Super Akk Posted January 2, 2022 Share Posted January 2, 2022 (edited) Здравствуйте, я работаю в Proteus и у меня возникла ошибка Simulation is not running in real time due to excessive CPU load Подскажите пожалуйста как её исправить Код прошивки: #include <lm3s300.h> // Graphic Display functions #include <glcd.h> // Font used for displaying text // on the graphic display #include <font5x7.h> // Declare your global variables here void main(void) { unsigned char odin[] = { 0x08, 0x00, 0x08, 0x00, #ifndef _GLCD_DATA_BYTEY_ 0x00, 0x10, 0x18, 0x14, 0x10, 0x10, 0x7C, 0x00, #else 0x00, 0x00, 0x48, 0x44, 0x7E, 0x40, 0x40, 0x00, #endif }; // Declare your local variables here // Variable used to store graphic display // controller initialization data GLCDINIT_t glcd_init_data; // Crystal Oscillator division factor: 1 #pragma optsize- CLKPR=(1<<CLKPCE); CLKPR=(0<<CLKPCE) | (0<<CLKPS3) | (0<<CLKPS2) | (0<<CLKPS1) | (0<<CLKPS0); #ifdef _OPTIMIZE_SIZE_ #pragma optsize+ #endif // Input/Output Ports initialization // Port B initialization // Function: Bit7=In Bit6=In Bit5=In Bit4=In Bit3=In Bit2=In Bit1=In Bit0=In DDRB=(0<<DDB7) | (0<<DDB6) | (0<<DDB5) | (0<<DDB4) | (0<<DDB3) | (0<<DDB2) | (0<<DDB1) | (0<<DDB0); // State: Bit7=T Bit6=T Bit5=T Bit4=T Bit3=T Bit2=T Bit1=T Bit0=T PORTB=(0<<PORTB7) | (0<<PORTB6) | (0<<PORTB5) | (0<<PORTB4) | (0<<PORTB3) | (0<<PORTB2) | (0<<PORTB1) | (0<<PORTB0); // Port C initialization // Function: Bit6=In Bit5=In Bit4=In Bit3=In Bit2=In Bit1=In Bit0=In DDRC=(0<<DDC6) | (0<<DDC5) | (0<<DDC4) | (0<<DDC3) | (0<<DDC2) | (0<<DDC1) | (0<<DDC0); // State: Bit6=T Bit5=T Bit4=T Bit3=T Bit2=T Bit1=T Bit0=T PORTC=(0<<PORTC6) | (0<<PORTC5) | (0<<PORTC4) | (0<<PORTC3) | (0<<PORTC2) | (0<<PORTC1) | (0<<PORTC0); // Port D initialization // Function: Bit7=In Bit6=In Bit5=In Bit4=In Bit3=In Bit2=In Bit1=In Bit0=In DDRD=(0<<DDD7) | (0<<DDD6) | (0<<DDD5) | (0<<DDD4) | (0<<DDD3) | (0<<DDD2) | (0<<DDD1) | (0<<DDD0); // State: Bit7=T Bit6=T Bit5=T Bit4=T Bit3=T Bit2=T Bit1=T Bit0=T PORTD=(0<<PORTD7) | (0<<PORTD6) | (0<<PORTD5) | (0<<PORTD4) | (0<<PORTD3) | (0<<PORTD2) | (0<<PORTD1) | (0<<PORTD0); // Timer/Counter 0 initialization // Clock source: System Clock // Clock value: Timer 0 Stopped // Mode: Normal top=0xFF // OC0A output: Disconnected // OC0B output: Disconnected TCCR0A=(0<<COM0A1) | (0<<COM0A0) | (0<<COM0B1) | (0<<COM0B0) | (0<<WGM01) | (0<<WGM00); TCCR0B=(0<<WGM02) | (0<<CS02) | (0<<CS01) | (0<<CS00); TCNT0=0x00; OCR0A=0x00; OCR0B=0x00; // Timer/Counter 1 initialization // Clock source: System Clock // Clock value: Timer1 Stopped // Mode: Normal top=0xFFFF // OC1A output: Disconnected // OC1B output: Disconnected // Noise Canceler: Off // Input Capture on Falling Edge // Timer1 Overflow Interrupt: Off // Input Capture Interrupt: Off // Compare A Match Interrupt: Off // Compare B Match Interrupt: Off TCCR1A=(0<<COM1A1) | (0<<COM1A0) | (0<<COM1B1) | (0<<COM1B0) | (0<<WGM11) | (0<<WGM10); TCCR1B=(0<<ICNC1) | (0<<ICES1) | (0<<WGM13) | (0<<WGM12) | (0<<CS12) | (0<<CS11) | (0<<CS10); TCNT1H=0x00; TCNT1L=0x00; ICR1H=0x00; ICR1L=0x00; OCR1AH=0x00; OCR1AL=0x00; OCR1BH=0x00; OCR1BL=0x00; // Timer/Counter 