Гирлянда на ATMEGA16 и С
tifaso
Решил собирать новогоднюю гирлянду и за основу взял микросхему ATMEGA16 прошивку пишу на си. Задумка хорошая вроде как даже получается, но есть одна вещь которую я так и не могу понять.
Вот в общем схема и код прошивки (код ещё не дописан).
Код прошивки:
#define F_CPU 1000000UL
#include <avr/io.h>
#include <util/delay.h>
volatile unsigned char power=0;
volatile unsigned char menu=0;
int main(void)
	DDRA = 0b11110000;
	DDRB = 0b00000000;
	DDRC = 0b11111111;
	DDRD = 0b11111111;
	PORTA = 0b00001111;
	PORTB = 0b11111111;
	PORTC = 0b00000000;
	PORTD = 0b10000000;
    while(1)
        if (~PINB & (1<<0))
			while(~PINB & (1<<0));
			if (PINC)
				PORTD = 0b10000000;
				PORTC = 0b00000000;
				PORTA &= ~((1<<4)|(1<<5)|(1<<6)|(1<<7));
				power=0;
			else
				PORTD &= ~(1<<7);
				PORTC |= (1<<0);
				power=1;
		if (power==1)
			if (~PINB & (1<<1))
				PORTC |= (1<<1);
				PORTC &= ~((1<<2)|(1<<3)|(1<<4)|(1<<5)|(1<<6)|(1<<7));
				menu=1;
			if (~PINB & (1<<2))
				PORTC |= (1<<2);
				PORTC &= ~((1<<1)|(1<<3)|(1<<4)|(1<<5)|(1<<6)|(1<<7));
				menu=2;
			if (~PINB & (1<<3))
				PORTC |= (1<<3);
				PORTC &= ~((1<<1)|(1<<2)|(1<<4)|(1<<5)|(1<<6)|(1<<7));
				menu=3;
			if (~PINB & (1<<4))
				PORTC |= (1<<4);
				PORTC &= ~((1<<1)|(1<<2)|(1<<3)|(1<<5)|(1<<6)|(1<<7));
				menu=4;
			if (~PINB & (1<<5))
				PORTC |= (1<<5);
				PORTC &= ~((1<<1)|(1<<2)|(1<<3)|(1<<4)|(1<<6)|(1<<7));
				menu=5;
			if (~PINB & (1<<6))
				PORTC |= (1<<6);
				PORTC &= ~((1<<1)|(1<<2)|(1<<3)|(1<<4)|(1<<5)|(1<<7));
				menu=6;
			if (~PINB & (1<<7))
				PORTC |= (1<<7);
				PORTC &= ~((1<<1)|(1<<2)|(1<<3)|(1<<4)|(1<<5)|(1<<6));
				menu=7;
			if (~PINA & (1<<0))
				PORTA |= (1<<4);
				PORTC &= ~((1<<1)|(1<<2)|(1<<3)|(1<<4)|(1<<5)|(1<<6)|(1<<7));
				PORTA &= ~((1<<5)|(1<<6)|(1<<7));
				menu=8;
			if (~PINA & (1<<1))
				PORTA |= (1<<5);
				PORTA &= ~((1<<4)|(1<<6)|(1<<7));
				menu=9;
			if (~PINA & (1<<2))
				PORTA |= (1<<6);
				PORTA &= ~((1<<4)|(1<<5)|(1<<7));
				menu=10;
			if (~PINA & (1<<3))
				PORTA |= (1<<7);
				PORTA &= ~((1<<4)|(1<<5)|(1<<6));
				menu=11;
			if (menu==1)
				PORTD |= (1<<0);
				PORTD &= ~((1<<1)|(1<<2)|(1<<3)|(1<<4)|(1<<5)|(1<<6));
				_delay_ms(300);
				PORTD |= (1<<1);
				PORTD &= ~((1<<0)|(1<<2)|(1<<3)|(1<<4)|(1<<5)|(1<<6));
				_delay_ms(300);
				PORTD |= (1<<2);
				PORTD &= ~((1<<0)|(1<<1)|(1<<3)|(1<<4)|(1<<5)|(1<<6));
				_delay_ms(300);
				PORTD |= (1<<3);
				PORTD &= ~((1<<0)|(1<<1)|(1<<2)|(1<<4)|(1<<5)|(1<<6));
				_delay_ms(300);
				PORTD |= (1<<4);
				PORTD &= ~((1<<0)|(1<<1)|(1<<2)|(1<<3)|(1<<5)|(1<<6));
				_delay_ms(300);
				PORTD |= (1<<5);
				PORTD &= ~((1<<0)|(1<<1)|(1<<2)|(1<<3)|(1<<4)|(1<<6));
				_delay_ms(300);
				PORTD |= (1<<6);
				PORTD &= ~((1<<0)|(1<<1)|(1<<2)|(1<<3)|(1<<4)|(1<<5));
				_delay_ms(300);
			if (menu==2)
				PORTD |= (1<<0);
				_delay_ms(300);
				PORTD |= (1<<1);
				_delay_ms(300);
				PORTD |= (1<<2);
				_delay_ms(300);
				PORTD |= (1<<3);
				_delay_ms(300);
				PORTD |= (1<<4);
				_delay_ms(300);
				PORTD |= (1<<5);
