Guest Сергей
Считывание содержимого веб страницы Arduino
Guest Сергей
Есть ардуино мега и интернет шилд. Использую готовый скетч WebClient для подключения к веб странице, на выходе получаю вот такой ответ. Как получить реальное содержимое страницы, вместо этого?
b9
<html>
<head><title>301 Moved Permanently</title></head>
<body bgcolor="white">
<center><h1>301 Moved Permanently</h1></center>
<hr><center>nginx/1.12.2</center>
</body>
</html>
0
disconnecting.
На всякий случай код скетча из вебклиента
  Web client
 This sketch connects to a website (http://www.google.com)
 using an Arduino Wiznet Ethernet shield.
 Circuit:
 * Ethernet shield attached to pins 10, 11, 12, 13
 created 18 Dec 2009
 by David A. Mellis
 modified 9 Apr 2012
 by Tom Igoe, based on work by Adrian McEwen
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128);  // numeric IP for Google (no DNS)
char server[] = "4cloud.pro";    // name address for Google (using DNS)
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 3, 153);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
void setup() {
  // Open serial communications and wait for port to open:
  Serial.begin(9600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // try to congifure using IP address instead of DHCP:
    Ethernet.begin(mac, ip);
  // give the Ethernet shield a second to initialize:
  delay(1000);
  Serial.println("connecting...");
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
    Serial.println("connected");
    // Make a HTTP request:
    client.println("GET / HTTP/1.1");
    client.println("Host: www.4cloud.pro");
    client.println();
  } else {
    // if you didn't get a connection to the server:
    Serial.println("connection failed");
void loop() {
  // if there are incoming bytes available
  // from the server, read them and print them:
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println();
    Serial.println("disconnecting.");
    client.stop();
    // do nothing forevermore:
    while (true);
В скече обновить ссылки на страницу. Старая была удалена или перемещена в другое место.
Повышаем уровень передаваемой мощности в однопарной сети Ethernet
В статье приведено описание новых гибридных разъемов для использования в SPE-приложениях. По сравнению с традиционными разъемами, в основе структуры которых лежит технология PoDL (Power over Data Line), предлагаемое решение содержит в себе дополнительные контакты питания, но сохраняет при этом компактные размеры. А работа с более высокими значениями тока значительно расширяет возможности применения предлагаемых разъемов в различных топологиях, по сравнению с PoDL.
    • тут https://speakerboxlite.com/ru/manufacturers/shared можно подобрать, база достаточно актуальная, и посчитать сразу если даташиту доверяете, у приличных производителей с этим всё нормально.
    • В том то и дело - что ничего особо не сказал)  Много места занимает зараза) кому как - дело хозяина.
    • Больше на К73-9 похож.
    • Кстати на счёт 2161 надо подумать над этим и еще ТГР притулить Ну пластинка из кусочка алюминия меня не тяготить да и спокойней мне...
    • Это только кажется, что если сместить напряжение, то будет точнее. Чтобы точность как минимум не ухудшилась, смещение (фактически - вычитание) надо делать с точностью не хуже единицы младшего разряда АЦП. Прикиньте, какая точность нужна от источника напряжения смещения, от операционников. Посчитайте и сравните точность того, что вы делаете, с потерей 0,5 В в начале шкалы АЦП. Чтобы прикинуть в уме, вспомните, что использование только половины диапазона входного напряжения АЦП - это потеря всего одного младшего разряда в результате. Меняем шило на мыло, да ещё добавляем кучу деталей и недешёвый прецезионный ИОН... То, как вы хотите сделать, оправдано только если это по крайней мере не ухудшает точность. Вот например сместить и растянуть на весь диапазон АЦП напряжение плюс-минус 1 вольт около 12 (т.е. когда надо измерять только в диапазоне от 11 до 13 В), - тогда есть смысл так делать, если жаба не задушит поставить 0,1% ИОН и такой же точности резисторы. Прежде, чем бросаться трясти, полезно подумать.
    • Если собирать по феншую прямоход - дроссель  нужен, а если использовать резонанс - я думаю для умзч вполне можно обойтись ключами смд - вообще без радиаторов.
    • Признаюсь, я ожидал подобное предостережение от уважаемых коллег. Меня подвёл мой стаомодный и, можно сказать, реакционный консерватизм в отношении полов. Обещаю впредь быть бдительным.
  • Шаровый кран (латунь) с электроприводом DN15, DN20, DN25. Встроенный концевик.
