ОУ, компараторы, мультиплексоры, токовые датчики, радиаторы, корпуса, бл.пит. и т.д.
ОУ, ИОН, компараторы, супервизоры, резисторы, блоки питания, реле, корпуса, радиаторы и т.д.
Все микросхемы оригинал, китая нет. SMD
Список будет потихоньку обновляться, если нужна доп.инфо - пишите размещу фото, ссылки и проч.
Операционные усилители
AD600AR             300         Dual, Low Noise, Wideband Variable Gain Amplifiers
AD603AR             200         Low Noise, 90 MHz Variable Gain Amplifier
AD620                  200         Low Cost Low Power Instrumentation Amplifier
AD622AR             200         Low Cost Instrumentation Amplifier
AD627A               300         Single and Dual Supply Rail-to-Rail Instrumentation Amplifier
AD628                  200         A High Common-Mode Voltage, Programmable Gain Difference Amplifier
AD629A               200         High Common-Mode Voltage Difference Amplifier.
AD711                  100         Precision, LowCost, High Speed, BiFET Op Amp
AD712                  150         Precision, Low Cost, High Speed BiFET Dual Op Amp
AD713                  200         Quad Precision, Low Cost, High Speed, BiFET Enhanced Replacement for LF347, TL084
AD8008A             200         Ultralow Distortion, High Speed Amplifiers
AD8009                100         1 GHz, 5,500 V/mks Low Distortion Amplifier
AD8032                200         2.7 V, 800 mA, 80 MHz Rail-to-Rail I/O Amplifiers
AD8042                100         Dual 160 MHz Rail-to-Rail Amplifier
AD8052                100         Low Cost, High Speed, Rail-to-Rail Amplifiers
AD8058AR          100         Low Cost, High Performance Voltage Feedback, 325 MHz Amplifiers
AD8061A             100         Low-Cost, 300 MHz Rail-to-Rail Amplifiers
AD8132                100         Low Cost, High Speed Differential Amplifier
AD817                  100         High Speed, Low Power Wide Supply Range Amplifier
AD818                  100         Low Cost, Low Power Video Op Amp
AD822AR             200         Single-Supply, Rail-to-Rail  Low Power FET-Input Op Amp
AD823AR             200         Dual, 16 MHz, Rail-to-Rail FET Input Amplifier
AD8307                200         Low Cost DC-500 MHz, 92 Db Logarithmic Amplifier
AD847AR            250         High Speed, Low Power Monolithic Op Amp
AD8542ARZ        50           General-Purpose CMOS Rail-to-Rail Amplifiers
AD8626                150         Precision Low Power Single-Supply JFET Amplifiers
AD8627                150         Precision Low Power Single-Supply JFET Amplifiers
AD9617JR            200         Low Distortion, Precision, Wide Bandwidth Op Amp
INA155U             150         Single Supply Rail-to-Rail Output Instrumentation Amplifier
LM6142                100         17 MHz Rail-to-Rail Input-Output Operational Amplifiers
LM662                  100         CMOS Dual Amplifier Rail-to-Rail  Output Swing
LM837                  100         Low Noise Quad Operational Amplifier
LT1167                  300         Single Resistor Gain Programmable, Precision Instrumentation Amplifier
LT1211 [DIP8]   200         14MHz, 7V/μs, Single Supply Dual and Quad Precision Op Amps
LT1886                  200         Dual 700MHz, 200mA Operational Amplifier
MAX4167ESA    200         High-Output-Drive, Precision, Low-Power, Single-Supply, Rail-to-Rail I/O
MC34072             50           Single Supply 3.0 V to 44 V Operational Amplifiers
MC33202             50           Low Voltage, Rail-to-Rail Operational Amplifiers
MC33077             50           Operational Amplifier, Low Noise, Dual
MC34074             50           Single Supply 3.0 V to 44 V Operational Amplifiers
MXL1007             100         Low Noise Precision Op Amp
OP07C                  50           Precision Operational Amplifier
OP27G/OPA27  100         Low Noise, Precision Operational Amplifier
OP97F                  100         Low Power, High Precision Operational Amplifier
OPA177G            100         Precision Operational Amplifier
OPA132U            200         High-Speed FET-Input Operational Amplifiers
