Sanchous
Проблема при прошивке stm32 через st-link
Я делаю проект с использованием stm32, до этого я работал с arduino, и подобных проблем не было, при прошивке МК эти кодом (сгенерированым при помощи cubeMX):
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * <h2><center>&copy; Copyright (c) 2020 STMicroelectronics.
  * All rights reserved.</center></h2>
  * This software component is licensed by ST under BSD 3-Clause license,
  * the "License"; You may not use this file except in compliance with the
  * License. You may obtain a copy of the License at:
  *                        opensource.org/licenses/BSD-3-Clause
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
    Error_Handler();
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
С использованием такого make скрипта:
# File automatically-generated by tool: [projectgenerator] version: [3.5.2] date: [Mon Feb 03 16:34:48 MSK 2020]
# Generic Makefile (based on gcc)
# ChangeLog :
#	2017-02-10 - Several enhancements + project update mode
#   2015-07-22 - first version
# target
TARGET = test
# building variables
# debug build?
DEBUG = 1
# optimization
OPT = -Og
# paths
# Build path
BUILD_DIR = build
# source
# C sources
C_SOURCES =  \
Src/main.c \
Src/stm32f1xx_it.c \
Src/stm32f1xx_hal_msp.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_gpio_ex.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_tim.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_tim_ex.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_rcc.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_rcc_ex.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_gpio.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_dma.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_cortex.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_pwr.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_flash.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_flash_ex.c \
Drivers/STM32F1xx_HAL_Driver/Src/stm32f1xx_hal_exti.c \
Src/system_stm32f1xx.c
# ASM sources
ASM_SOURCES =  \
startup_stm32f103xb.s
# binaries
PREFIX = arm-none-eabi-
# The gcc compiler bin path can be either defined in make command via GCC_PATH variable (> make GCC_PATH=xxx)
# either it can be added to the PATH environment variable.
ifdef GCC_PATH
CC = $(GCC_PATH)/$(PREFIX)gcc
AS = $(GCC_PATH)/$(PREFIX)gcc -x assembler-with-cpp
CP = $(GCC_PATH)/$(PREFIX)objcopy
SZ = $(GCC_PATH)/$(PREFIX)size
else
CC = $(PREFIX)gcc
AS = $(PREFIX)gcc -x assembler-with-cpp
CP = $(PREFIX)objcopy
SZ = $(PREFIX)size
endif
HEX = $(CP) -O ihex
BIN = $(CP) -O binary -S
# CFLAGS
# cpu
CPU = -mcpu=cortex-m3
# fpu
# NONE for Cortex-M0/M0+/M3
# float-abi
# mcu
MCU = $(CPU) -mthumb $(FPU) $(FLOAT-ABI)
# macros for gcc
# AS defines
AS_DEFS =
# C defines
C_DEFS =  \
-DUSE_HAL_DRIVER \
-DSTM32F103xB
# AS includes
AS_INCLUDES =
# C includes
C_INCLUDES =  \
-IInc \
-IDrivers/STM32F1xx_HAL_Driver/Inc \
-IDrivers/STM32F1xx_HAL_Driver/Inc/Legacy \
-IDrivers/CMSIS/Device/ST/STM32F1xx/Include \
-IDrivers/CMSIS/Include \
# compile gcc flags
ASFLAGS = $(MCU) $(AS_DEFS) $(AS_INCLUDES) $(OPT) -Wall -fdata-sections -ffunction-sections
CFLAGS = $(MCU) $(C_DEFS) $(C_INCLUDES) $(OPT) -Wall -fdata-sections -ffunction-sections
ifeq ($(DEBUG), 1)
CFLAGS += -g -gdwarf-2
endif
# Generate dependency information
CFLAGS += -MMD -MP -MF"$(@:%.o=%.d)"
# LDFLAGS
# link script
LDSCRIPT = STM32F103C8Tx_FLASH.ld
# libraries
LIBS = -lc -lm -lnosys
LIBDIR =
LDFLAGS = $(MCU) -specs=nano.specs -T$(LDSCRIPT) $(LIBDIR) $(LIBS) -Wl,-Map=$(BUILD_DIR)/$(TARGET).map,--cref -Wl,--gc-sections
# default action: build all
all: $(BUILD_DIR)/$(TARGET).elf $(BUILD_DIR)/$(TARGET).hex $(BUILD_DIR)/$(TARGET).bin
# build the application
# list of objects
OBJECTS = $(addprefix $(BUILD_DIR)/,$(notdir $(C_SOURCES:.c=.o)))
vpath %.c $(sort $(dir $(C_SOURCES)))
# list of ASM program objects
OBJECTS += $(addprefix $(BUILD_DIR)/,$(notdir $(ASM_SOURCES:.s=.o)))
vpath %.s $(sort $(dir $(ASM_SOURCES)))
$(BUILD_DIR)/%.o: %.c Makefile | $(BUILD_DIR)
	$(CC) -c $(CFLAGS) -Wa,-a,-ad,-alms=$(BUILD_DIR)/$(notdir $(<:.c=.lst)) $< -o $@
$(BUILD_DIR)/%.o: %.s Makefile | $(BUILD_DIR)
	$(AS) -c $(CFLAGS) $< -o $@
$(BUILD_DIR)/$(TARGET).elf: $(OBJECTS) Makefile
	$(CC) $(OBJECTS) $(LDFLAGS) -o $@
	$(SZ) $@
$(BUILD_DIR)/%.hex: $(BUILD_DIR)/%.elf | $(BUILD_DIR)
	$(HEX) $< $@
$(BUILD_DIR)/%.bin: $(BUILD_DIR)/%.elf | $(BUILD_DIR)
	$(BIN) $< $@
$(BUILD_DIR):
	md $@
# clean up
clean:
	-rm -fR $(BUILD_DIR)
# dependencies
-include $(wildcard $(BUILD_DIR)/*.d)
# *** EOF ***
При прошивке через st-link программой stm32 st-link utulity, я получаю ошибку: "File empty or corrupted!"
