] usbcore: registered new device driver usb
[    0.152000] usbphy-platform usbphy-platform: Initialized Realtek IPCam USB Phy module
[    0.156000] Linux video capture interface: v2.00
[    0.160000] Advanced Linux Sound Architecture Driver Initialized.
[    0.164000] NET: Registered protocol family 2
[    0.168000] cfg80211: Calling CRDA to update world regulatory domain
[    0.176000] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[    0.180000] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[    0.188000] TCP: Hash tables configured (established 512 bind 512)
[    0.192000] TCP: reno registered
[    0.196000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.204000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.208000] NET: Registered protocol family 1
[    0.220000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.224000] jffs2: version 2.2. (NAND) В© 2001-2006 Red Hat, Inc.
[    0.232000] msgmni has been set to 75
[    0.236000] io scheduler noop registered
[    0.240000] io scheduler deadline registered
[    0.244000] io scheduler cfq registered (default)
[    0.248000] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[    0.256000] serial8250: ttyS0 at MMIO 0x18810000 (irq = 6) is a 16550A
[    0.264000] console [ttyS1] enabled, bootconsole disabled
[    0.272000] serial8250: ttyS1 at MMIO 0x18810100 (irq = 6) is a 16550A
[    0.280000] serial8250: ttyS2 at MMIO 0x18810200 (irq = 6) is a 16550A
[    0.288000] loop: module loaded
[    0.292000] dbg_iomem initialized!
[    0.296000] rts-quadspi rts3903-qspi: force to set channels from quad mode to dual mode
[    0.304000] rts-quadspi rts3903-qspi: request 60000000 Hz, force to set 41666666 Hz
[    0.312000] rts-quadspi rts3903-qspi: found mx25l6433f, expected mx25l12835f
[    0.320000] rts-quadspi rts3903-qspi: mx25l6433f (8192 Kbytes)
[    0.324000] 8 cmdlinepart partitions found on MTD device m25p80
[    0.332000] Creating 8 MTD partitions on "m25p80":
[    0.336000] 0x000000000000-0x000000040000 : "boot"
[    0.340000] 0x000000040000-0x000000050000 : "conf"
[    0.348000] 0x000000050000-0x000000200000 : "kernel"
[    0.352000] 0x000000200000-0x000000300000 : "rom"
[    0.356000] 0x000000300000-0x000000500000 : "rootfs"
[    0.364000] 0x000000500000-0x0000007f0000 : "ipc"
[    0.368000] 0x0000007f0000-0x000000800000 : "conf.bak"
[    0.376000] 0x000000000000-0x000000800000 : "all"
[    0.380000] rts-quadspi rts3903-qspi: Realtek QSPI Controller at 0x18030000 (irq 5)
[    0.388000] rtl8168 Gigabit Ethernet driver 8.038.00-NAPI loaded
[    0.492000] rtl8168 rts3903-r8168 (unregistered net_device): Use MAC address: 4c:b0:08:39:04:10
[    0.500000] eth%d: 0xb8400000, 4c:b0:08:39:04:10, IRQ 10
[    0.504000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.512000] ehci-rts: ehci-rts platform driver
[    0.516000] ehci-platform ehci-platform: EHCI Host Controller
[    0.524000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
[    0.532000] ehci-platform ehci-platform: irq 11, io mem 0x18100000
[    0.548000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
[    0.552000] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.560000] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.568000] usb usb1: Product: EHCI Host Controller
[    0.572000] usb usb1: Manufacturer: Linux 3.10.27 ehci_hcd
[    0.576000] usb usb1: SerialNumber: ehci-platform
[    0.584000] hub 1-0:1.0: USB hub found
[    0.584000] hub 1-0:1.0: 1 port detected
[    0.592000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.596000] ohci-platform ohci-platform: Generic Platform OHCI Controller
[    0.604000] ohci-platform ohci-platform: new USB bus registered, assigned bus number 2
[    0.612000] ohci-platform ohci-platform: irq 11, io mem 0x18180000
[    0.676000] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    0.680000] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.688000] usb usb2: Product: Generic Platform OHCI Controller
[    0.696000] usb usb2: Manufacturer: Linux 3.10.27 ohci_hcd
[    0.700000] usb usb2: SerialNumber: ohci-platform
[    0.704000] hub 2-0:1.0: USB hub found
[    0.708000] hub 2-0:1.0: 1 port detected
[    0.712000] i2c /dev entries driver
[    0.716000] ERROR: Unable to read RTP_REG_DC4_TRIM_OFFSET reg
[    0.724000] ERROR: Unable to read RTP_REG_CHIP_VERSION reg
[    0.728000] rtp_mfd 0-0030: pre_init() failed: -140
[    0.732000] rtp_mfd: probe of 0-0030 failed with error -140
[    0.740000] timer margin: 8 sec
[    0.744000] nf_conntrack version 0.5.0 (607 buckets, 2428 max)
[    0.752000] ip_tables: (C) 2000-2006 Netfilter Core Team
[    0.756000] TCP: cubic registered
[    0.760000] NET: Registered protocol family 17
[    0.764000] Key type dns_resolver registered
[    0.768000] invalid hconf_mtd_idx!
[    0.772000] hconf init failed
[    0.780000] ALSA device list:
[    0.780000]   No soundcards found.
[    0.788000] VFS: Mounted root (squashfs filesystem) readonly on device 31:4.
[    0.796000] Freeing unused kernel memory: 188K (80431000 - 80460000)
init started: BusyBox v1.28.1 (2018-04-08 16:57:54 CST)
[step.1] Install RealTek modules
[    2.164000] usbcore: registered new interface driver rtl8188fu
[    2.236000] rlx snd internal codec init
[    2.240000] soc-audio soc-audio.0.auto: ASoC: machine RLX_INTERN_CARD should use snd_soc_register_card()
[    2.252000] soc-audio soc-audio.0.auto:  rlx-codec-digital <-> pcm-platform mapping ok
[    2.260000] soc-audio soc-audio.0.auto:  rlx-codec-analog <-> pcm-platform mapping ok
[    2.308000] rtscam:isp resvd mem addr : 0x00570000, size : 0x1400000
[    2.316000] rtscam:rtscam_mem_init v:0xa0570000 p:0x00570000 s:0x00001400
[    2.328000] rtscam:rtscam_lock_init
[    2.340000] rtscam:rtscam_soc_probe
[    2.352000] rtscam:rtscam_hx280_probe
[    2.360000] rtscam:hx280enc:HW at base <0x18060000> with ID <0x48317011>
[    2.372000] rtscam:rtscam_jpgenc_probe
[    2.388000] rtscam:rtscam_osd2_probe
[    2.396000] rtscam:rtstream_init
[step.2] Make device node
[step.3] Check update by reset key.
[step.4] Mount Gwell filesystem
[    2.588000] jffs2: notice: (55) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
mount: mounting /dev/mtdblock5 on /ipc failed: Invalid argument
[step.5] Misc config
ifconfig: SIOCGIFFLAGS: No such device
###      Gwell IPC System      ###
ERROR: "/ipc/ipc" are NOT executable!
Please press Enter to activate this console.
Камера мне пришла не рабочая из Китая. В программе Yoosee не обнаружена по Lan и в Wifi сети. Сделал только лог.
Изменено пользователем Radist_
    • Уважаемые товарищи, нужны схемы, либо НТД для ремонтов блоков очень срочно!!!! Всё кроме реле Р10ТМУ, уже нашёл не вашем форуме и их отремонтировали....любая помощь приветствуется
