stubiflex
Проблема с Unified Bootloader Host Application-ом
Сгенерировал с помощью МСС код загрузчика. При попытке залить приложение с помощью Unified Bootloader Host Application, получаю сообщение, которая на скриншоте.
PIC6F18456
Как перебороть?
//        Software License Agreement
// ©2016 Microchip Technology Inc. and its subsidiaries. You may use this
// software and any derivatives exclusively with Microchip products.
// THIS SOFTWARE IS SUPPLIED BY MICROCHIP "AS IS". NO WARRANTIES, WHETHER
// EXPRESS, IMPLIED OR STATUTORY, APPLY TO THIS SOFTWARE, INCLUDING ANY IMPLIED
// WARRANTIES OF NON-INFRINGEMENT, MERCHANTABILITY, AND FITNESS FOR A PARTICULAR
// PURPOSE, OR ITS INTERACTION WITH MICROCHIP PRODUCTS, COMBINATION WITH ANY
// OTHER PRODUCTS, OR USE IN ANY APPLICATION.
// IN NO EVENT WILL MICROCHIP BE LIABLE FOR ANY INDIRECT, SPECIAL, PUNITIVE,
// INCIDENTAL OR CONSEQUENTIAL LOSS, DAMAGE, COST OR EXPENSE OF ANY KIND
// WHATSOEVER RELATED TO THE SOFTWARE, HOWEVER CAUSED, EVEN IF MICROCHIP HAS
// BEEN ADVISED OF THE POSSIBILITY OR THE DAMAGES ARE FORESEEABLE. TO THE
// FULLEST EXTENT ALLOWED BY LAW, MICROCHIP'S TOTAL LIABILITY ON ALL CLAIMS IN
// ANY WAY RELATED TO THIS SOFTWARE WILL NOT EXCEED THE AMOUNT OF FEES, IF ANY,
// THAT YOU HAVE PAID DIRECTLY TO MICROCHIP FOR THIS SOFTWARE.
// MICROCHIP PROVIDES THIS SOFTWARE CONDITIONALLY UPON YOUR ACCEPTANCE OF THESE TERMS.
// Memory Map
//   |    0x0000     |   Reset vector
//   |    0x0004     |   Interrupt vector
//   |  Boot Block   |   (this program)
//   |    0x0300     |   Re-mapped Reset Vector
//   |    0x0304     |   Re-mapped High Priority Interrupt Vector
//   |  Code Space   |   User program space
//   |    0x3FFF     |
// Definitions:
//   STX     -   Start of packet indicator
//   DATA    -   General data up to 255 bytes
//   COMMAND -   Base command
//   DLEN    -   Length of data associated to the command
//   ADDR    -   Address up to 24 bits
//   DATA    -   Data (if any)
// Commands:
//   RD_VER      0x00    Read Version Information
//   RD_MEM      0x01    Read Program Memory
//   WR_MEM      0x02    Write Program Memory
//   ER_MEM      0x03    Erase Program Memory (NOT supported by PIC16)
//   RD_EE       0x04    Read EEDATA Memory
//   WR_EE       0x05    Write EEDATA Memory
//   RD_CONFIG   0x06    Read Config Memory (NOT supported by PIC16)
//   WT_CONFIG   0x07    Write Config Memory (NOT supported by PIC16)
//   CHECKSUM    0x08    Calculate 16 bit checksum of specified region of memory
//   RESET       0x09    Reset Device and run application
#define  READ_VERSION   0
#define  READ_FLASH     1
#define  WRITE_FLASH    2
#define  ERASE_FLASH    3
#define  READ_EE_DATA   4
#define  WRITE_EE_DATA  5
#define  READ_CONFIG    6
#define  WRITE_CONFIG   7
#define  CALC_CHECKSUM  8
#define  RESET_DEVICE   9
#define  CALC_CRC       10
    #include "xc.h"       // Standard include