OP213F                200         Low Noise, Low Drift Single-Supply Operational Amplifiers
OP249G               150         Precision JFET High-Speed Amp, Improved Replacement for AD712,LT1057,OP215,TL072
OP291G               100         Micropower Single-Supply Rail-to-Rail Input/Output Op Amps
OP292G               200         Single-Supply Operational Amplifiers
OP184F                200         Precision Rail-to-Rail Input and Output Operational Amplifiers
OP484E                300         Precision Rail-to-Rail Input and Output Operational Amplifiers
OP462G               250         15 MHz Rail-to-Rail Operational Amplifiers
OPA2134UA       200         High Performance AUDIO OPERATIONAL AMPLIFIERS
OPA2234U          300         Low Power, Precision SINGLE-SUPPLY OPERATIONAL AMPLIFIERS
OPA2340UA       150         Single-Supply, Rail-to-Rail Operational Amplifiers
OPA2350UA       200         High-Speed, Single-Supply, Rail-to-Rail OPERATIONAL AMPLIFIERS
OPA2650/52/58                150         Wideband, Low Power Voltage Feedback OPERATIONAL AMPLIFIER
OPA2680U          250         Dual Wideband, Voltage Feedback OPERATIONAL AMPLIFIER With Disable
OPA2340UA       100         Single-Supply, Rail-to-Rail Operational Amplifiers MicroAmplifier
OPA620KU         200         Wideband Precision OPERATIONAL AMPLIFIER
OPA655U            200         Wideband, Unity Gain Stable, FET-Input Amplifier
OPA690/2690    100         Wideband, Voltage-Feedback Operational Amplifier With Disable
TLE2072C            200      Excalibur Low-Noise High-speed JFET-INPUT OP AMP
TL062                    50           Low Power J-FET Dual Amplifier
TL064                    50           Low Power J-FET Quad Amplifier
TL072                    50           Low-Noise FET-Input Operational Amplifiers
TL074                    50           Low-Noise FET-Input Operational Amplifiers
TL081,082,084   50           JFET-Input Operational Amplifiers
TLC2272               50
TS922i                   50           Rail-to-rail, high output current, Low distortion, Low noise amplifier
Токовые усилители
MAX471CSA, ESA 150     Precision, High-Side Current-Sense Amplifiers
MAX472ESA       150         Precision, High-Side Current-Sense Amplifiers
MAX4376F          100         High-Side Current-Sense Amplifiers with Internal Gain
Компараторы
MXL1016             200         Ultra-Fast Precision TTL Comparators
MAX9686            100         Very Fast TTL Output Comparators
LT1720                  200         4.5ns, Single Supply 3V/5V Comparators with Rail-to-Rail Outputs
AD8561                150         Ultrafast 7 ns Single Supply Comparator
LM6511                100         180 ns 3V Comparator
LM339                  10           Quad Differential Comparators
LM311                  10           Differential Comparator With Strobes
Источники опорного напряжения
REF195G              150         5V Precision Micropower, Low Dropout Voltage References
REF02C                 150         5V Precision Voltage Reference/Temperature Transducer
TL431 (SO8)       25           Adjustable  Precision Shunt Regulator
AD780AR             200         2.5 V/3.0 V High Precision Reference
MAX6193C         150         3.0 V Precision, Micropower, Low-Dropout Voltage References
MAX6198B         150         4.096 V Precision, Micropower, Low-Dropout Voltage References
Цифровые потенциометры
X9C104                 300         100k Digitally Controlled Potentiometer
X9C503                 300         50k Digitally Controlled Potentiometer
X9C103                 300         10k Digitally Controlled Potentiometer
X9C102                 300         1k Digitally Controlled Potentiometer
Температурные сенсоры
LM35D                 100         Precision Centigrade Temperature Sensor
TMP36F               100         Low Voltage Temperature Sensor
AD22100              150         Voltage Output Temperature Sensor with Signal Conditioning
LM35D                 100         Precision Centigrade Temperature Sensors
TMP01E, F          200         Low Power Programmable Temperature Controller
