Sambler
МК ATMEGA16 и 7SEG-MPX6-CA-BLUE
Дано следующее задание, собрать электронную плату с 7 сегментным. Собрал, код ввёл, но на индикаторе почему то ничего не отображается, хотя всё подключено так же, как в задании.
Код программы:
Скрытый текст
.include"m16def.inc"
.dseg
tab: .byte 8
.cseg
.org 0
  rjmp Reset
.org 0x12
  rjmp Timer0_Ovf
.org 0x28
Reset:
                                          ; SP <- Ramend
                               ldi r16, HIGH(RamEnd)
                               out sph, r16
                               ldi r16, LOW(RamEnd)
                               out spl, R16
                                           ; A, C : output,Value = 0x00
                               ldi r16, 0xFF
                               out DDRA, r16
                               out DDRC, r16
                               ldi r16, 0x00
                               out PortA, r16
                               out PortC, r16
                                         ; Timer0_OVF, Prescaler = 8, OffSet = 100
                               ldi r16, 0x01
                               out TIMSK, r16
                               ldi r16, 0x03
                               out TCCR0, r16
                               ldi r16, 0x80
                               out TCNT0, r16
                               rcall TabInit
                               clr r17
                               sei
                Main:
                    rjmp Main
reti
Timer0_Ovf:
                               clr r16
                               out portA, r16
                               ldi r16, 200
                               out TCNT0, r16
                               lsl r17
                               cpi r17, 0x00
                               brne L2
                               ldi r17, 0x01
                L1:
                               ldi yh, High(tab)
                               ldi yl, Low(tab)
                               cpi r17, 0b00000001
                               brne L2
                               ldd r16, y+0
                               out PortA, r16
                               mov r18, r17
                               com r18
                               out PortC, r18
                L2:
                               ldi yh, High(tab)
                               ldi yl, Low(tab)
                               cpi r17, 0b00000010
                               brne L3
                               ldd r16, y+1
                               out PortA, r16
                               mov r18, r17
                               com r18
                               out PortC, r18
                L3:
                               ldi yh, High(tab)
                               ldi yl, Low(tab)
                               cpi r17, 0b00000100
                               brne L4
                               ldd r16, y+2
                               out PortA, r16
                               mov r18, r17
                               com r18
                               out PortC, r18
                L4:
                               ldi yh, High(tab)
                               ldi yl, Low(tab)
                               cpi r17, 0b00001000
                               brne L5
                               ldd r16, y+3
                               out PortA, r16
                               mov r18, r17
                               com r18
                               out PortC, r18
                L5:
                               ldi yh, High(tab)
                               ldi yl, Low(tab)
                               cpi r17, 0b00010000
                               brne L6
                               ldd r16, y+4
                               out PortA, r16
                               mov r18, r17
                               com r18
                               out PortC, r18
                L6:
                               ldi yh, High(tab)
                               ldi yl, Low(tab)
                               cpi r17, 0b00100000
                               brne L7
                               ldd r16, y+5
                               out PortA, r16
                               mov r18, r17
                               com r18
                               out PortC, r18
                L7:
                               ldi yh, High(tab)
                               ldi yl, Low(tab)
                               cpi r17, 0b01000000
                               brne L8
                               ldd r16, y+6
                               out PortA, r16
                               mov r18, r17
                               com r18
                               out PortC, r18
                L8:
                               ldi yh, High(tab)
                               ldi yl, Low(tab)
                               cpi r17, 0b10000000
                               brne L9
                               ldd r16, y+7
                               out PortA, r16
                               mov r18, r17
                               com r18
                               out PortC, r18
    L9:
reti
TabInit:
                               ldi yh, High(tab)
                               ldi yl, Low(tab)
                               ldi r16, 0b01111001 ; r16 <- 'E'
                               st y+, r16
                               ldi r16, 0b01010000 ; r16 <- 'r'
                               st y+, r16
                               st y+, r16
                               ldi r16, 0b01011100 ; r16 <- '0'
                               st y+, r16
                               st y+, r16
                               ldi r16, 0b01111101 ; r16 <- '6'
                               st y+, r16
                               st y+, r16
                               st y, r16
                     ret
2 Картинки: 1 - моя работа, 2 - работа из задания.
Может я ка кто не так подключаю ? и может эти буквы\цифры на соелинениях влияют на это?
Edited by Alex
Код спрятал под Сполер
35 минут назад, Sambler сказал:
Мысли вслух ?
Или ждём появления экстрасенса ?
