Ошибка
Grinch
при прошивке мк выдает ошибку. А какая именно ошибка?
avrdude -p atmega8-16PU -P lpt1 -c stk200 -U flash:w:my_test.hex
avrdude: AVR Part "atmega8-16PU" not found. (на atmega8 просто тоже менял, всё равно ошибка)
Valid parts are:
m6450 = ATMEGA6450 [D:\WinAVR-20071221\bin\avrdude.conf:12304]
m3250 = ATMEGA3250 [D:\WinAVR-20071221\bin\avrdude.conf:12115]
m645 = ATMEGA645 [D:\WinAVR-20071221\bin\avrdude.conf:11926]
m325 = ATMEGA325 [D:\WinAVR-20071221\bin\avrdude.conf:11737]
usb1287 = AT90USB1287 [D:\WinAVR-20071221\bin\avrdude.conf:11549]
usb1286 = AT90USB1286 [D:\WinAVR-20071221\bin\avrdude.conf:11360]
usb647 = AT90USB647 [D:\WinAVR-20071221\bin\avrdude.conf:11171]
usb646 = AT90USB646 [D:\WinAVR-20071221\bin\avrdude.conf:10981]
t84 = ATtiny84 [D:\WinAVR-20071221\bin\avrdude.conf:10798]
t44 = ATtiny44 [D:\WinAVR-20071221\bin\avrdude.conf:10616]
t24 = ATtiny24 [D:\WinAVR-20071221\bin\avrdude.conf:10434]
m2561 = ATMEGA2561 [D:\WinAVR-20071221\bin\avrdude.conf:10241]
m2560 = ATMEGA2560 [D:\WinAVR-20071221\bin\avrdude.conf:10048]
m1281 = ATMEGA1281 [D:\WinAVR-20071221\bin\avrdude.conf:9860]
m1280 = ATMEGA1280 [D:\WinAVR-20071221\bin\avrdude.conf:9671]
m640 = ATMEGA640 [D:\WinAVR-20071221\bin\avrdude.conf:9483]
t85 = ATtiny85 [D:\WinAVR-20071221\bin\avrdude.conf:9302]
t45 = ATtiny45 [D:\WinAVR-20071221\bin\avrdude.conf:9123]
t25 = ATtiny25 [D:\WinAVR-20071221\bin\avrdude.conf:8943]
pwm3b = AT90PWM3B [D:\WinAVR-20071221\bin\avrdude.conf:8762]
pwm2b = AT90PWM2B [D:\WinAVR-20071221\bin\avrdude.conf:8579]
pwm3 = AT90PWM3 [D:\WinAVR-20071221\bin\avrdude.conf:8396]
pwm2 = AT90PWM2 [D:\WinAVR-20071221\bin\avrdude.conf:8212]
t2313 = ATtiny2313 [D:\WinAVR-20071221\bin\avrdude.conf:8025]
m168 = ATMEGA168 [D:\WinAVR-20071221\bin\avrdude.conf:7837]
m88 = ATMEGA88 [D:\WinAVR-20071221\bin\avrdude.conf:7651]
m48 = ATMEGA48 [D:\WinAVR-20071221\bin\avrdude.conf:7464]
t861 = ATTINY861 [D:\WinAVR-20071221\bin\avrdude.conf:7276]
t461 = ATTINY461 [D:\WinAVR-20071221\bin\avrdude.conf:7087]
t261 = ATTINY261 [D:\WinAVR-20071221\bin\avrdude.conf:6898]
t26 = ATTINY26 [D:\WinAVR-20071221\bin\avrdude.conf:6741]
m8535 = ATMEGA8535 [D:\WinAVR-20071221\bin\avrdude.conf:6583]
m8515 = ATMEGA8515 [D:\WinAVR-20071221\bin\avrdude.conf:6425]
m8 = ATMEGA8 [D:\WinAVR-20071221\bin\avrdude.conf:6265]
m161 = ATMEGA161 [D:\WinAVR-20071221\bin\avrdude.conf:6125]