				_delay_ms(300);
				PORTD |= (1<<6);
				_delay_ms(300);
				PORTD &= ~(1<<0);
				_delay_ms(300);
				PORTD &= ~(1<<1);
				_delay_ms(300);
				PORTD &= ~(1<<2);
				_delay_ms(300);
				PORTD &= ~(1<<3);
				_delay_ms(300);
				PORTD &= ~(1<<4);
				_delay_ms(300);
				PORTD &= ~(1<<5);
				_delay_ms(300);
				PORTD &= ~(1<<6);
			if (menu==3)
				PORTD |= ((1<<0)|(1<<6));
				_delay_ms(300);
				PORTD |= ((1<<1)|(1<<5));
				_delay_ms(300);
				PORTD |= ((1<<2)|(1<<4));
				_delay_ms(300);
				PORTD |= (1<<3);
				_delay_ms(300);
				PORTD &= ~((1<<0)|(1<<6));
				_delay_ms(300);
				PORTD &= ~((1<<1)|(1<<5));
				_delay_ms(300);
				PORTD &= ~((1<<2)|(1<<4));
				_delay_ms(300);
				PORTD &= ~(1<<3);
				_delay_ms(300);
А в чём заключается проблема при подаче питания и не зависимо от каких либо нажатий кнопок на некоторые ножки микросхемы (ножки 24, 25, 27) прилетает +5V  там где впринцепи их не должно быть при запуске. Проверял мультиметром на плате всё в норме нигде не подкорачивает всё на своих местах да плюсовая дорожка там далеко.
Насчёт кода не знаю, но схема - жесть. Реле-то в ней нафига? Да ещё и питается всё это от одного источника без единого конденсатора даже.
@Dr. West По поводу кондёров на схеме как то не обозначил, но в реале на входе питания стоят на 0.1 uF и элекролит на 680uF. А реле поставил так как побоялся что будет слишком большая нагрузка на микросхему ведь туда планируется подключить по 20 светодиодов на каждый канал (вывод микросхемы) не знаю достаточно ли будет если оставить только транзисторные ключи. Кстати по поводу питания питается всё это от блока питания на 5V 2A.
Изменено пользователем tifaso
28 минут назад, tifaso сказал:
Достаточно. Только ключи нужно выбрать соответствующие (с учетом тока, потребляемого желаемым букетом светодиодов). С реле схема схема приобретает юмористические черты.
Задача вывода МК - обеспечить базовый ток насыщения транзисторного ключа, а это доли - единицы мА. А сам ключ можно поставить какой угодно мощности, хоть на 100 Ампер.
Если, допустим, 20 светодиодов, по 20 мА, в сумме 0,4 Ампера. Такой ток влёгкую потянет любой транзистор средней мощности типа КТ815 и подобные. А чтобы уж совсем не грузить выходы МК, можно поставить ключи на составных транзисторах.
А если светодиодов в каждом канале помногу, то выгодней их запитать от более высокого напряжения, заодно сэкономив кучу резисторов.
С реле же только проблемы будут, и щёлканье постоянное - оно надо?
Двухтранзисторные биполярные ключи в схемах на микроконтроллере
3 часа назад, tifaso сказал:
Неоднократно мною было замечено, что на китайских атмегах активным должен быть "0", Если активная "1", то светодиод светит всегда. Т.е. светодиод анодом подключаем к питанию, а катодом к контроллеру и меняем прошивку. При чем все светодиоды, и не только их, а и транзисторные ключи тоже, т.е. меняем проводимость транзисторов.
Изменено пользователем makcucm8
Сомневаюсь, что такое возможно даже на "китайких" микросхемах. Проверяйте состояние внутренней подтяжки "наверх". Тамошнего тока вполне достаточно, чтобы засветить светодиод.
