2313 + Winavr
cmeptb999
#define F_CPU 8000000UL
#include <avr/io.h>
#include <avr/delay.h>
double red, green, blue; //now colors
unsigned int tred, tgreen, tblue; //tagert colors
double delta_red, delta_green, delta_blue; //величина прибавки за шаг
unsigned int time = 1;
int i; //длительность шага
void delay(unsigned int delayt) //задержка _delay_ms() на вход принимает только константу(
while (delayt != 0)
_delay_ms(1);
delayt--;
void main(void)
red=0;
green=0;
blue=0;
// Crystal Oscillator division factor: 1
//#pragma optsize-
//CLKPR=0x80;
//CLKPR=0x00;
//#ifdef _OPTIMIZE_SIZE_
//#pragma optsize+
//#endif
// Input/Output Ports initialization
// Port A initialization
// Func2=In Func1=In Func0=In
// State2=T State1=T State0=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
// Func7=In Func6=In Func5=In Func4=Out Func3=Out Func2=Out Func1=In Func0=In
// State7=T State6=T State5=T State4=0 State3=0 State2=0 State1=T State0=T
PORTB=0x00;
DDRB=0x1C;
// Port D initialization
// Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTD=0x00;
DDRD=0x00;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: 8000,000 kHz
// Mode: Fast PWM top=FFh
// OC0A output: Non-Inverted PWM
// OC0B output: Disconnected
TCCR0A=0x83;
TCCR0B=0x01;
TCNT0=0x00;
OCR0A=0x00;
OCR0B=0x00;
// Timer/Counter 1 initialization
// Mode: Fast PWM top=00FFh
// OC1A output: Non-Inv.
// OC1B output: Non-Inv.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer 1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0xA1;
TCCR1B=0x09;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// Interrupt on any change on pins PCINT0-7: Off
//GIMSK=0x00;
//MCUCR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x01;
srand(1); //инициализируем рандомайзер этим значением
while (1)
tred =1+ (rand()&0xFD); //задаем значения
tgreen =1+ (rand()&0xFD);
tblue =1 +(rand()& 0xFD);
time = 10+ (rand()&0x09);
//нерабочий кусок
//i=rand()&0x0F;
//if(i==1)
//tred=0;
// if(i==2)
// tgreen=0;
//if(i==3)
//tblue=0;
delta_red=(tred-red)/100; //вычисляем шаг
delta_green=(tgreen-green)/100;
delta_blue=(tblue-blue)/100;
i=0;
while(i<100)
i++;
red=red+delta_red;
green=green+delta_green;
blue=blue+delta_blue;
OCR1B = red;
OCR1A = green;
OCR0A = blue;
delay(time);
delay(time*10);
Проблема в закоментированном куске кода, при его добавлении, прошивка не работает в протеусе и не хочет заливатся на микроконтроллер. Но что в нем криминального такого? без него все работает как
надо.
Так же сначала я попробовал сделать тот кусок с помощью switch но были аналогичные проблемы.
Изменено пользователем cmeptb999
Что значит "прошивка не работает" и "не хочет заливаться"? При симуляции и заливке возникают ошибки, или результаты симуляции или запуска устройства не соответствуют ожидаемым?
В протеусе при старте симуляции все каналы ШИМ обнуляются, а при прошивке аврдуд ругается по моему на недоступный адресс.
и если я не ошибаюсь то проблема в i=rand()&0x0F; хотя я не понимаю что там может быть не так.
Посмотрите в документации как задать тип процессора в самой программе.
Например для того что бы компилятор знал, что пишем программу для AT90S2313, нужно в начале написать вот такую команду препроцессора:
#define __AVR_AT90S2313__
Это сообщение поставляется "как есть", без каких либо гарантий. Автор сообщения не несёт какой либо ответственности
за материальный, либо моральный ущерб причиненный данным сообщением напрямую или косвенно.