m32 = ATMEGA32 [D:\WinAVR-20071221\bin\avrdude.conf:5950]
m6490 = ATMEGA6490 [D:\WinAVR-20071221\bin\avrdude.conf:5757]
m649 = ATMEGA649 [D:\WinAVR-20071221\bin\avrdude.conf:5572]
m3290p = ATMEGA3290P [D:\WinAVR-20071221\bin\avrdude.conf:5389]
m3290 = ATMEGA3290 [D:\WinAVR-20071221\bin\avrdude.conf:5204]
m329p = ATMEGA329P [D:\WinAVR-20071221\bin\avrdude.conf:5019]
m329 = ATMEGA329 [D:\WinAVR-20071221\bin\avrdude.conf:4835]
m169 = ATMEGA169 [D:\WinAVR-20071221\bin\avrdude.conf:4655]
m163 = ATMEGA163 [D:\WinAVR-20071221\bin\avrdude.conf:4512]
m162 = ATMEGA162 [D:\WinAVR-20071221\bin\avrdude.conf:4316]
m644p = ATMEGA644P [D:\WinAVR-20071221\bin\avrdude.conf:4126]
m644 = ATMEGA644 [D:\WinAVR-20071221\bin\avrdude.conf:3936]
m324p = ATMEGA324P [D:\WinAVR-20071221\bin\avrdude.conf:3745]
m164p = ATMEGA164P [D:\WinAVR-20071221\bin\avrdude.conf:3554]
m16 = ATMEGA16 [D:\WinAVR-20071221\bin\avrdude.conf:3376]
c32 = AT90CAN32 [D:\WinAVR-20071221\bin\avrdude.conf:3185]
c64 = AT90CAN64 [D:\WinAVR-20071221\bin\avrdude.conf:2995]
c128 = AT90CAN128 [D:\WinAVR-20071221\bin\avrdude.conf:2805]
m128 = ATMEGA128 [D:\WinAVR-20071221\bin\avrdude.conf:2627]
m64 = ATMEGA64 [D:\WinAVR-20071221\bin\avrdude.conf:2446]
m103 = ATMEGA103 [D:\WinAVR-20071221\bin\avrdude.conf:2306]
8535 = AT90S8535 [D:\WinAVR-20071221\bin\avrdude.conf:2185]
8515 = AT90S8515 [D:\WinAVR-20071221\bin\avrdude.conf:2071]
4434 = AT90S4434 [D:\WinAVR-20071221\bin\avrdude.conf:1988]
4433 = AT90S4433 [D:\WinAVR-20071221\bin\avrdude.conf:1864]
2343 = AT90S2343 [D:\WinAVR-20071221\bin\avrdude.conf:1740]
2333 = AT90S2333 [D:\WinAVR-20071221\bin\avrdude.conf:1655]
2313 = AT90S2313 [D:\WinAVR-20071221\bin\avrdude.conf:1542]
4414 = AT90S4414 [D:\WinAVR-20071221\bin\avrdude.conf:1429]
1200 = AT90S1200 [D:\WinAVR-20071221\bin\avrdude.conf:1314]
t15 = ATtiny15 [D:\WinAVR-20071221\bin\avrdude.conf:1181]
t13 = ATtiny13 [D:\WinAVR-20071221\bin\avrdude.conf:1008]
t12 = ATtiny12 [D:\WinAVR-20071221\bin\avrdude.conf:875]
t11 = ATtiny11 [D:\WinAVR-20071221\bin\avrdude.conf:811]
make.exe: *** [program] Error 1
> Process Exit Code: 2
> Time Taken: 00:00
а не, меняю на atmega8 и ошибка другая...
vrdude -p atmega8 -P lpt1 -c stk200 -U flash:w:my_test.hex
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9206
avrdude: Expected signature for ATMEGA8 is 1E 93 07
Double check chip, or use -F to override this check.
avrdude done. Thank you.
