Помогите Разобраться С Таймером На Atiny2313
:020000020000FC
:1000000006C0FECFFDCF8FC1FBCF7EC1AEC10FEDCD
:100010000DBFFF24E0E6F0E000E8F1920A95E9F771
:100020000CE302BB0FE701BB08E708BB0DE807BB09
:1000300004E003BF02E009BF429A99277894C1E621
:10004000D0E00FEF088309830A830B830DE76DD09F
:1000500030D129F0EEE5F2E0E1D00AEF66D009E117
:10006000E02E9F7797FD0FC0EE20E1F7DD20D1F75E
:100070000DE7D02E5ED010F4C3985BD07CD090D02A
:10008000A8D0C39AECCF04E050D0B69B0FC0B59B6C
:1000900001C03AC0C3984DD0C39A40E050E068EE2A
:1000A00073E0A0E0B0E0E9E6F0E00AC042D063D03F
:1000B00040E050E060E177E2A0E0B0E0E7E6F0E0A9
:1000C000002411242224332480E3440F551F661F8B
:1000D000771FAA1FBB1F001C111C221C331C0016FB
:1000E00011062206330628F0001A110A220A330AE2
:1000F00043958A9551F7672B6A2B6B2B81F44083CC
:100100005183A5D0E8D0ABCF14D0232B41F43730A6
:1001100030F400936B0010936C0099D0A0CFEAE507
:10012000F2E07CD00AEF01D09ACFE02EEE20F1F77A
:100130000895FDBCFCBC222404E1C39B08E9302ED9
:1001400008E808BF0AE809BF987F01E40EBDB89827
:1001500092FD0AC091FFFCCF00E40EBD042D152DC9
:10016000262D372D8894089500E40EBD04E0DDDFD0
:100170003FEF08940895C39B12C040916B005091CB
:100180006C00041B150B2F093F0948F49160009582
:100190001095209530950F1D1F1D2F1D3F1D089593
:1001A000C7E6D0E0C39B229668817981441B550B3A
:1001B00081E210F4460F571F5795479537952795BD
:1001C000179507958A95A9F7022F132F242F352FFE
:1001D0000895ADE6B0E066276395442750E2000F2E
:1001E000111F221F331F441F4A3010F04A5003953D
:1001F0005A95A9F74D930F151F052F053F0561F778
:10020000623010F4FD926395C39B6D5FEEE5F2E002
:1002100090FF709634966A956230E0F71127C1E638
:10022000D0E0C8953196002DE894023010F400FB20
:100230000E91FF93EF93E2EAF2E0E00FF11FC89511
:10024000EF91FF9100F80992C53659F70895C1E67C
:10025000D0E0F992C536E9F708950E050F0F0E04A8
:100260000F0F0A01000D0A00000D0E030F0F0E0301
:100270000F0F0F01000D0001000D0000000D010027
:10028000000C0001000C0000000C0100000B00013C
:10029000000B0000000B0E020F0F0E020F0F0E02DC
:1002A0000F0FFC60DAF266B6BEE0FEF6024EC4CE78
:1002B0009E00C7E6D0E041E055E521D00993500FFC
:1002C000CB36D9F71CD0051729F00FEF0A930A9304
:1002D0000A930A930895C7E6D0E041E055E50991F5
:1002E000500F03D0CB36D9F7052F4EBB43950DBB2E
:1002F000F894E29AE19A7894E199FECF08954EBB82
:100300004395E09A0DB308950F930FB70F9323947D
:10031000231428F0BA9AB89A946002E009BF0F91AA
:100320000FBF0F9118950F930FB70F93BA9B0AC089
:1003300044B455B4622CBA9804E10A95F1F708E088
:1003400008BF0FC0742C44B44718752C55B4570817
:10035000762C622C67087724BA9AB89A02E009BF13
:1003600092600F910FBF0F9118950F9309ED02BF87
:1003700078940FB71F930F93FF93EF93E0E6F0E0AD
:1003800010811395143010F01ED0112711930CE337
:1003900002BBE10F00E406951150E8F700950C73DD
:1003A0001081E8E010FF919A10FD9198909A909832
:1003B0001695EA95B9F702BBEF91FF910F911F9146
:1003C0000FBF0F91189506B3009500711681068333
:1003D000011731F4158105831027102309F0906867
:0E03E000EE2009F0EA94DD2009F0DA94089589
:00000001FF
Вот у них там прошива для тинки 2313.Скопируй в блокнот и сохрани с расширением .hex компилить-то скомпилиное чего?Дальше в соответствии с инструкциями ставь фузы.