Аналоговые ключи, мультиплексоры
DG211                  150         Quad SPST CMOS Analog Switches
ADG408               150         LC2MOS 4-/8-Channel High Performance Analog Multiplexers
ADG409               150         LC2MOS 4-/8-Channel High Performance Analog Multiplexers
ADG419               200         LC2MOS Precision Analog Switch
DG411                  150         Precision Monolithic Quad SPST CMOS Analog Switches
DG413                  150         Monolithic Quad SPST, CMOS Analog Switches
ADG212               150         LC2MOS Quad SPST Switches
ADG706               200         CMOS, 2.5 Ohm Low-Voltage, 8-/16-Channel Multiplexers
ADG707               200         CMOS, 2.5 Ohm Low-Voltage, 8-/16-Channel Multiplexers
ADG711               150         CMOS Low Voltage, 4 Ω Quad, SPST Switches
ADG709               150         CMOS, 1.8 V to 5.5 V/±2.5 V, 3 Ω Low Voltage 4-/8-Channel Multiplexers
ADG426               250         LC2 MOS 8-/16-Channel High Performance Analog Multiplexers
ADG452               150         LC2MOS 5 V RON SPST Switches
ADG707               200         CMOS 1.8 V to 5.5 V/2.5 V, 2.5 Low-Voltage, 8-/16-Channel Multiplexers
ADG708/709      100         CMOS, 1.8 V to 5.5 V/±2.5 V, 3 ΩLow Voltage 4-/8-Channel Multiplexers
MC14066B          10           Quad Analog Switch
DTQS3VH126Q  100         2.5V / 3.3V QUAD ACTIVEHIGH, HIGH BANDWIDTH SWITCH
Питание
MAX660              150         CMOS Monolithic Voltage Converter (Step-Up Charche-Pump)
ADM660              150         CMOS Monolithic Voltage Converter (Step-Up Charche-Pump)
ADM8660            150         CMOS Switched-Capacitor Voltage Converter
HT7660                 150         CMOS Switched-Capacitor Voltage Converter
LT1054i                 200         Switched-Capacitor Voltage Converter with Regulator
LT1506-3.3          200         4.5A, 500kHz Step-Down Switching Regulator
LT1507-3              200         500kHz Monolithic Buck Mode Switching Regulator
LM1086-3.3[TO-263]      50           1.5-A Low Dropout Positive Regulators
LP2951 [SO-8]   50           Adjustable Micropower Voltage Regulators with Shutdown
LM2676S-ADJ    100         High Efficiency 3A Step-Down Voltage Regulator
ЦАП, АЦП
AD7417                250         10-Bit 4-/1-Channel ADCs
AD7538                200         14-Bit DAC LC2MOS
AD976A               500         16-Bit 200 kSPS BiCMOS A/D Converter
AD9050                300         10-Bit, 60 MSPS A/D Converter
ADS7828              300         12-Bit 8-Channel Sampling ADC  I2C
DAC08C               150         8-Bit, High Speed, Multiplying D/A Converter
MAX5541            300         16-Bit DAC, Low-Cost, +5V, Serial-Input, Voltage-Output
MAX147B            250         +2.7V, Low-Power, 8-Channel, Serial 12-Bit ADCs
PCM1730E          250         24-BIT, 192-kHz SAMPLING ADVANCED SEGMENT, AUDIO STEREO DAC
LTC1658               300         14-Bit Rail-to-Rail Micropower DAC in MSOP
TLC1543               150         11-Channel Single ADC SAR 38ksps 10-bit Serial 20-Pin
Другое
AD637                  350         High Precision, Wideband RMS-to-DC Converter
XTR110KU           300         Precision Voltage-To-Current Converter/Transmitter
AD9850                300         CMOS, 125 MHz Complete DDS Synthesizer
MAX232              100         RS-232 Driver/Receiver
AD8138                150         Low Distortion Differential ADC Driver
ADF4001              150         200 MHz Clock Generator PLL
AD654                  200         Low Cost Monolithic Voltage-to-Frequency Converter
DS1705                100         Supervisory 3.3V and 5.0V
ADM705-707     100         Low Cost Supervisory Circuits
MC33161             50           Universal Voltage Monitor
LM1881                50           Video Sync Separator
PCF8574              50           Remote 8-Bit I/O Expander for I2C Bus
CY22150FZ          250         One-PLL General-Purpose Flash-Programmable and I2C Programmable Clock Generator
Резисторы прецизионные токоизмерительные SMD.  50р/шт
DALE WSR-3       0.002 Oм 1%
