Stm32F105 И Can
safronov-63
Делаю адаптер USB-CAN. в режиме CAN_MODE_NORMAL не отправляются и не принимаются сообщения. но в режиме CAN_MODE_LOOPBACK все работает как и должно. Трансивер ISO1050 (работает, проверено). на ноге PB9 при отправке ничего не происходит. Уже неделю мучаюсь.
Инициализация СAN
can_filter.FilterIdHigh = 0;
can_filter.FilterIdLow = 0;
can_filter.FilterMaskIdHigh = 0;
can_filter.FilterMaskIdLow = 0;
can_filter.FilterMode = CAN_FILTERMODE_IDMASK;
can_filter.FilterScale = CAN_FILTERSCALE_32BIT;
can_filter.FilterNumber = 0;
can_filter.FilterFIFOAssignment = CAN_FIFO0;
can_filter.BankNumber = 0;
can_filter.FilterActivation = ENABLE;
can_handle.Instance = CAN1;
can_handle.Init.Prescaler = 450;
can_handle.Init.Mode = CAN_MODE_NORMAL;
can_handle.Init.SJW = CAN_SJW_1TQ;
can_handle.Init.BS1 = CAN_BS1_4TQ;
can_handle.Init.BS2 = CAN_BS2_3TQ;
can_handle.Init.TTCM = DISABLE;
can_handle.Init.ABOM = ENABLE;
can_handle.Init.AWUM = DISABLE;
can_handle.Init.NART = DISABLE;
can_handle.Init.RFLM = DISABLE;
can_handle.Init.TXFP = DISABLE;
HAL_CAN_Init(&can_handle);
HAL_CAN_ConfigFilter(&can_handle, &can_filter);
Инициализация выводов
__HAL_RCC_CAN1_CLK_ENABLE();
__HAL_RCC_AFIO_CLK_ENABLE();
// ремап на PB8 и PB9
__HAL_AFIO_REMAP_CAN1_2();
GPIO_InitTypeDef GPIO_InitStruct;
GPIO_InitStruct.Pin = GPIO_PIN_9;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_HIGH;
HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
GPIO_InitStruct.Pin = GPIO_PIN_8;
GPIO_InitStruct.Mode = GPIO_MODE_AF_INPUT;
  • 4 месяца спустя...
Did you have any luck getting this to work? I'm having similar issues (sorry for incorrect language). I'm using STM32F103C8 with CubeMX and FreeRTOS.
/* CAN init function */
void MX_CAN_Init(void)
/* Enable CAN clock */
__HAL_RCC_CAN1_CLK_ENABLE ();
hcan.Instance = CAN1;
hcan.Init.Prescaler = 16;
hcan.Init.Mode = CAN_MODE_NORMAL;
hcan.Init.SJW = CAN_SJW_1TQ;
hcan.Init.BS1 = CAN_BS1_1TQ;
hcan.Init.BS2 = CAN_BS2_1TQ;
hcan.Init.TTCM = DISABLE;
hcan.Init.ABOM = DISABLE;
hcan.Init.AWUM = DISABLE;
hcan.Init.NART = DISABLE;
hcan.Init.RFLM = DISABLE;
hcan.Init.TXFP = DISABLE;
/* CAN register init */
HAL_CAN_DeInit(&hcan);
HAL_CAN_Init(&hcan);
/* CAN filter init */
sFilterConfig.FilterNumber = 0; // CAN1 [ 0..13]
sFilterConfig.FilterMode = CAN_FILTERMODE_IDMASK; // IdMask or IdList
sFilterConfig.FilterScale = CAN_FILTERSCALE_32BIT; // 16 or 32
sFilterConfig.FilterIdHigh	 = 0x0000; // Everything, otherwise 11-bit in top bits
sFilterConfig.FilterIdLow	 = 0x0000;
sFilterConfig.FilterMaskIdHigh = 0x0000;
sFilterConfig.FilterMaskIdLow = 0x0000;
sFilterConfig.FilterFIFOAssignment = CAN_FIFO0; // Rx
sFilterConfig.FilterActivation = ENABLE;
HAL_CAN_ConfigFilter(&hcan, &sFilterConfig);
void StartDefaultTask(void const * argument)
int adcVal;
CanTxMsgTypeDef TxMess;
int TransmitSuccess = 0;
/* Infinite loop */
for(;
/* Form the message */
TxMess.StdId = 0x123;
TxMess.ExtId = 0x00;
TxMess.DLC = 8;
TxMess.Data[0] = 0xAA;
TxMess.Data[1] = 0xBB;
TxMess.Data[2] = 0xFF;
TxMess.Data[3] = 0xCC;
TxMess.IDE = CAN_ID_STD ;
TxMess.RTR = CAN_RTR_DATA;
hcan.pTxMsg = &TxMess;
if( HAL_OK == HAL_CAN_Transmit(&hcan,50) ) {
TransmitSuccess++;
HAL_GPIO_TogglePin(GPIOB,GPIO_LED_CREEP_Pin);
