Управляемый ШИМ на основе микроконтроллера AT90S1200
Роман Федченко
Цитата
Fuse Bits
The AT90S1200 has two Fuse bits: SPIEN and RCEN.
• When the SPIEN Fuse bit is programmed (“0”), Serial Program Downloading is enabled. Default value is programmed (“0”).
• When the RCEN Fuse bit is programmed (“0”), MCU clocking from the Internal RC Oscillator is selected. Default value is erased (“1”). Parts with this bit preprogrammed (“0”) can be delivered on demand.
• The Fuse bits are not accessible in Serial Programming mode. The status of the Fuse bits is not affected by Chip Erase.
Стало быть фьюзы не надо трогать.
Программой, например, USBASP_AVRDUDE_PROG.
Изменено пользователем солар