> Time Taken: 00:01
"И мы построим свой лунопарк, с блэк-джеком и шлюхами..." (Робот Бэндер, Футурама)
Вместо atmega8-16PU надо писать просто m8
Изменено пользователем fredo
Проблема в том что у твоего контроллера идентификатор 1e9206, а у atmega8 должен быть 1E 93 07
с таким идентификатором у atmel вобще никакого контроллера нету
я поменял на m8 - не работает. Я первый раз прошиваю мк, мош чета не правильно... У меня мк atmega8-16pu
MakeFile
# - Makefile - myROBOT.ru
# Тип используемого микроконтроллера
MY_MCU = atmega8
# Частота кварцевого резонатора (Hz)
MY_F_CPU = 8000000
# Название файла проекта (без расширения)
MY_TARGET = my_test
# Используемый программатор (для AVRDUDE)
MY_AVRDUDE_PROGRAMMER = stk200
# Порт, к которому подключен программатор
MY_PROGRAMMER_PORT = lpt1
# MCU name
MCU = $(MY_MCU)
# Processor frequency.
F_CPU = $(MY_F_CPU)
# Output format. (can be srec, ihex, binary)
FORMAT = ihex
# Target file name (without extension).
TARGET = $(MY_TARGET)
# Object files directory
OBJDIR = obj
# List C source files here. (C dependencies are automatically generated.)
SRC =$(TARGET).c
# List C++ source files here. (C dependencies are automatically generated.)
CPPSRC =
# List Assembler source files here.
ASRC =
# Optimization level, can be [0, 1, 2, 3, s].
OPT = s
# Debugging format.
DEBUG = dwarf-2
# List any extra directories to look for include files here.
EXTRAINCDIRS =
# Compiler flag to set the C Standard level.
CSTANDARD = -std=gnu99
# Place -D or -U options here for C sources
CDEFS = -DF_CPU=$(F_CPU)UL
# Place -D or -U options here for C++ sources
CPPDEFS = -DF_CPU=$(F_CPU)UL
#CPPDEFS += -D__STDC_LIMIT_MACROS
#CPPDEFS += -D__STDC_CONSTANT_MACROS
#---------------- Compiler Options C ----------------
CFLAGS = -g$(DEBUG)
CFLAGS += $(CDEFS)
CFLAGS += -O$(OPT)
#CFLAGS += -mint8
#CFLAGS += -mshort-calls
CFLAGS += -funsigned-char
CFLAGS += -funsigned-bitfields
CFLAGS += -fpack-struct
CFLAGS += -fshort-enums
#CFLAGS += -fno-unit-at-a-time
CFLAGS += -Wall
CFLAGS += -Wstrict-prototypes
CFLAGS += -Wundef
#CFLAGS += -Wunreachable-code
#CFLAGS += -Wsign-compare
CFLAGS += -Wa,-adhlns=$(<:%.c=$(OBJDIR)/%.lst)
CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
CFLAGS += $(CSTANDARD)
#---------------- Compiler Options C++ ----------------
CPPFLAGS = -g$(DEBUG)
CPPFLAGS += $(CPPDEFS)
CPPFLAGS += -O$(OPT)
#CPPFLAGS += -mint8
#CPPFLAGS += -mshort-calls
CPPFLAGS += -funsigned-char
CPPFLAGS += -funsigned-bitfields
CPPFLAGS += -fpack-struct
CPPFLAGS += -fshort-enums
CPPFLAGS += -fno-exceptions
#CPPFLAGS += -fno-unit-at-a-time
CPPFLAGS += -Wall
#CPPFLAGS += -Wstrict-prototypes
CFLAGS += -Wundef
#CPPFLAGS += -Wunreachable-code
#CPPFLAGS += -Wsign-compare
CPPFLAGS += -Wa,-adhlns=$(<:%.cpp=$(OBJDIR)/%.lst)
CPPFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
#CPPFLAGS += $(CSTANDARD)