osDelay(200);
else{
osDelay(100);
osDelay(100);
osDelay(100);
void MX_GPIO_Init(void)
/* GPIO Ports Clock Enable */
__GPIOA_CLK_ENABLE();
/* CAN GPIOs configuration **************************************************/
/* Enable GPIO clock */
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_AFIO_CLK_ENABLE ();
/* Connect CAN block to pins */
__HAL_AFIO_REMAP_CAN1_1();
/* Configure CAN RX and TX pins */
GPIO_InitStruct.Pin = GPIO_CAN_TX | GPIO_CAN_RX;
GPIO_InitStruct.Speed = GPIO_SPEED_MEDIUM;
GPIO_InitStruct.Pull = GPIO_PULLDOWN;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
In main I call
SystemClock_Config();
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_CAN_Init();
It seems to transmit only 1 frame. Then nothing. The Rx node never receives anything.
    • У меня до саба ещё дело не дошло, только сейчас думаю купить амп на полкиловатта, но так можно, при условии, что на входе будет моно, и будет срез частот
    • Про флаг Т: если он не используется в основной программе, а у меня он постоянно в деле. для меня меня отложенная обработка прерывания обычное дело, нужно лишь правильно расставить приоритеты частей программы. И обычное дело: выставляешь частоту задающего генератора побольше, делишь его до получения частоты 1000 Гц каким либо таймером, загоняешь в прерывание с флагом. затем закольцовываешь основную программу с проверкой флага прерывания от таймера 1000Гц. загоняешь программу в Sleep. Получаешь кольцо обработки с образцовым интервалом в 1 мс. После любого прерывания проверяешь флаг от таймера, если он, то сбрасываешь флаг и начинаешь перебирать подпрограммы обработки индикаторов, клавиатуры, и тд. и тп, подпрограммы обработки флагов и др. После окончания обработки всех подпрограмм возвращаешься к Sleep. И так по кольцу. Если происходит прерывание не от таймера, программа выходит из Sleep, проверяется флаг от таймера, если не он (а это не он) обратно к Sleep. В большенстве программ использую этот алгоритм.
    • @korsaj Сегодня попробовал сделать как ты посоветовал. Получился следующий код. #define F_CPU 7372800UL #define BAUND 9600L #define UBRRL_value (F_CPU/(BAUND*16))-1 #include <avr/io.h> #include <util/delay.h> #include <avr/interrupt.h> #include <stdlib.h> void init_pin(void); #define C_PC0 (~PINC&(1<<PC0)) #define C_PC1 (~PINC&(1<<PC1)) #define LED_1_ON() PORTD|=(1<<PD2) #define LED_1_OFF() PORTD&=~(1<<PD2) #define LED_2_ON() PORTD|=(1<<PD3) #define LED_2_OFF() PORTD&=~(1<<PD3) #define FLAG_END_RX (1<<3) #define FLAG_ERR_RX (1<<4) #define BUF_SIZE 20 char rx_buf[BUF_SIZE]; char buf_index = 0; volatile start=1, flags; char b; ISR(USART_RXC_vect) { b=UDR; if(!(flags & FLAG_END_RX)) { rx_buf[buf_index]=UDR; if(rx_buf[buf_index] == 0x0D) { flags |= FLAG_END_RX; return; } buf_index++; if(buf_index >= BUF_SIZE) { buf_index = 0; flags |= FLAG_ERR_RX; } } } void init_UART() { UBRRL = UBRRL_value; UBRRH = UBRRL_value>>8; UCSRB|=(1<<TXEN); UCSRB|=(1<<RXEN); UCSRC|=((1<<URSEL)|(1<<UCSZ0)|(1<<UCSZ1)); UCSRB|=(1<<RXCIE); sei(); flags = 0; } void send_UART(char value) { while(!