42 минуты назад, Sambler сказал:
какой смышленый ученик попался :i-m_so_happy:
Повышаем уровень передаваемой мощности в однопарной сети Ethernet
В статье приведено описание новых гибридных разъемов для использования в SPE-приложениях. По сравнению с традиционными разъемами, в основе структуры которых лежит технология PoDL (Power over Data Line), предлагаемое решение содержит в себе дополнительные контакты питания, но сохраняет при этом компактные размеры. А работа с более высокими значениями тока значительно расширяет возможности применения предлагаемых разъемов в различных топологиях, по сравнению с PoDL.
6 минут назад, Alex сказал:
Мысли вслух ?
Ну подключено же так как указано в задании ..... Или эти Сирии дорожки может не нужны?
Только что, IMXO сказал:
Проблема в том, что в колледже дают, я делаю, причем единственный с группы, а спросить не у кого, приходится по форумам ходить, тут люди умнее
Вебинар «Новинки и решения Traco для промышленных и отраслевых приложений» (28.10.2021)
Компэл 28 октября приглашает всех желающих принять участие в вебинаре, где будет рассмотрена новая и перспективная продукция компании Traco. Мы подробно рассмотрим сильные стороны и преимущества продукции Traco, а также коснемся практических вопросов, связанных с измерением уровня шумов, промывкой изделий после пайки и отдельно разберем, как отличить поддельный ИП Traco от оригинала.
ну тогда не ленись, сходи на казус и почитай ЧаВо по протезу  ответ найдешь буквально на 2..3 странице.
пересказывать его лениво.
Популярные пружинные клеммники Degson со склада Компэл
Пружинные разъемные клеммники Degson с технологией Push-In обеспечивают надежное и безопасное электрическое соединение. При их использовании исключается возможность короткого замыкания в точке контакта, что гарантирует надежное соединение. Электрическая безопасность клеммных блоков подтверждается соответствием мировым стандартам UL, IEC и VDE.
5 минут назад, IMXO сказал:
Простите, я сюда пришел с рассчетом, что мне объяснят хоть, как это сделать, куда нажать и т д. Мне буквально ещё 2 работы и все, больше я не потревожу глупыми вопросами
4 минуты назад, IMXO сказал:
Это конечно очень интересно, но времени нет изучать все это, мне были даны 6 работ, 4 из которых я смог выполнить, а 2 - нет. Сейчас нужно решить проблему с этой работой, а завтра я создам ещё 1 тему и уже пойду сдавать портфолио
Датчики дальности ST обеспечивают безопасность в период COVID-19
Оптические датчики приближения STMicroelectronics из семейства Flight Sense™, средства разработки и программное обеспечение для них позволяют как организовать бесконтактную работу торговых и информационных точек и соблюдение социальной дистанции в непростой эпидемический период, так и строить сложные пространственные системы вплоть до трехмерных моделей. Рассмотрим устройство для обнаружения и измерения расстояний до объектов без физического контакта, и инструментарий для его разработки, а также другие примеры.
1 час назад, Sambler сказал:
Считаете, что у нас оно есть, для обучения Вас Протеусу ? :)
По нему в сети просто море информации. На любой вопрос можно найти ответ. Главное - не лениться...
Дам Вам совет. Скажите тому, кто Вам дал эти работы, что Вы не разбираетесь в Протеусе ничерта. За это двойку не поставят :)
И пообещайте, что сделаете это всё в железе. Вы же сможете это сделать, не зря же учились ? Не правда ли ? :)
8 часов назад, Alex сказал:
Так именно таким способом и происходит обучение программы. В прошлом семестре Orcad Caoture, я так же ничего не знал, так же ходил и спрашивал( хотя она на много легче ) и сейчас я многим работы делаю за деньги.
Я не прошу вас обучать всей программе, я просто прошу подсказать ту маленькую деталь, где и что мне нужно сделать, хотя бы название ее и дальше я уже сам пойду разбираться и изучать
Я вот серьезно не понимаю, мы со вчера оффтопим и засоряем тему, в место того, что бы просто сказать, что не так и как исправить, я уже понял, что проблема с подключением связана, но я не знаю как мне загуглить "как в соединении схемы добавить буквы" я не понимаю, потому что не учити.
А сказать препода, что я не шарю в программе? Серьезно? Это то же самое, что сказать, чтотя не шарю в ассемблере, я его не учил и не буду, оно мне не нужно и в жизни вряд ли пригодится. Образование в Молдове у нас такое... Тем более в колледже мы первая группа с такой профессией, можно сказать на нас тестируют все
В чем принципиальное отличие твоей и моей картинки?