#---------------- Assembler Options ----------------
ASFLAGS = -Wa,-adhlns=$(<:%.S=$(OBJDIR)/%.lst),-gstabs
#---------------- Library Options ----------------
# Minimalistic printf version
PRINTF_LIB_MIN = -Wl,-u,vfprintf -lprintf_min
# Floating point printf version (requires MATH_LIB = -lm below)
PRINTF_LIB_FLOAT = -Wl,-u,vfprintf -lprintf_flt
# If this is left blank, then it will use the Standard printf version.
PRINTF_LIB =
#PRINTF_LIB = $(PRINTF_LIB_MIN)
#PRINTF_LIB = $(PRINTF_LIB_FLOAT)
# Minimalistic scanf version
SCANF_LIB_MIN = -Wl,-u,vfscanf -lscanf_min
# Floating point + %[ scanf version (requires MATH_LIB = -lm below)
SCANF_LIB_FLOAT = -Wl,-u,vfscanf -lscanf_flt
# If this is left blank, then it will use the Standard scanf version.
SCANF_LIB =
#SCANF_LIB = $(SCANF_LIB_MIN)
#SCANF_LIB = $(SCANF_LIB_FLOAT)
MATH_LIB = -lm
#---------------- External Memory Options ----------------
EXTMEMOPTS =
#---------------- Linker Options ----------------
LDFLAGS = -Wl,-Map=$(TARGET).map,--cref
LDFLAGS += $(EXTMEMOPTS)
LDFLAGS += $(PRINTF_LIB) $(SCANF_LIB) $(MATH_LIB)
#LDFLAGS += -T linker_script.x
#---------------- Programming Options (avrdude) ----------------
AVRDUDE_PROGRAMMER = $(MY_AVRDUDE_PROGRAMMER)
# com1 = serial port. Use lpt1 to connect to parallel port.
AVRDUDE_PORT = $(MY_PROGRAMMER_PORT)
AVRDUDE_WRITE_FLASH = -U flash:w:$(TARGET).hex
#AVRDUDE_WRITE_EEPROM = -U eeprom:w:$(TARGET).eep
#AVRDUDE_ERASE_COUNTER = -y
#AVRDUDE_NO_VERIFY = -V
#AVRDUDE_VERBOSE = -v -v
AVRDUDE_FLAGS = -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER)
AVRDUDE_FLAGS += $(AVRDUDE_NO_VERIFY)
AVRDUDE_FLAGS += $(AVRDUDE_VERBOSE)
AVRDUDE_FLAGS += $(AVRDUDE_ERASE_COUNTER)
#---------------- Debugging Options ----------------
# For simulavr only - target MCU frequency.
DEBUG_MFREQ = $(F_CPU)
# Set the DEBUG_UI to either gdb or insight.
# DEBUG_UI = gdb
DEBUG_UI = insight
# Set the debugging back-end to either avarice, simulavr.
DEBUG_BACKEND = avarice
#DEBUG_BACKEND = simulavr
# GDB Init Filename.
GDBINIT_FILE = __avr_gdbinit
# When using avarice settings for the JTAG
JTAG_DEV = /dev/com1
# Debugging port used to communicate between GDB / avarice / simulavr.
DEBUG_PORT = 4242
# Debugging host used to communicate between GDB / avarice / simulavr, normally
DEBUG_HOST = localhost
# Define programs and commands.
SHELL = sh
CC = avr-gcc
OBJCOPY = avr-objcopy
OBJDUMP = avr-objdump
SIZE = avr-size
NM = avr-nm
AVRDUDE = avrdude
REMOVE = rm -f
REMOVEDIR = rm -rf
COPY = cp
WINSHELL = cmd
# Define Messages
# English
MSG_ERRORS_NONE = Errors: none
MSG_BEGIN = -------- begin --------
MSG_END = --------  end  --------
MSG_SIZE_BEFORE = Size before:
MSG_SIZE_AFTER = Size after:
MSG_COFF = Converting to AVR COFF:
MSG_EXTENDED_COFF = Converting to AVR Extended COFF:
MSG_FLASH = Creating load file for Flash:
MSG_EEPROM = Creating load file for EEPROM:
MSG_EXTENDED_LISTING = Creating Extended Listing:
MSG_SYMBOL_TABLE = Creating Symbol Table:
MSG_LINKING = Linking:
MSG_COMPILING = Compiling C:
MSG_COMPILING_CPP = Compiling C++:
MSG_ASSEMBLING = Assembling:
MSG_CLEANING = Cleaning project:
MSG_CREATING_LIBRARY = Creating library:
# Define all object files.
OBJ = $(SRC:%.c=$(OBJDIR)/%.o) $(CPPSRC:%.cpp=$(OBJDIR)/%.o) $(ASRC:%.S=$(OBJDIR)/%.o)