Quote
Ну, если заменить контроллер на шаговый искатель, сочинить генаратор импульсов на электромашинном принципе, а вместо светодиодов воспользоваться какой-нибудь вакуумной индикацией (чуть светящиеся лампы накаливания начала прошлого века будут самое то), то получится брутальный агрегат в стим-панк стиле. :-D
Изменено пользователем El-Shang
@makcucm8 Ну так да я изначально в коде все светодиоды выставляю в ноль и только при нажатии кнопки или выполнения условия светодиод должен включится, но тут какая то таинственная загадка для меня с этим. И оно вообще не реагирует ни на что Там всё время сидит +5V.
@Dr. West Так как у меня уже всё собрано на чистовую и переделывать хотелось бы с минимальными затратами нашёл сейчас у себя транзисторы 2N4401 распиновка у них похожая да и по характеристикам помощнее BC547. Да и мою гирлянду должно потянуть. Поэтому я просто заменю транзисторы в ключах и уберу все реле.
@El-Shang Попробую проверить. Ну как подтянуть вывод к нулю изначально? Если вроде как в коде я это выставил, но оно не действует.
Потянет, хоть и на пределе. Базовые резисторы только придётся уменьшить раза в 3.
з.ы. Может, МК элементарно, битый. Сделайте тестовую прошивку, где ничего другого не делается, а МК только дрыгает ногами,  с интервалом, например 1 секунда.
@Dr. West И на какое сопротивление резисторы ставить? Если уменьшить раза в 3 я так понимаю на 330 ОМ будут в самый раз.
А это реально мысль написать тестовую прошивку и проверить микросхему. Одна кстати вообще мёртвая попалась программатором ошибку била. Остальные не знаю есть ещё четыре проверю. Возможно реально микросхема побитая.
@tifaso, вчитался в Ваш сам первый пост. :-) Я полагаю, что Вам достаточно отключить в фьюзах JTAG. Ножки 24, 25, 26 и 27 как раз для него и выделены (линии TCK, TMS, TDO и TDI соответственно).
@El-Shang Попробую такой вариант применить.
В фьюзах есть только JTAGEN это оно? просто ничего больше похожего нету.
56 минут назад, El-Shang сказал:
Делал проект на атмеге 8, динамическая индикация с общим анодом, при определенных условиях должен засветиться светодиод, на выходе "1". Так вот когда он светится на индикаторах непонятно что, не работают анодные ключи, всегда открыты. Физически отключил светодиод, проверил выход контроллера, "1" присутствует, индикация нормальная. Подключаю все назад, опять тоже самое. Заменил в прошивке режим работы вывода на светодиод, активный стал "0", перевернул светодиод и подключил анод к питанию, все работает нормально.
11 минут назад, makcucm8 сказал:
Светодиод через резистор был включен?
Ну я не ванга и без кода и схемы "определенные условия" представить не могу, увы. :-)
А лучше на мосфетах
Для людей, которые пишут "мФ" вместо "мкФ", в аду приготовлен отдельный котёл. 1 мФ = 1000 мкФ.
8 часов назад, tifaso сказал:
DDRC = 0b11111111;
измени на DDRC=0b00000000;
if (~PINB & (1<<0))
проверка бита на ноль  if (~(PINB & (1<<0))) , а не  if (~PINB & (1<<0))
зачем тут volatile?
6 часов назад, Bobius сказал:
А лучше на мосфетах
Мосфетов, да ещё низковольтных, у автора наверняка нет, а покупать он не любит, делает из того что есть.
1 час назад, Dr. West сказал:
мог бы на материнках надергать .... коих у каждого мусорного бака найти можно ....
@El-Shang Спасибо при отключении  JTAGEN в фьюзах +5 вольт ушли и теперь эта часть работает как и должна.
@Dr. West Сделал всё так убрал реле, заменил транзисторы на 2N4401 и резисторы на 330 ом. Но вот в чём суть через ключи напруга не проходит. Промерял мультиметром в разных точках на выходах микросхемы напруга появляется как и положено 5 вольт, но после резистора остаётся всего лишь 0.7 вольта, а в коллекторе транзистора вообще по нолям.
Так и должно быть, транзистор открыт. Нагрузку к коллектору присоединил? :)
Угу, если на "открытом коллекторе" пытаться измерять напряжение, там и должен быть ноль. Транзистор в данном случае никуда не "подаёт напругу", а замыкает цепь через нагрузку от шины плюсового питания на общий провод.
Светодиод другим концом куда подключен?