2 initialization // Clock source: System Clock // Clock value: Timer2 Stopped // Mode: Normal top=0xFF // OC2A output: Disconnected // OC2B output: Disconnected ASSR=(0<<EXCLK) | (0<<AS2); TCCR2A=(0<<COM2A1) | (0<<COM2A0) | (0<<COM2B1) | (0<<COM2B0) | (0<<WGM21) | (0<<WGM20); TCCR2B=(0<<WGM22) | (0<<CS22) | (0<<CS21) | (0<<CS20); TCNT2=0x00; OCR2A=0x00; OCR2B=0x00; // Timer/Counter 0 Interrupt(s) initialization TIMSK0=(0<<OCIE0B) | (0<<OCIE0A) | (0<<TOIE0); // Timer/Counter 1 Interrupt(s) initialization TIMSK1=(0<<ICIE1) | (0<<OCIE1B) | (0<<OCIE1A) | (0<<TOIE1); // Timer/Counter 2 Interrupt(s) initialization TIMSK2=(0<<OCIE2B) | (0<<OCIE2A) | (0<<TOIE2); // External Interrupt(s) initialization // INT0: Off // INT1: Off // Interrupt on any change on pins PCINT0-7: Off // Interrupt on any change on pins PCINT8-14: Off // Interrupt on any change on pins PCINT16-23: Off EICRA=(0<<ISC11) | (0<<ISC10) | (0<<ISC01) | (0<<ISC00); EIMSK=(0<<INT1) | (0<<INT0); PCICR=(0<<PCIE2) | (0<<PCIE1) | (0<<PCIE0); // USART initialization // USART disabled UCSR0B=(0<<RXCIE0) | (0<<TXCIE0) | (0<<UDRIE0) | (0<<RXEN0) | (0<<TXEN0) | (0<<UCSZ02) | (0<<RXB80) | (0<<TXB80); // Analog Comparator initialization // Analog Comparator: Off // The Analog Comparator's positive input is // connected to the AIN0 pin // The Analog Comparator's negative input is // connected to the AIN1 pin ACSR=(1<<ACD) | (0<<ACBG) | (0<<ACO) | (0<<ACI) | (0<<ACIE) | (0<<ACIC) | (0<<ACIS1) | (0<<ACIS0); ADCSRB=(0<<ACME); // Digital input buffer on AIN0: On // Digital input buffer on AIN1: On DIDR1=(0<<AIN0D) | (0<<AIN1D); // ADC initialization // ADC disabled ADCSRA=(0<<ADEN) | (0<<ADSC) | (0<<ADATE) | (0<<ADIF) | (0<<ADIE) | (0<<ADPS2) | (0<<ADPS1) | (0<<ADPS0); // SPI initialization // SPI disabled SPCR=(0<<SPIE) | (0<<SPE) | (0<<DORD) | (0<<MSTR) | (0<<CPOL) | (0<<CPHA) | (0<<SPR1) | (0<<SPR0); // TWI initialization // TWI disabled TWCR=(0<<TWEA) | (0<<TWSTA) | (0<<TWSTO) | (0<<TWEN) | (0<<TWIE); // Graphic Display Controller initialization // The KS0108 connections are specified in the // Project|Configure|C Compiler|Libraries|Graphic Display menu: // DB0 - PORTB Bit 0 // DB1 - PORTB Bit 1 // DB2 - PORTB Bit 2 // DB3 - PORTB Bit 3 // DB4 - PORTB Bit 4 // DB5 - PORTB Bit 5 // DB6 - PORTB Bit 6 // DB7 - PORTB Bit 7 // E - PORTC Bit 0 // RD /WR - PORTC Bit 1 // RS - PORTC Bit 2 // /RST - PORTC Bit 3 // /CS1 - PORTC Bit 4 // /CS2 - PORTC Bit 5 // Specify the current font for displaying text glcd_init_data.font=font5x7; // No function is used for reading // image data from external memory glcd_init_data.readxmem=NULL; // No function is used for writing // image data to external memory glcd_init_data.writexmem=NULL; glcd_init(&glcd_init_data); glcd_putimage(0,0, odin, GLCD_PUTCOPY); while (1) { // Place your code here } } Схема прикреплена ниже в архиве Схема.rar Edited January 2, 2022 by Super Akk Link to comment Share on other sites More sharing options...