# Define all listing files.
LST = $(SRC:%.c=$(OBJDIR)/%.lst) $(CPPSRC:%.cpp=$(OBJDIR)/%.lst) $(ASRC:%.S=$(OBJDIR)/%.lst)
# Compiler flags to generate dependency files.
GENDEPFLAGS = -MD -MP -MF .dep/$(@F).d
# Combine all necessary flags and optional flags.
# Add target processor to flags.
ALL_CFLAGS = -mmcu=$(MCU) -I. $(CFLAGS) $(GENDEPFLAGS)
ALL_CPPFLAGS = -mmcu=$(MCU) -I. -x c++ $(CPPFLAGS) $(GENDEPFLAGS)
ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS)
# Default target.
all: begin gccversion sizebefore build sizeafter end
# Change the build target to build a HEX file or a library.
build: elf hex eep lss sym
#build: lib
elf: $(TARGET).elf
hex: $(TARGET).hex
eep: $(TARGET).eep
lss: $(TARGET).lss
sym: $(TARGET).sym
LIBNAME=lib$(TARGET).a
lib: $(LIBNAME)
# Eye candy.
begin:
@echo
@echo $(MSG_BEGIN)
end:
@echo $(MSG_END)
@echo
# Display size of file.
HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex
ELFSIZE = $(SIZE) -A $(TARGET).elf
AVRMEM = avr-mem.sh $(TARGET).elf $(MCU)
sizebefore:
@if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_BEFORE); $(ELFSIZE); \
$(AVRMEM) 2>/dev/null; echo; fi
sizeafter:
@if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_AFTER); $(ELFSIZE); \
# Display compiler version information.
gccversion :
@$(CC) --version
# Program the device.
program: $(TARGET).hex $(TARGET).eep
$(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH) $(AVRDUDE_WRITE_EEPROM)
# Generate avr-gdb config/init file which does the following:
gdb-config:
@$(REMOVE) $(GDBINIT_FILE)
@echo define reset >> $(GDBINIT_FILE)
@echo SIGNAL SIGHUP >> $(GDBINIT_FILE)
@echo end >> $(GDBINIT_FILE)
@echo file $(TARGET).elf >> $(GDBINIT_FILE)
@echo target remote $(DEBUG_HOST):$(DEBUG_PORT)  >> $(GDBINIT_FILE)
ifeq ($(DEBUG_BACKEND),simulavr)
@echo load  >> $(GDBINIT_FILE)
endif
@echo break main >> $(GDBINIT_FILE)
debug: gdb-config $(TARGET).elf
ifeq ($(DEBUG_BACKEND), avarice)
@echo Starting AVaRICE - Press enter when "waiting to connect" message displays.
@$(WINSHELL) /c start avarice --jtag $(JTAG_DEV) --erase --program --file \
$(TARGET).elf $(DEBUG_HOST):$(DEBUG_PORT)
@$(WINSHELL) /c pause
else
@$(WINSHELL) /c start simulavr --gdbserver --device $(MCU) --clock-freq \
$(DEBUG_MFREQ) --port $(DEBUG_PORT)
endif
@$(WINSHELL) /c start avr-$(DEBUG_UI) --command=$(GDBINIT_FILE)