    #include <stdint.h>
    #include <stdbool.h>
    #include "bootload.h"
    #include "mcc.h"
void     Get_Buffer (void);     // generic comms layer
uint8_t  Get_Version_Data(void);
uint8_t  Read_Flash(void);
uint8_t  Write_Flash(void);
uint8_t  Erase_Flash(void);
uint8_t  Read_EE_Data(void);
uint8_t  Write_EE_Data(void);
uint8_t  Read_Config(void);
uint8_t  Write_Config(void);
uint8_t  Calc_Checksum(void);
void     StartWrite(void);
void     BOOTLOADER_Initialize(void);
void     Run_Bootloader(void);
bool     Bootload_Required (void);
#define	MINOR_VERSION   0x07       // Version
#define	MAJOR_VERSION   0x00
//#define STX             			 0x55       // Actually code 0x55 is 'U'  But this is what the autobaud feature of the PIC16F1 EUSART is looking for
#define ERROR_ADDRESS_OUT_OF_RANGE   0xFE
#define ERROR_INVALID_COMMAND        0xFF
#define COMMAND_SUCCESS              0x01
// To be device independent, these are set by mcc in memory.h
#define  LAST_WORD_MASK          (WRITE_FLASH_BLOCKSIZE - 1)
#define  NEW_RESET_VECTOR        0x500
#define  NEW_INTERRUPT_VECTOR    0x504
#define _str(x)  #x
#define str(x)  _str(x)
    uint16_t check_sum;    // Checksum accumulator
    uint16_t counter;      // General counter
    uint8_t data_length;
    uint8_t rx_data;
    uint8_t tx_data;
    bool reset_pending = false;
// Force variables into Unbanked for 1-cycle accessibility
    uint8_t EE_Key_1    __at(0x70);
    uint8_t EE_Key_2    __at(0x71);
frame_t  frame;
// The bootloader code does not use any interrupts.
// However, the application code may use interrupts.
// The interrupt vector on a PIC16F is located at
// address 0x0004.
// The following function will be located
// at the interrupt vector and will contain a jump to
// the new application interrupt vector
    asm ("psect  intentry,global,class=CODE,delta=2");
    asm ("pagesel " str(NEW_INTERRUPT_VECTOR));
    asm ("GOTO " str(NEW_INTERRUPT_VECTOR));
void BOOTLOADER_Initialize ()
    EE_Key_1 = 0;
    EE_Key_2 = 0;
    if (Bootload_Required () == true)
        Run_Bootloader ();     // generic comms layer
    STKPTR = 0x1F;
    asm ("pagesel " str(NEW_RESET_VECTOR));
    asm ("goto  "  str(NEW_RESET_VECTOR));
bool Bootload_Required ()
//  Check the reset vector for code to initiate bootloader
    // This section reads the application start vector to see if the location is blank
    NVMADRL = NEW_RESET_VECTOR & 0xFF;    // (0x3FFF) or not.  If blank, it runs the bootloader.
    NVMADRH = (NEW_RESET_VECTOR & 0xFF00UL)>> 8;
    // Otherwise, it assumes the application is loaded and instead runs the application.
    NVMCON1 = 0x80;
    NVMCON1bits.RD = 1;
    NOP();
    NOP();
    if ((NVMDATH == 0x3F) && (NVMDATL == 0xFF))
        return (true);
    return (false);
uint8_t  ProcessBootBuffer()
    uint8_t   len;
    EE_Key_1 = frame.EE_key_1;
    EE_Key_2 = frame.EE_key_2;
// Test the command field and sub-command.