26 минут назад, 100482 сказал:
В гайдах нашел Property Assigment Tools инструмент. Сегодня попробую его использовать, Надеюсь получится
Edited by Sambler
12 часов назад, IMXO сказал:
Хорошо, я посмотрел гайды, нашел Property Assigment Tools.
Попробую сегодня обязательно. Надеюсь получится.
И ждите от меня еще 1 тему)) потому что, там задание с 7ми сегментными, когда код запускаю, выдает циклично кучу ошибок, что аж система лагает и приходится принудительно закрывать программу.
Такая простая схема.... зачем там шины? Провел бы эти нещастные 16 проводков зато всё заработало бы сразу. А так... вы повторяете схемы не понимая в чём суть. Просто повторяете некие магические действия. А смысл - то соединить точки проводами. Как это сделать - второй вопрос. В той схеме нет смысла применять шины.
51 минуту назад, Alexeyslav сказал:
Это вы скажите преподавателю, который выдавал мне задание.
И вообще, почему все только осуждают меня, а как сделать - никто не говорит, это что, на столько сложно? да ту же ссылку на гайд кинуть....
29 минут назад, Sambler сказал:
чел, да ты офигел, я тебе ссылку еще в пост5 кинул, там твой вАпрос разжеван полностью , то что тебе его читать лень это твои проблемы.
3 минуты назад, IMXO сказал:
ГОнишь??? я уже давно нашел и сделал всё. Я запускаю и на этом 7мисегм. ничего не отображается, хотя процесс идёт, как видно на скрине:
гонят дерьмо по трубам, а быковать перед мамой с папой  будешь.
еще раз говорю читай там все разжевано и это тоже.
Я тебе так ответил, потому что ты грубо ответил мне,  не нужно сейчас разжигать конфликт, попрошу правила соблюдать, вы всё таки модератор.
И если я не 40 летний дяденька, не означает, что можно упоминать родителей, указывая тем самым, что мне меньше 10.
6 минут назад, IMXO сказал:
ЧТО разжевано? почему не отображается на индикаторе ничего? ГДЕ, я не вижу где это написано.... Там целая книга, у меня времени нет всё прочесть, и вообще, мне это не нужно, мне закончить эту работу и сдать, ВСё, так трудно помочь что ли? Я понимаю, что все тут эксперты и за бесплатно помогаете, Но раз вы решились на это, почему я должен быть исключением?
Я не хочу изучать, мне просто нужно решить мою проблему и сдать, всё. А вы меня заставляете самостоятельно изучать всю программу, которая мне никогда не пригодится и потратить  на это уйму часов, которых у меня нет. Помимо протеуса, мне еще в Оркаде схемы создавать, Лайоуте.
Я не виноват, что в этом семестре наше государство решило дать нам в изучение ПРОТЕУС.
вот и соблюдай.
индикатор не светится в двух случаях:
1. ты его исключил из симуляции
2. называется Minimum Trigger Time , но что это и зачем по ссылке ты не прочитал , еще раз повторю:  тебе его читать лень это твои проблемы.
2 минуты назад, IMXO сказал:
Понимаете в чем проблема, вы мне не хотите говорить что это, а заставляете читать ВСЁ, ВЕСЬ ГАЙД, зачем? укажите направление и я пойду по нему......
Да просто поменяйте свой дисплей на 7SEG-MPX8-CC-BLUE и всё у Вас получится.
Спасибо, я пробовал менять на 100мс, не изменялось ничего, поставил 1us и вроде заработал, но не так как нужно, сейчас буду играть с частотой еще))image.png.3a7066050a110a2d18eaf28a5f9b809c.png
6 минут назад, x-revers сказал:
чел, вся работа с дисплеем описана всего на трех страницах. предлагаешь лично для тебя сюда сделать копипаст?
ВСЁ, Я решил проблему, правда, оно всё равно странно работает и проблема в том, что я даже не знаю как она должна работать, но думаю, раз отображение есть, то уже хорошо))image.png.be08ecd4695100fe95a4eed3d72c49a5.png
Офигеть!!! Вы посмотрите в конец исходного кода. Там в комментариях написано что должно отображаться на дисплее: Error666
4 минуты назад, x-revers сказал:
Вы гений? я бы никогда не допер до этого))))) и почему нигде не было сказано, что нужно СС использовать..... Пойду завтра преподавателю предъявлю за это. Благодарю!
ТЕМУ МОЖНО ЗАКРЫВАТЬ!
p,s, ждите от меня еще 1 тему, мне последняя работа осталась