Что за программер у тебя?
Екстра пик, доделанный. Он зашывает этот текст и всётаки, какие фьзы ставить, так и не определился.
Изменено пользователем cam
Бит SPIEN помоему по умолчанию стоит.На какой частоте пытаешься прочесть фузы?И есть возможность если,по перебирай частоты и выставь внешний кварц на 10Mhz.Битами CKSEL3=1,CKSEL2=1,CKSEL1=1.
Программирую Понипрогом
Если я не ошибаюсь в этой программе снятая галочка на фузе означает 1. Изменено пользователем evgesha53
фьюзы зашиваются, какие хочешь. Поставил галку только на левел1, кварц 10мг. Думаю может микросхема 4049 неподошла, она HEF4049BT вместо 74нс (галочка =0)
Завтра продолжу
А вообще,чтоб отключить схему сброса при снижении напряжения питания,нужно установить BODLEVEL2...0:1.Наверное не надо было этот бит трогать.Отключи схему,она там помоему не нужна.Задержку сброса установи 65+14CK CKSEL0:1 SUT1...0:00.Кварц работает?Где ты вычитал,что эти микросхемы взаимозаменяемы???74HC/HCT4094 8 битные сдвиговые регистры.HEF4049B походу шести буфер,ещё и инвертор.
Может ты про HEF4094B ?
кварц новый брал, должен работать, правда не факт, но 8888 мельтишат, пальцем поводиш по ногам - неоторые сегменты тухнут, да и кнопка реагирует - притухает до нуля и зажигается. А на программаторе другой кварц стоит. Буду смотреть 4094 подробнее, покупал в магазине, думал 4094, реф - это производитель,даташит скачал, вроде похож. Да оцил. сломался, гад. завтра продолжу мучения. Сброс сделал - конденсатор на землю+10к на плюс. Да точно, нужно шит найти на HEF4094BT, у меня такая стоит . Спасибо за помошь.
http://www.terraelectronica.ru/pdf/NXP/HEF4094.pdf
http://www.terraelectronica.ru/pdf/TI/CD74HC4094M.pdf
Совпадают с точностью до вывода.
Однако первая заметно медленней, как и вся серия 4000, но допускает высоковольтное питание до 15 вольт
74HC быстрее почти в три раза, но максимальное питание - 6 вольт.
戦う前に相手のベルトの色に注目
Я так понял у него 4049,а не 4094.
у меня 4094 шиты совпадают, скорее всего новый контроллер нужно. Когда брал, мне подозрительно показалось, ноги были не под углом, а прямо вниз. Наверное выходы испорченные, хотя так шъётся. 73рубля
Ну тогда у тебя аналогичные схемы.В 29 посте ты ошибся.Про микроконтроллер,ну скорее кварц,чем контроллер.Но судя по тому что мерцания есть,походу конфигурация.Фузы зашил как я написал?Просто может тактируешь не правильно?
продолжая биться с этой схемой, заменил всё, кварц,проц, и 4094.Ничего не изменилось. Перепробывал всю конфигурацию, прочитал книгу в которой ни слова не нашёл про Lock2, Lock1, Spmen и др. Осталось найти 4094, - 74 серии. Может будут какие советы от знатоков Attiny2313,?
Прочитать даташит на контроллер, составить слово конфигурации вручную и зашить его.