    switch (frame.command)
    case    READ_VERSION:
        len = Get_Version_Data();
        break;
    case    READ_FLASH:
        len = Read_Flash();
        break;
    case    WRITE_FLASH:
        len = Write_Flash();
        break;
    case    ERASE_FLASH:
        len = Erase_Flash();
        break;
    case    READ_CONFIG:
        len = Read_Config();
        break;
    case    WRITE_CONFIG:
        len = Write_Config();
        break;
    case    CALC_CHECKSUM:
        len = Calc_Checksum();
        break;
    case    RESET_DEVICE:
        reset_pending = true;
        len = 9;
        break;
    default:
        frame.data[0] = ERROR_INVALID_COMMAND;
        len = 10;
    return (len);
// Commands
//        Cmd     Length----------------   Address---------------
// In:   [<0x00> <0x00><0x00><0x00><0x00> <0x00><0x00><0x00><0x00>]
// OUT:  [<0x00> <0x00><0x00><0x00><0x00> <0x00><0x00><0x00><0x00> <VERL><VERH>]
uint8_t  Get_Version_Data()
    frame.data[0] = MINOR_VERSION;
    frame.data[1] = MAJOR_VERSION;
    frame.data[2] = 0;       // Max packet size (256)
    frame.data[3] = 1;
    frame.data[4] = 0;
    frame.data[5] = 0;
    NVMADRL = 0x06;               // Get device ID
    NVMADRH = 0x00;
    NVMCON1bits.NVMREGS = 1;
    NVMCON1bits.RD = 1;
    NOP();
    NOP();
    frame.data[6] = NVMDATL;
    frame.data[7] = NVMDATH;
    frame.data[8] = 0;
    frame.data[9] = 0;
    frame.data[10] = ERASE_FLASH_BLOCKSIZE;
    frame.data[11] = WRITE_FLASH_BLOCKSIZE;
    NVMADRL = 0x00;
    NVMADRH = 0x00;
    for (uint8_t  i= 12; i < 16; i++)
        NVMCON1bits.RD = 1;
        NOP();
        NOP();
        frame.data[i] = NVMDATL;
        if ((++ NVMADRL) == 0x00)
            ++ NVMADRH;
    return  25;   // total length to send back 9 byte header + 16 byte payload
// Read Flash
// In:	[<0x01><DLEN><ADDRL><ADDRH><ADDRU>]
// OUT:	[<0x01><DLEN><ADDRL><ADDRH><ADDRU><DATA>...]
uint8_t Read_Flash()
    NVMADRL = frame.address_L;
    NVMADRH = frame.address_H;
    NVMCON1 = 0x80;
    for (uint16_t i = 0; i < frame.data_length; i += 2)
        NVMCON1bits.RD = 1;
        NOP();
        NOP();
        frame.data[i+1] = NVMDATH;
            ++ NVMADRH;
    return (frame.data_length + 9);
// Write Flash
// In:	[<0x02><DLENBLOCK><0x55><0xAA><ADDRL><ADDRH><ADDRU><DATA>...]
// OUT:	[<0x02>]
uint8_t Write_Flash()
    NVMCON1 = 0xA4;       // Setup writes
    for (uint16_t  i= 0; i < frame.data_length; i += 2)
        if (((NVMADRL & LAST_WORD_MASK) == LAST_WORD_MASK)|| (i == frame.data_length - 2))
        NVMCON1bits.LWLO = 0;
        NVMDATL = frame.data[i];
        NVMDATH = frame.data[i+1];
        StartWrite();
            ++ NVMADRH;
    frame.data[0] = COMMAND_SUCCESS;
    EE_Key_1 = 0x00;  // erase EE Keys
    EE_Key_2 = 0x00;
    return (10);
// Erase Program Memory
// Erases data_length rows from program memory
uint8_t Erase_Flash ()
    for (uint16_t i=0; i < frame.data_length; i++)
        if ((NVMADRH & 0x7F) >= ((END_FLASH & 0xFF00) >> 8))
            frame.data[0] = ERROR_ADDRESS_OUT_OF_RANGE;
            return (10);
        NVMCON1 = 0x94;       // Setup writes
        StartWrite();
        if ((NVMADRL += ERASE_FLASH_BLOCKSIZE) == 0x00)
            ++ NVMADRH;
    frame.EE_key_1 = 0x00;  // erase EE Keys
    frame.EE_key_2 = 0x00;
    return (10);
// Read Config Words
// In:	[<0x06><DataLengthL><unused> <unused><unused> <ADDRL><ADDRH><ADDRU><unused>...]