# Convert ELF to COFF for use in debugging / simulating in AVR Studio or VMLAB.
COFFCONVERT = $(OBJCOPY) --debugging
COFFCONVERT += --change-section-address .data-0x800000
COFFCONVERT += --change-section-address .bss-0x800000
COFFCONVERT += --change-section-address .noinit-0x800000
COFFCONVERT += --change-section-address .eeprom-0x810000
coff: $(TARGET).elf
@echo
@echo $(MSG_COFF) $(TARGET).cof
$(COFFCONVERT) -O coff-avr $< $(TARGET).cof
extcoff: $(TARGET).elf
@echo
@echo $(MSG_EXTENDED_COFF) $(TARGET).cof
$(COFFCONVERT) -O coff-ext-avr $< $(TARGET).cof
# Create final output files (.hex, .eep) from ELF output file.
%.hex: %.elf
@echo
@echo $(MSG_FLASH) $@
$(OBJCOPY) -O $(FORMAT) -R .eeprom $< $@
%.eep: %.elf
@echo
@echo $(MSG_EEPROM) $@
-$(OBJCOPY) -j .eeprom --set-section-flags=.eeprom="alloc,load" \
--change-section-lma .eeprom=0 -O $(FORMAT) $< $@
# Create extended listing file from ELF output file.
%.lss: %.elf
@echo
@echo $(MSG_EXTENDED_LISTING) $@
$(OBJDUMP) -h -S $< > $@
# Create a symbol table from ELF output file.
%.sym: %.elf
@echo
@echo $(MSG_SYMBOL_TABLE) $@
$(NM) -n $< > $@
# Create library from object files.
.SECONDARY : $(TARGET).a
.PRECIOUS : $(OBJ)
%.a: $(OBJ)
@echo
@echo $(MSG_CREATING_LIBRARY) $@
$(AR) $@ $(OBJ)
# Link: create ELF output file from object files.
.SECONDARY : $(TARGET).elf
.PRECIOUS : $(OBJ)
%.elf: $(OBJ)
@echo
@echo $(MSG_LINKING) $@
$(CC) $(ALL_CFLAGS) $^ --output $@ $(LDFLAGS)
# Compile: create object files from C source files.
$(OBJDIR)/%.o : %.c
@echo
@echo $(MSG_COMPILING) $<
$(CC) -c $(ALL_CFLAGS) $< -o $@
# Compile: create object files from C++ source files.
$(OBJDIR)/%.o : %.cpp
@echo
@echo $(MSG_COMPILING_CPP) $<
$(CC) -c $(ALL_CPPFLAGS) $< -o $@
# Compile: create assembler files from C source files.
%.s : %.c
$(CC) -S $(ALL_CFLAGS) $< -o $@
# Compile: create assembler files from C++ source files.
%.s : %.cpp
$(CC) -S $(ALL_CPPFLAGS) $< -o $@
# Assemble: create object files from assembler source files.
$(OBJDIR)/%.o : %.S
@echo
@echo $(MSG_ASSEMBLING) $<
$(CC) -c $(ALL_ASFLAGS) $< -o $@
# Create preprocessed source for use in sending a bug report.
%.i : %.c
$(CC) -E -mmcu=$(MCU) -I. $(CFLAGS) $< -o $@
# Target: clean project.
clean: begin clean_list end
clean_list :
@echo
@echo $(MSG_CLEANING)
$(REMOVE) $(TARGET).hex
$(REMOVE) $(TARGET).eep
$(REMOVE) $(TARGET).cof
$(REMOVE) $(TARGET).elf
$(REMOVE) $(TARGET).map
$(REMOVE) $(TARGET).sym
$(REMOVE) $(TARGET).lss
$(REMOVEDIR) $(OBJDIR)
$(REMOVE) $(SRC:.c=.s)
$(REMOVE) $(SRC:.c=.d)
$(REMOVEDIR) .dep
# Create object files directory
$(shell mkdir $(OBJDIR) 2>/dev/null)
# Include the dependency files.
-include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*)
# Listing of phony targets.
.PHONY : all begin finish end sizebefore sizeafter gccversion \
build elf hex eep lss sym coff extcoff \
clean clean_list program debug gdb-config
my_test.c
ПРИМЕР МИГАНИЯ СВЕТОДИОДАМИ
  #include <avr/io.h>
  #include <avr/delay.h>
  #define F_CPU 8000000UL  // 8 MHz
  int main(void)			  // начало основой программы
  DDRD = 0xff;			/* все выводы порта D сконфигурировать как выходы */
	while (1) {			  // Бесконечный цикл
		PORTD = 0xff; /* установить "1" на всех линиях порта D */
		_delay_ms(250);   // Ждем 0.25 сек.
		PORTD = 0x00;  /* установить "0" на всех линиях порта D */
	}	   // закрывающая скобка бесконечного цикла
  }	  // закрывающая скобка основной программы
Изменено пользователем Zer
А. Вроде нашел ошибку - не поставил перемычку на 2-12 выводы программатора... ща исправлю и проверю <_<