DALE WSR-2       0.005 Oм 1%
SMV                      R010 0.5%  (4выв)
CSR1                     0.01 Ом (4выв)
CSR1                     0.02 Ом (4выв)
WSC-1                  0.1 Oм 1%
DALE CMR          0.15 Oм 1%
DALE WSR-2       0.82 Oм 1%
DALE WSC-2       1,0 Oм  1%
DALE WSC-2       1,5 Oм  1%
SMR                      2.7 Ом 1%
WSC-1                  2 Oм 1%
DALE RS-2B        10 Oм 1%
Реле слаботочные сигнальные
OMRON G6H-2F 5VDC   100р
NAIS TQ2-12V   100р
MOSFET
ХХХХХХХХ
Дисплеи LCD
ХХХХХХХ
LCD 128x64
LCD 24x2
VFD Noritake CU40025  1400р    Алфавитно-цифровой; 40x2 (совместим с HD44780)
VFD Noritake CU24025  1400р    Алфавитно-цифровой;24x2 (совместим с HD44780)
Трансформаторы
ХХХХХХХ
Радиаторы алюминиевые
ХХХХХХХХ
Вентиляторы
ХХХХХХХ
Пластины алюминиевые для передних панелей
ХХХХХХХ
Корпуса
ХХХХХХХ
Блоки питания
ХХХХХХХ
ASTEC LPS43      300р        12V4.5A               https://ru.mouser.com/datasheet/2/633/lps40series_ds_1184686823_ds-707387.pdf
Бесплатно доброшу на выбор стабилизаторы напряжения в случае покупки от 1000р:
78M05 [DPAC] 78M06 [DPAC]
78M09 [DPAC]
LF50 [DPAC]
78L05 [SO-8]
78L15 [SO-8]
LM337 [SO-8]
Edited by tkot973
корректировка текста
Приглашаем на вебинар «Необычное в обычном. Сравнительный анализ современных решений Recom» (27.01.2022)
Приглашаем 27/01/2022 всех желающих посетить вебинар, посвященный двум наиболее растущим сегментам интегрированных источников питания – AC/DC малой мощности (1-20Вт) и сегменту решений PoL без изоляции. На вебинаре рассмотрим проблему выбора AC/DC в бюджетном сегменте и концепцию тестирования ускоренного старения, проведем сравнительный анализ подходов к интеграции AC/DC модулей. Сделаем обзор решений концепции POL с доисторических времен до современных технологий и средств для разработки и тестирования.
Решения Infineon для беспроводного электроинструмента с бесщеточными электродвигателями
Современные строительные электроинструменты достигают высокой производительности и эргономичности благодаря использованию мощных бесщеточных электродвигателей и литий-ионных аккумуляторов. Для реализации сложных алгоритмов питания таких двигателей и управления ими компания Infineon предлагает решения, позволяющие создавать оборудование, отвечающее самым современным требованиям, предъявляемым к технике подобного класса.
Стандарт LoRaWAN и его использование в России с контроллерами STM32WL
Стандарт сетевого уровня LoRaWAN технологии LoRa одобрен для применения в России и отвечает требованиям региональных сетевых операторов. Компания STMicroelectronics выпустила линейку беспроводных однокристальных контроллеров серии STM32WL c поддержкой модуляции LoRa. Серия STM32WL имеет цифровые и аналоговые периферийные устройства для приложений, требующих высокой энергоэффективности и возможностей связи на достаточно большие расстояния, подходя для широкого спектра промышленных и потребительских приложений.
Разработка преобразователей на основе карбид-кремниевых приборов с помощью симулятора SpeedFit 2.0
Компания Wolfspeed разработала бесплатный онлайн симулятор SpeedFit 2.0, позволяющий разработчикам быстро и всесторонне оценить параметры основных процессов, происходящих в силовой части импульсных преобразователей электрической энергии, и сравнить между собой различные варианты реализации поставленного технического задания.
1 час назад, Diod КД522А сказал:
Спасибо высота не та что нужно
Есть более плоские корпуса, корпус металл, но они меньше по длине и ширене. Если интересно, в пн. дам размеры.
Закончились следующие позиции:
OPA177
OPA2134
MAX5541
AD9850
SMV R010 0,5%
Появились новые:
MAX4711  Fault-Protected, Low-Voltage, Quad SPST Analog Switches     200р
MOSFET STY140NS10 (N-CHANNEL 100V - 0.009 Ω - 140A - 450W) "c урезанными" ногами до 1см (так получилось:-)    300р.
Edited by tkot973
убрал неверно расставленные кавычки
Господа, или товарищи, не знаю как сейчас уместно, но у меня сейчас сложилась ситуация так, что нет возможности часто сюда заглядывать.
Если какой то вопрос, пожалуйста, звоните или пишите на вацап + 7 985 034 14 16
С уважением,
Константин
