Структура, указатель на структуру, во FLASH
GalatZ
Здравствуйте, разбираюсь с проектом меню Отсюда, при компиляции ругается на размещение во FLASH, не понимаю, что нужно исправить, читал форумы и пытался найти решение сам, не получается.
typedef struct PROGMEM{
	void       *Next;
	void       *Previous;
	void       *Parent;
	void       *Child;
	uint8_t     Select;
	const char  Text[];
} menuItem;
menuItem *selectedMenuItem; // текущий пункт меню
menuItem* menuStack[10];
volatile uint8_t menuStackTop;
#define MAKE_MENU(Name, Next, Previous, Parent, Child, Select, Text) \
    extern menuItem Next;     \
	extern menuItem Previous; \
	extern menuItem Parent;   \
	extern menuItem Child;  \
	menuItem Name = {(void*)&Next, (void*)&Previous, (void*)&Parent, (void*)&Child, (uint8_t)Select, { Text }}
#define PREVIOUS   ((menuItem*)pgm_read_word(&selectedMenuItem->Previous))
#define NEXT       ((menuItem*)pgm_read_word(&selectedMenuItem->Next))
#define PARENT     ((menuItem*)pgm_read_word(&selectedMenuItem->Parent))
#define CHILD      ((menuItem*)pgm_read_word(&selectedMenuItem->Child))
#define SELECT		(pgm_read_byte(&selectedMenuItem->Select))
char strNULL[] PROGMEM = "";
#define NULL_ENTRY Null_Menu
menuItem  Null_Menu = {(void*)0, (void*)0, (void*)0, (void*)0, 0, {0x00}};
//        NAME      NEXT,      PREVIOUS     PARENT,     CHILD
MAKE_MENU(m_s1i1,  m_s1i2,    NULL_ENTRY,  NULL_ENTRY, m_s2i1,       0, "Start");
MAKE_MENU(m_s1i2,  m_s1i3,    m_s1i1,      NULL_ENTRY, m_s3i1,       0, "Settings");
MAKE_MENU(m_s1i3,  NULL_ENTRY,m_s1i2,      NULL_ENTRY, NULL_ENTRY,   MENU_RESET, "Reset");
// подменю Запуск
MAKE_MENU(m_s2i1,  m_s2i2,    NULL_ENTRY,  m_s1i1,     NULL_ENTRY,   MENU_MODE1, "Mode 1");
MAKE_MENU(m_s2i2,  m_s2i3,    m_s2i1,      m_s1i1,     NULL_ENTRY,   MENU_MODE2, "Mode 2");
MAKE_MENU(m_s2i3,  NULL_ENTRY,m_s2i2,      m_s1i1,     NULL_ENTRY,   MENU_MODE3, "Mode 3");
// подменю Настройка
MAKE_MENU(m_s3i1,  m_s3i2,    NULL_ENTRY,  m_s1i2,     m_s4i1,       0, "Pressure");
MAKE_MENU(m_s3i2,  NULL_ENTRY,m_s3i1,      m_s1i2,     m_s5i1,       0, "Time");
... и тд.
Error		variable 'strNULL' must be const in order to be put into read-only section by means of '__attribute__((progmem))'	test_menu
Error		variable 'Null_Menu' must be const in order to be put into read-only section by means of '__attribute__((progmem))'	test_menu
Error		variable 'm_s1i1' must be const in order to be put into read-only section by means of '__attribute__((progmem))'	test_menu
.. и т.д.
14.04.2020 в 20:18, GalatZ сказал:
Здесь возможно ошибка синтаксиса
strNULL[] похоже на массив каждый элемент которого должен быть типом описанным структурой
    void       *Next;
    void       *Previous;
    void       *Parent;
    void       *Child;
    uint8_t     Select;
    const char  Text[];
} menuItem;
и может быть получится если, как то так.....
menuItem strNULL[] PROGMEM="";
хотя как компилятор будет понимать, что такое PROGMEM="";
Я не силён в программировании, поэтому это только домыслы. Может Вам стоит обратиться к автору сего кода в источнике для пояснения этой записи.
остальные ошибки вытекающие из непонимания этой записи.
http://radio-hobby.org/modules/instruction/winavr-i-avr-studio/struktury-i-obyedineniya
может, что-то прояснит.
Спасибо за помощь, разобрался, должно быть вот так:
	void       *Next;
	void       *Previous;
	void       *Parent;
	void       *Child;
	uint8_t     Select;
	const char  Text[];
} menuItem;
//menuItem* menuStack[10];
//volatile uint8_t menuStackTop;
// Externs:
extern menuItem const      Null_Menu;
menuItem const   Null_Menu = {(void*)0, (void*)0, (void*)0, (void*)0, 0, {0x00}};
// Defines and Macros:
    extern menuItem const Next;     \
	extern menuItem const Previous; \
	extern menuItem const Parent;   \
	extern menuItem const Child;  \
	menuItem const Name = {(void*)&Next, (void*)&Previous, (void*)&Parent, (void*)&Child, (uint8_t)Select, { Text }}
//char strNULL[] PROGMEM = "";
//#define NULL_ENTRY Null_Menu
//menuItem  Null_Menu = {(void*)0, (void*)0, (void*)0, (void*)0, 0, {0x00}};
Все компилируется и работает:
Изменено пользователем GalatZ
16.04.2020 в 10:06, AL_smeu сказал:
просмотрел весь проект, вообще нигде не нашёл использование этого элемента strNULL.
факт подтвердился, эта переменная не нужна вообще?
DI HALT намудрил?!
Вся иерархия меню хранится в ОЗУ? Расточительно, однако...