Yuriy.pv Posted January 2, 2022 Share Posted January 2, 2022 Вы случаем код с атмеги не пихаете в Cortex? Уж очень похожи регистры. Link to comment Share on other sites More sharing options...
Реле, разъемы, вентиляторы, корпуса, микросхемы, конденсаторы и много другое!Скидки до 20% на сайте электронного дискаунтера ТМ Электроникс.Бесплатная доставка в любую точку России + кэшбэк 15%.Подробнее Реклама: ООО ТМ ЭЛЕКТРОНИКС, ИНН: 7806548420, info@tmelectronics.ru, +7(812)4094849
Super Akk Posted January 2, 2022 Author Share Posted January 2, 2022 @Yuriy.pv Да, мне необходимо переделать код с AVR на ARM Link to comment Share on other sites More sharing options...
Материалы вебинара «Литиевые аккумуляторы EVE Energy и решения для управления перезаряжаемыми источниками тока»Опубликованы материалы вебинара Компэл, посвященного литиевым аккумуляторам EVE Energy и решениям для управления перезаряжаемыми источниками тока.На вебинаре мы представили информацию не только по линейкам аккумуляторной продукции EVE, но и по решениям для управления ею, что поможет рассмотреть эти ХИТ в качестве дополнительной альтернативы для уже выпускающихся изделий. Также рассмотрели нюансы работы с производителем и сервисы, предоставляемые Компэл по данной продукции. Подробнее>> Реклама: АО КОМПЭЛ, ИНН: 7713005406, ОГРН: 1027700032161
andrusha152 Posted January 2, 2022 Share Posted January 2, 2022 Перевод Цитата Моделирование не выполняется в реальном времени из-за чрезмерной загрузки процессора Компьютер, наверное, слабенький. Link to comment Share on other sites More sharing options...
Комплексные решения с литиевыми батареями EVE для интеллектуальных систем безопасностиЛитиевые химические источники тока EVE по своим характеристикам являются идеальным выбором для современных интеллектуальных систем безопасности. EVE разрабатывает литиевые батареи, опираясь на многолетние исследования таких областей применения, как беспроводная связь стандартов Bluetooth, LoRa, Wi-Fi, NB-IoT и ZigBee. Рассмотрим решения для систем безопасности с использованием батарей EVE. Подробнее>> Реклама: АО КОМПЭЛ, ИНН: 7713005406, ОГРН: 1027700032161
Yuriy.pv Posted January 2, 2022 Share Posted January 2, 2022 1 час назад, Super Akk сказал: Да, мне необходимо переделать код с AVR на ARM Тут не переделывать, а заново писать нужно. Link to comment Share on other sites More sharing options...
Литиевые батарейки и аккумуляторы от мирового лидера EVE в КомпэлКомпания Компэл, официальный дистрибьютор EVE Energy, бренда №1 по производству химических источников тока (ХИТ) в мире, предлагает продукцию EVE как со склада, так и под заказ. Компания EVE широко известна в странах Европы, Америки и Юго-Восточной Азии уже более 20 лет. Недавно EVE была объявлена поставщиком новых аккумуляторных элементов круглого формата для электрических моделей «нового класса» компании BMW.Продукция EVE предназначена для самого широкого спектра применений – от бытового до промышленного. Подробнее>> Реклама: АО КОМПЭЛ, ИНН: 7713005406, ОГРН: 1027700032161
Super Akk Posted January 2, 2022 Author Share Posted January 2, 2022 2 минуты назад, Yuriy.pv сказал: Тут не переделывать, а заново писать нужно. Можете мне пожалуйста помочь с этим? Link to comment Share on other sites More sharing options...
Yuriy.pv Posted January 2, 2022 Share Posted January 2, 2022 Вам сюда . Link to comment Share on other sites More sharing options...
