Помогите стартонуть с Pic на Си
LiSiY5
Ребята помогите, Я начинаю изучение Pic и не могу создать первую прогу. Сам программирую на LD, FBD, ASM, но тут не могу стартонуть, с выходами все получается, а вот с входами проблемка. Есть код на Си, подскажите в чем ошибка. Буду очень благодарен любой информации.
// PIC16F18877 Configuration Bit Settings
// 'C' source line config statements
// CONFIG1
#pragma config FEXTOSC = HS     // External Oscillator mode selection bits (HS (crystal oscillator) above 4MHz; PFM set to high power)
#pragma config RSTOSC = EXT1X   // Power-up default value for COSC bits (EXTOSC operating per FEXTOSC bits)
#pragma config CLKOUTEN = OFF   // Clock Out Enable bit (CLKOUT function is disabled; i/o or oscillator function on OSC2)
#pragma config CSWEN = ON       // Clock Switch Enable bit (Writing to NOSC and NDIV is allowed)
#pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enable bit (FSCM timer enabled)
// CONFIG2
#pragma config MCLRE = ON       // Master Clear Enable bit (MCLR pin is Master Clear function)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
#pragma config LPBOREN = OFF    // Low-Power BOR enable bit (ULPBOR disabled)
#pragma config BOREN = ON       // Brown-out reset enable bits (Brown-out Reset Enabled, SBOREN bit is ignored)
#pragma config BORV = LO        // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (VBOR) set to 1.9V on LF, and 2.45V on F Devices)
#pragma config ZCD = OFF        // Zero-cross detect disable (Zero-cross detect circuit is disabled at POR.)
#pragma config PPS1WAY = ON     // Peripheral Pin Select one-way control (The PPSLOCK bit can be cleared and set only once in software)
#pragma config STVREN = ON      // Stack Overflow/Underflow Reset Enable bit (Stack Overflow or Underflow will cause a reset)
// CONFIG3
#pragma config WDTCPS = WDTCPS_31// WDT Period Select bits (Divider ratio 1:65536; software control of WDTPS)
#pragma config WDTE = ON        // WDT operating mode (WDT enabled regardless of sleep; SWDTEN ignored)
#pragma config WDTCWS = WDTCWS_7// WDT Window Select bits (window always open (100%); software control; keyed access not required)
#pragma config WDTCCS = SC      // WDT input clock selector (Software Control)
// CONFIG4
#pragma config WRT = OFF        // UserNVM self-write protection bits (Write protection off)
#pragma config SCANE = available// Scanner Enable bit (Scanner module is available for use)
#pragma config LVP = ON         // Low Voltage Programming Enable bit (Low Voltage programming enabled. MCLR/Vpp pin function is MCLR.)
// CONFIG5
#pragma config CP = OFF         // UserNVM Program memory code protection bit (Program Memory code protection disabled)
#pragma config CPD = OFF        // DataNVM code protection bit (Data EEPROM code protection disabled)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
#define _XTAL_FREQ 20000000
void main(void) {
    TRISB=0;
    PORTB=0;
    TRISA=11111111;
    PORTA=11111111;
    TRISA=11111111;
    if(PORTAbits.RA0 == 1) { RB0 = 1;}
    return;
я дико извиняюсь , а вы вкуда по return выйти пытаетесь?.
первый раз вижу чтобы стартовали с F18877 .... у мня даже компилятор о нем не знает :)
а так любой код на Си
выглядит
void main(void)
  // секция инициализации МК
while(1)
  // здесь основной код
  // в бесконечном цикле
} // end while(1)
}// end main
if(PORTAbits.RA0 == 1) { RB0 = 1;}  записывается как
if(PORTbits.RA0) { LATBbits.LATB0=1;}
PS выкладывая код пользуйтесь тегами КОД:  <> на панели сообщений
Увы не получается, может у кого то есть код на данный контроллер на Си или ассемблере с конфигурационными байтами. Первый код хочу по входу А0 включается выход В0.
3 часа назад, LiSiY5 сказал:
Увы не получается.
Что конкретно не получается? Если речь идет о первоначальном коде, то там написана ахинея. Вам сказали выше, что проверку нужно делать В БЕСКОНЕЧНОМ ЦИКЛЕ. Вы зачем то вставили return... Вы знаете что такое return в Си?