// OUT:	[9 byte header + 4 bytes config1 + config 2]
uint8_t Read_Config ()
    NVMCON1 = 0x40;      // can these be combined?
    for (uint8_t  i= 0; i < frame.data_length; i += 2)
        NVMCON1bits.RD = 1;
        NOP();
        NOP();
        ++ NVMADRL;
    return (13);           // 9 byte header + 4 bytes config words
// Write Config Words
uint8_t Write_Config ()
    NVMCON1 = 0xC4;       // Setup writes
    for (uint8_t  i = 0; i < frame.data_length; i += 2)
        StartWrite();
            ++ NVMADRH;
    EE_Key_2 = 0x00;
    return (10);
// Calculate Checksum
// In:	[<0x08><DataLengthL><DataLengthH> <unused><unused> <ADDRL><ADDRH><ADDRU><unused>...]
// OUT:	[9 byte header + ChecksumL + ChecksumH]
uint8_t Calc_Checksum()
    NVMCON1 = 0x80;
    check_sum = 0;
    for (uint16_t i = 0;i < frame.data_length; i += 2)
        NVMCON1bits.RD = 1;
        NOP();
        NOP();
        check_sum += (uint16_t)NVMDATL;
        check_sum += ((uint16_t)NVMDATH) << 8;
            ++ NVMADRH;
     frame.data[0] = (uint8_t) (check_sum & 0x00FF);
     frame.data[1] = (uint8_t)((check_sum & 0xFF00) >> 8);
     return (11);
/*uint8_t Calc_Checksum()
 uint16_t addr = (frame.address_H << 8) | frame.address_L;
 check_sum = 0;
 check_sum += FLASH_ReadWord(addr);
 ++ addr;
 return (11);
// Unlock and start the write or erase sequence.
void StartWrite()
    CLRWDT();
//    NVMCON2 = EE_Key_1;
//    NVMCON2 = EE_Key_2;
//    NVMCON1bits.WR = 1;       // Start the write
// had to switch to assembly - compiler doesn't comprehend no need for bank switch
    asm ("movf " str(_EE_Key_1) ",w");
    asm ("movwf " str(BANKMASK(NVMCON2)));
    asm ("movf  " str(_EE_Key_2) ",w");
    asm ("bsf  "  str(BANKMASK(NVMCON1)) ",1");       // Start the write
    NOP();
    NOP();
    return;
// Check to see if a device reset had been requested.  We can't just reset when
// the reset command is issued.  Instead we have to wait until the acknowledgement
// is finished sending back to the host.  Then we reset the device.
void Check_Device_Reset ()
    if (reset_pending == true)
        RESET();
Если я Вас правильно понял, вы вначале bootloader нашли на свои мк прошивка .asm,  потом настроили ее допустим шьем в конец flash памяти не с нулевого адреса мк и скомпилировали еe в .hex и прошили нормальным прогграматором и только потом можно заливать свою прошивку программу через uart переходник допустим. Если это было сделанно не так вы нарушили все инструкций адрес вот читаем http://proiot.ru/blog/posts/2012/10/03/zamechatelnyi-bootloader-ot-microchip-dlia-pic16-pic18/ или я дурак вас не понял).
Написано же выше, что я сгенерировал (создал прошивку) бутлоудера. Конечно же сгенерированную прошивку залил в PIC с помощью PICkit3. Потом пытался залить прошивку аппликации через уже залитого бутлоудера и программы на ПК. Результаты на скриншотах.
А замечательный бутлоадер, на которого дали ссылку, меня давно уже работает. Но тема сейчас не этот.
Время – деньги и наноамперы: применение часов реального времени Maxim Integrated
Зачем использовать внешнюю микросхему часов реального времени (RTC), а не внутренние RTC микроконтроллера? Хотя бы потому, что у RTC MAX31342 производства Maxim Integrated типовое потребление составляет 150 нА при 3 В и температуре 25°С, а у встроенных RTC одного из самых малопотребляющих микроконтроллеров при тех же условиях – примерно 370 нА.
Читать статью
Мне только одно интересно через приложение AN1310 которое можно тоже самое проделать тоже ошибку выдает?
Залитая прошивка бутлоудера не способен сотрудничать с AN1310, по этому не может быть выдаваться тот же ошибка.
