STM32
Азизбек
Здравствуйте Всем. я недавно начинал изучать СТМ32. У меня есть bluepill, PCF8574AT, LCD1602 но никак не получается. помогите пожалуйста.
#include "i2c-lcd.h"
#include "main.h"
extern I2C_HandleTypeDef hi2c1;  // change your handler here accordingly
#define SLAVE_ADDRESS_LCD 0x3F // change this according to ur setup
void lcd_send_cmd (char cmd)
  char data_u, data_l;
    uint8_t data_t[4];
    data_u = (cmd&0xf0);
    data_l = ((cmd<<4)&0xf0);
    data_t[0] = data_u|0x0E;  //en=1, rs=0
    data_t[1] = data_u|0x0A;  //en=0, rs=0
    data_t[2] = data_l|0x0E;  //en=1, rs=0
    data_t[3] = data_l|0x0A;  //en=0, rs=0
    HAL_I2C_Master_Transmit (&hi2c1, SLAVE_ADDRESS_LCD,(uint8_t *) data_t, 4, 100);
void lcd_send_data (char data)
    uint8_t data_t[4];
    data_u = (data&0xf0);
    data_l = ((data<<4)&0xf0);
    data_t[0] = data_u|0x0F;  //en=1, rs=0
    data_t[1] = data_u|0x0B;  //en=0, rs=0
    data_t[2] = data_l|0x0F;  //en=1, rs=0
    data_t[3] = data_l|0x0B;  //en=0, rs=0
void lcd_clear (void)
    lcd_send_cmd (0x80);
    for (int i=0; i<70; i++)
        lcd_send_data (' ');
void lcd_put_cur(int row, int col)
    switch (row)
        case 0:
            col |= 0x80;
            break;
        case 1:
            col |= 0xC0;
            break;
    lcd_send_cmd (col);
void lcd_init (void)
    // 4 bit initialisation
    HAL_Delay(50);  // wait for >40ms
    lcd_send_cmd (0x30);
    HAL_Delay(5);  // wait for >4.1ms
    HAL_Delay(1);  // wait for >100us
    HAL_Delay(10);
    lcd_send_cmd (0x20);  // 4bit mode
    HAL_Delay(10);
  // dislay initialisation
    lcd_send_cmd (0x28); // Function set --> DL=0 (4 bit mode), N = 1 (2 line display) F = 0 (5x8 characters)
    HAL_Delay(1);
    lcd_send_cmd (0x08); //Display on/off control --> D=0,C=0, B=0  ---> display off
    HAL_Delay(1);
    lcd_send_cmd (0x01);  // clear display
    HAL_Delay(1);
    HAL_Delay(1);
    lcd_send_cmd (0x06); //Entry mode set --> I/D = 1 (increment cursor) & S = 0 (no shift)
    HAL_Delay(1);
    lcd_send_cmd (0x0C); //Display on/off control --> D = 1, C and B = 0. (Cursor and blink, last two bits)
void lcd_send_string (char *str)
    while (*str) lcd_send_data (*str++);
#include "stm32f1xx_hal.h"
void lcd_init (void);   // initialize lcd
void lcd_send_cmd (char cmd);  // send command to the lcd
void lcd_send_data (char data);  // send data to the lcd
void lcd_send_string (char *str);  // send string to the lcd
void lcd_put_cur(int row, int col);  // put cursor at the entered position row (0 or 1), col (0-15);
void lcd_clear (void);
lcd_init();
lcd_send_string ("HELLO WORLD");
HAL_Delay(1000);
lcd_put_cur(1, 0);
lcd_send_string ("football");