(UCSRA&(1<<UDRE))); UDR=value; } int main(void) { init_pin(); init_UART(); while(1) { if (start==1) { _delay_ms(500); send_UART('O'); send_UART('K'); send_UART('!'); send_UART(0x0D); send_UART(0x0A); _delay_ms(10); start=0; } if (b == '0') { LED_1_ON(); LED_2_OFF(); send_UART('N'); send_UART('+'); send_UART('0'); send_UART('0'); send_UART(0x0D); send_UART(0x0A); _delay_ms(10); b=4; } if (b == '1') { LED_1_OFF(); LED_2_ON(); send_UART('N'); send_UART('+'); send_UART('0'); send_UART('1'); send_UART(0x0D); send_UART(0x0A); _delay_ms(10); b=4; } if (b == '2') { LED_1_ON(); LED_2_ON(); send_UART('N'); send_UART('+'); send_UART('0'); send_UART('2'); send_UART(0x0D); send_UART(0x0A); _delay_ms(10); b=4; } if (b == '3') { LED_1_OFF(); LED_2_OFF(); send_UART('N'); send_UART('+'); send_UART('0'); send_UART('3'); send_UART(0x0D); send_UART(0x0A); _delay_ms(10); b=4; } if (C_PC0) { send_UART('P'); send_UART('C'); send_UART('0'); send_UART(0x0D); send_UART(0x0A); _delay_ms(250); } if (C_PC1) { send_UART('P'); send_UART('C'); send_UART('1'); send_UART(0x0D); send_UART(0x0A); _delay_ms(250); } } } void init_pin(void) { DDRC = 0b00000000; PORTC = 0b11111111; DDRD |= ((1<<2)|(1<<3)); PORTD &=~ ((1<<2)|(1<<3)); } Ну как сказать всё работает, но вот меня очень интересует приём команд на саму ATMEGA16. Он так и работает только с цифрами. Более ничего корректно принять не получается даже используя таблицу ascii. А мне нужно будет принимать команды и посложней чем просто буквенно - цифровые. Потому как возвращаясь к командам самого плеера там в этих командах хранятся различные данные. Вот примерно так это всё выглядит. AT+QM \ r \ n Запрос режима работы [0: Bluetooth], [1: MP3] AT+M1 \ r \ n Номер текущего файла AT+M2 \ r \ n Общее количество звуковых файлов AT+MD \ r \ n Источник музыки USB или SD Card AT+MT \ r \ n Общее время воспроизведения текущего файла AT+MK \ r \ n Время воспроизведения текущего файла AT+MP \ r \ n Текущее состояние плеера [0]Стоп, [1]Воспроизведение, [2]Пауза К примеру при отправке команды AT+M1 \ r \ n в ответ мы получим M1 + 000002 \ r \ n при этом здесь может быть любое число в hex формате. Мне же нужно каким то образом принять эти данные и обработать их соответствующим образом. Но при этом и нужно учитывать так же что плеер может сам отправить эти данные по началу воспроизведения трека. Вот в этом сейчас и стоит основная задача. Чего я и пытаюсь получить в итоге.
    • Ну тогда дорога к сименсу в гости - они вам какой-нибудь Desigo CC или даже Siematic предложат, тыщ за 10 долларов. Ну и ещё тыщ 5 надо будет отдать за контроллеры и их конфигурирование.   А если попроще - то можно к отечественным MasterSCADA обратиться, либо к WiredBoard - у них не совсем SCADA система, но нормальные контроллеры, довольно просто настраиваются и можно графическую оболочку рисовать.
    • тогда вы имеете то, что имеете, и никак от этого не избавиться. Хоть святой водой окропите. "Или трусы или крестик" (с) Нагрузки у вас немаленькие. Вы же с нуля переделываете, снова некуда ? Понятие LowESR очень неконкретное. Сколько вешать в граммах ? пустая трата времени
    • Да все это туфта, выеденного яйца не стоит. В общем чушь собачья. На мониторе тему уже сплавили в мусорку, а здесь треп еще будет на 10 страницах. Все камеры, их у него было три, исправные. Записывают отлично. А дальше вся проблема в этом. Особо интересно - монтажник видео.