Металл-композит как альтернатива ферриту: дроссели Panasonic семейства ETQP
Современные электронные устройства требуют все более компактных и эффективных компонентов. Новые металл-композитные дроссели обладают рядом преимуществ перед дросселями с ферритовым сердечником. Они не имеют ярко выраженного насыщения, обладают отличными частотными свойствами и способны работать при температурах до 150°C и выше. Все это делает их альтернативой стандартным дросселям с ферритовым сердечником в широком спектре автомобильных и промышленных приложений.
    • Guest Владимир
      By Guest Владимир
      Доброго времени суток.
      Есть условный  конвейер, и по нему двигаются N-ыме товары с qr штрихкодами. Нужно разработать сканер, который чем быстрее будет работать, тем лучше.
      Посоветуйте какие то камеры и статьи/книги о подобном.
    • By One _ moment
      Здравствуйте. Нужно разобраться с принципом работы интерфейса I2C на Stm32. понимаю, что материала в интернете много, но почему-то даже просто структура, где определяются параметры, у меня другая.
      Моя вот такая:
      typedef struct
        uint32_t I2C_Timing;
        uint32_t I2C_AnalogFilter;
        uint32_t I2C_DigitalFilter;
        uint32_t I2C_Mode;
        uint32_t I2C_OwnAddress1;
        uint32_t I2C_Ack;
        uint32_t I2C_AcknowledgedAddress;
      }I2C_InitTypeDef;
      Те, что даются в примерах, в статьях, такая:
      typedef struct
        uint32_t I2C_ClockSpeed;
        uint16_t I2C_Mode;
        uint16_t I2C_DutyCycle;
        uint16_t I2C_OwnAddress1;
        uint16_t I2C_Ack;
        uint16_t I2C_AcknowledgedAddress;
      }I2C_InitTypeDef;
      Найдя пример на этом форуме (https://forum.cxem.net/index.php?/topic/202586-i2c-%D0%B2-stm32f030/) увидел, что используются параметры такие же, что и у меня, но теперь не понятно, откуда такие значения берут и по какой логике.
      Прошу не пинать ногами и кидать в меня гнилые помидоры, а помочь разобраться в этом всём или подсказать, где можно найти исчерпывающую информацию, где хорошо и по полочкам всё разложено.
      Программирую в keil uVision v5
      Отладочная плата stm32f0 disco
      МК stm32f0030r8
      Благодарю заранее.
    • Guest User1324
      By Guest User1324
      Здравствуйте, помогите подключить USB-флешку к STM32F103RCT6, нужна дополнить принципиальную схему. Если есть возможность нарисовать.
    • By Tokes
      Здравствуйте.
      CUBEMX + CUBEIDE + PUTTY + STLINK V2
      Есть blue pill. Создал новый проект в CUBEMX. Включил там USB как COM порт. Завёл приём сообщений (модифицировал static CDC_Receive_FS функцию). Всё хорошо работает ровно до тех пор, пока в CUBEIDE не нажимаю F11 (build + flash + debug). После этого необходимо руками вытаскивать и засовывать кабель, чтобы можно было продолжать пользоваться терминалом. В то же время достаточно коснуться контакта "USB-" - и происходит тот самый желанный реконнект, после которого достаточно нажать restart session в терминале и всё продолжает работать нормально.
      Вопрос - как сделать программно, чтобы при старте устройство ("com port" или "usb com emulator") само себя "переподключало"?
    • By Стальной
      Здравствуйте!
      Интересует мнение коллег по правильному питанию мощных МК. Имеется STM32F722VCT6. Делаю для себя новый отладочный стенд. На нем будут обкатываться различные задачи, поставлю плюсом к МК всякую периферию, обязательно i2c память (из серии AT24Cxx), MAX3485, возможно какой-то дисплей, SD-карту, может быть SIM900 и NAND. Первичный источник - думаю, USB хватит.
      Вопрос - как организовать питание МК? Имеет ли смысл цифровую часть (а мб и часть периферийного зоопарка) питать импульсной системой, а аналоговую часть кренкой? Или всё кренкой запитать? Какие идеи?
      Спасибо)
      ЗЫ Сейчас использую стенд на STM32F407VET6, сделанный на коленках, все кренкой питается. Но там периферия изготавливается по мере необходимости и надевается отдельно на гребенки.