Чип-резисторы Panasonic - технология мягких выводов и сертификация AEC-Q200
Технология мягких выводов чип-резисторов производства компании Panasonic. Обзор серий с оптимизированными параметрами: прецизионных тонкопленочных, токоизмерительных, антисерных, резисторов с повышенной стойкостью к статике и импульсным нагрузкам, резисторных сборок.
Читать статью
Ну если для данного мк, после установки приложения  AN1310  нет бутлоадера .asm в списках поддержки то наверно не будет работать с вашей прошивкой данное приложение. Тогда посмотрите здесь намеки https://www.microchip.com/forums/m988264-p2.aspx может поможет и внимательно проидите по ссылкам которые там похоже ответ на вашу проблему есть, mcc не совсем корректно генерирует загрузчик с определенными данными.
5-ый раз говорю, что на МК залит прошивка бутлоудера, сгенерированная с помощью МСС. Это все не имеет никакого отношения к АN1310.
Тогда вас ждут танцы с бубном с загрузчиком сгенерированным с помощью мсс, его надо подгонять под приложение Unified Bootloader Host Application чтобы заработало как надо. Об этом явно пишут на форуме по ссылкам которые давал. То что бут залит в мк вас не спасет. Колдовать придется с самим бутом кода генерированным мсс еще раньше прежде чем прошивть его в мк.
Edited by Securety
А на вопрос, которую я задал в стартовом посте, ничего конкретного? Просто постите, увеличивая количество постов? После 100 бесполезных постов дают тут грамоту?
А вы на том форуме хоть были? В котором с переводом лично насчитал около 6+ решений именно с вашей проблемой unified bootloader application. Тут нет телепатов потому что, нужно иметь ваш мк с железом чтоб точно помочь вам, вы же не о коде спрашивайте и какие там ошибки которую легко в proteus проверить на правильность. Я лично на 100%  что там на том форуме вы не были и не пробывали варианты, а сразу здесь спросили и написали.
Здравствуйте. Что сразу вижу:
1. Попробуйте в настройках поставить скорость 19200. На 9600 у меня почему-то тоже не было связи.
2. Память под программу, как я понимаю, должна начинаться с 0х0300, у Вас в настройках 0х1000.
    • Но, с другой стороны...  чтоб все выхода сгорели разом? И нижние транзисторы? "Не верю". )
    • Кто вникает в тему-тому везет. А кто не желает читать-что пишут, набивает шишки.  Индукция зависит от свойств (марки) феррита. Откройте даташит на феррит например №87 и смотрите параметр Bs  Феррит №87 При температуре 25 градусов Bs=0.49T  , при нагреве до 100 градусов -уже 0,39Т . Это значит-что при индукции в 0.39Т феррит насытится и превратится в глину.  У других ферритов, пример советские,  Bs=0.25T , как превысите-будет насыщение и бадабум ключам.  Так же есть и параметр Ls-паразитная индуктивность. Она не дает размагнититься сердечнику до 0 и при новом цикле намагничивания будет выброс на ключах, как то так  по быстрому и на пальцах. Не поленитесь и откройте файлик Расета витков-там есть формулы, как считается СТ Подробнее про свойства ферритов читайте  в интернете , например  ЗДЕСЬ Расчет витков транса.xlsx
    • ну да только если нужно по порядку то break; не нужен, так же и нет необходимости в tmp++ в последней строке
    • Так наверное? switch(tmp)                         {                         case 0:    нужное действие; tmp++;  break;                         case 1:    нужное действие; tmp++;  break;                         case 2:    нужное действие; tmp++;  break;                         case 3:    нужное действие; tmp++;  break;                         case 4:    нужное действие; tmp++;  break;                         case 5:    нужное действие; tmp++;  break;                         }
    • Ну кто вам сказал....что однофазной.. Имеется и трёх фазная сеть. Да и 3000ватт из однофазной сети выжать не проблема. Главно чтоб сеть была правильно сделана. Одна розетка сможет выдать 3500ватт.
    • Точка находится в той же панельке, что и линия, полигон, окружность... Называется "узел".