戦う前に相手のベルトの色に注目
5 часов назад, LiSiY5 сказал:
и что это Вам даст? конфигирация пишется под обвязку МК и применяемый программатор , в соответствии с описанием компилятора
можно конечно попробовать помочь , от Вас  html на МК с описанием битов конфигурации из папки доков компилятора, инклюд , схема обвязки МК , и модель программатора и метод програмирования.
28.08.2020 в 18:49, IMXO сказал:
Спрыгиваю на более простой МК PIC16F877A, использую програматор РicKit3, компилятор ХС8, программа MPLAB X IDE, биты конфигурации:
// CONFIG
#pragma config FOSC = HS        // Oscillator Selection bits (HS oscillator)
#pragma config WDTE = OFF       // Watchdog Timer (WDT disabled)
#pragma config PWRTE = ON       // Power-up Timer Enable bit (Power-up Timer is enabled)
Хочу программу, при RA0==1 включается RB0=1.
Подскажите пожалуйста.
Изменено пользователем LiSiY5
#include <xc.h>	// Required to interface with delay routines
// __CONFIG(LVPDIS & WDTEN & PWRTEN & BORDIS & HS);
// CONFIG
#pragma config LVP = OFF
void init(void)
 INTCON = 0;
 PIE1 = 0;
 ADCON1 = 0b00000111; // Цифровые выводы
 TRISA = 0b11111111; //входы
 TRISB = 0; // выходы
 TRISC = 0b11111111;
 TRISD = 0;
 PORTA = 0;
 PORTB = 0;
 PORTC = 0;
 PORTD = 0;
 OPTION = 0b00000000;
void main (void)
init();
while(1)
      if(PORTAbits.RA0)
	     { PORTBbits.RB0=1;}
	   else
	     { PORTBbits.RB0=0;}
// можно еще так записать
      	PORTBbits.RB0= PORTAbits.RA0;
	} // end while(1)
Задачка стала по-сложнее, надо организовать АЦП преобразователь, кто то работал? Подскажите, а то с Google не могу договориться. Исходные конфигурационные данные и обвязку прилагаю(работа: по изменению потенциала на AN0 меняются выходы RB0-RB7). Всем спасибо за помощь.
// PIC16F877A Configuration Bit Settings
// CONFIG
#pragma config WDTE = ON        // Watchdog Timer Enable bit (WDT enabled)
#pragma config PWRTE = ON       // Power-up Timer Enable bit (PWRT enabled)
#pragma config BOREN = ON       // Brown-out Reset Enable bit (BOR enabled)
#pragma config LVP = ON         // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3/PGM pin has PGM function; low-voltage programming enabled)
#pragma config CPD = OFF        // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
#pragma config WRT = OFF        // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
#pragma config CP = OFF         // Flash Program Memory Code Protection bit (Code protection off)
#include <xc.h>
ADC.PDF
4 часа назад, LiSiY5 сказал:
шикарное описание... Вы точно программист?
void init_ADC_AN0 (void)
	TRISA |= (1<<0); // RA0 = input;
	ADCON1 0b10001110; // RA0(AN0) = analog input;
	ADCON0 = 0b11000001; // Fadc=Fosc/32; AN0; ADC=ON;
unsigned int ReadADC_AN0(void)
{ static unsigned char s_ucCount;
  static unsigned int  m_TempResalt[32];
  static unsigned int  s_uiSymm;
  s_ucCount++;
  s_ucCount&=0b00011111;
  s_uiSymm -= m_TempResalt[s_ucCount];
  __delay_us(20);
  ADCON0bits.GO_DONE=1;
  while(ADCON0bits.GO_DONE) continue;
  __delay_us(5);
  m_TempResalt[s_ucCount] = ADRESH;
  m_TempResalt[s_ucCount]<<=8;
  m_TempResalt[s_ucCount]+= ADRESL;
  s_uiSymm += m_TempResalt[s_ucCount];
  return s_uiSymm/32;
Разрешите объяснить, Я хочу полный код под мои конфигурационные биты на Pic16f877a. Мне необходимо получить переменную, назовем ADC, которая меняет значение от 0 до 1023, при изменении напряжения на входе AN0 от 0В до 5В. Далее сравнивая переменную с задаными const постараюсь получить на выходе то что задумано. Не судите строго, после перенесенного менингита сложно все вспоминаеться...
