Настройка тактирования STM32F4 при помощи CMSIS
Гость Иван
При смены множителя N в PLL, частота мерцания светодиодов остается неизменной. Даже если закомментировать регистры связанные с PLL и тактировать от HSE, то частота мигания светодиодов остается прежней.
Используется плата: stm32f4 discovery.
В чем может быть дело? Что не так?
Полный листинг программы:
#include "stm32f4xx.h"                 // Device header
int main (void)
		RCC->CR |= (RCC_CR_HSEON); 							//Enable HSE
	while( !(RCC->CR & RCC_CR_HSERDY) ) {} //ready to start HSE
	//FLASH
	FLASH->ACR |= FLASH_ACR_LATENCY | FLASH_ACR_PRFTEN| FLASH_ACR_ICEN| FLASH_ACR_DCEN;
	//PLL - HSE
	RCC->PLLCFGR |= RCC_PLLCFGR_PLLSRC_HSE; //set HSE as PLL source
	RCC->CR &= ~(RCC_CR_PLLON); 						//disable PLL before changes
	//PLL M
	RCC->PLLCFGR &= ~(RCC_PLLCFGR_PLLM); 		//clear all PLLM bits
	RCC->PLLCFGR |= RCC_PLLCFGR_PLLM_2; 		//set PLLM = 4 (100)
	//PLL P
	RCC->PLLCFGR &= ~(RCC_PLLCFGR_PLLP); 		//main PLL division PLLP = 2: 00
	//PLL N
	RCC->PLLCFGR &= ~(RCC_PLLCFGR_PLLN); 		//clear all PLLN bits with mask
	RCC->PLLCFGR |= RCC_PLLCFGR_PLLN_3; 		//set PLLN = 168 (1010 1000)
	RCC->PLLCFGR |= RCC_PLLCFGR_PLLN_5; 		//for 8 or 16 MHz HSE
	RCC->PLLCFGR |= RCC_PLLCFGR_PLLN_7; 		//
	//PLL Q 7 (0111)
	RCC->PLLCFGR &= ~(RCC_PLLCFGR_PLLQ);
	RCC->PLLCFGR |= (RCC_PLLCFGR_PLLQ_0	| RCC_PLLCFGR_PLLQ_2	| RCC_PLLCFGR_PLLQ_2);
	//AHB Prescaler
	RCC->CFGR &= ~(RCC_CFGR_HPRE); 					//Prescaler 1
	RCC->CFGR |= RCC_CFGR_HPRE_DIV1; 				//AHB = SYSCLK/1
	//APB1 Prescaler 8
	RCC->CFGR &= ~(RCC_CFGR_PPRE1);
	RCC->CFGR |= RCC_CFGR_PPRE1_DIV8;
	//APB2 Prescaler 2
	RCC->CFGR &= ~(RCC_CFGR_PPRE2);
	RCC->CFGR |= RCC_CFGR_PPRE2_DIV2;
	//PLL enable
	RCC->CR |= RCC_CR_PLLON; 								//enalbe PLL
	while((RCC->CR & RCC_CR_PLLRDY) == 0) {} 	//wait for PLL is ready
	//PLL System
	RCC->CFGR &= ~RCC_CFGR_SW;
	RCC->CFGR |= RCC_CFGR_SW_HSE; 					//PLL selected as system clock
	while((RCC->CFGR & RCC_CFGR_SWS) != RCC_CFGR_SWS_HSE) {} 	//wait for PLL is used
	RCC->AHB1ENR |=RCC_AHB1ENR_GPIODEN;	//start clock PORTD
	GPIOD->MODER |= GPIO_MODER_MODER15_0 | GPIO_MODER_MODER14_0 | GPIO_MODER_MODER13_0 | GPIO_MODER_MODER12_0; // Pin 15, 14, 13, 12 - out
	GPIOD->OTYPER &= ~0xF000; // Pin 15, 14, 13, 12 - Output push-pull
	GPIOD->OSPEEDR &= ~0xFF000000; // Pin 15, 14, 13, 12 - Low speed
while(1)
	// ON LED
	GPIOD->ODR |= GPIO_ODR_ODR_15 | GPIO_ODR_ODR_14 | GPIO_ODR_ODR_13 | GPIO_ODR_ODR_12;
	for (int i=0; i<24000000; i++){}
	// OFF LED
	GPIOD->ODR &= ~(GPIO_ODR_ODR_15 | GPIO_ODR_ODR_14 | GPIO_ODR_ODR_13 | GPIO_ODR_ODR_12);
Источником тактирования выбран внешний кварц, а нужно выбирать PLL.
Должно быть как-то так:
RCC->CFGR |= RCC_CFGR_SW_PLL; 					//PLL selected as system clock
while((RCC->CFGR & RCC_CFGR_SWS) != RCC_CFGR_SWS_PLL) {} 	//wait for PLL is used
4 часа назад, Вуйко сказал:
У меня так было изначально. Частота не меняется при смене N.
Это я потом пробовал с HSE
  • 1 год спустя...
