Ambilight На Msp430G2553
Пытаюсь приспособить следующий пример и скетч с него для MSP430g2553. Однако, при компилировании при помощи Energia получаю следующую ошибку
sketch_oct10a.cpp: In function 'void pulseGSCLK()':
sketch_oct10a.cpp:208:3: error: 'PORTB' was not declared in this scope
Как я понимаю PORTB не был объявлен как переменная, как это корректно можно сделать?
/* TLC5940 16-port LED driver
= Paden Hogeland - Adjusted for use of 4 RGB LED's
* Peter Mackey June 2007 Pratt Digital Arts pmackey@pratt.edu
* direct adressing to PORTB, smooth flickerless fading (thanks to Amp on the Arduino forum)
* additional logic from David Cuartielles's & Marcus Hannerstig's LEDdriver demo
= see the TLC5940 data sheet for the logic behind these pulse sequences
// Name the Arduino pins to the TLC5940 pin names
#define VPRG 2
#define SIN 5
#define SCLK 6
#define XLAT 7
#define BLANK 8
#define DCPRG 9
#define GSCLK 10 //note: but using PORTB method
#define MSINTRVL 0 // could be used to delay updating of incrementFades()
#define FADEMIN 0 // lowest fade level LEDs will reach (min would be 0, max 4065)
#define FADEINCR 64 // determines how many steps it takes to run the desired range (lower=longer)
// Array to hold the port values 0 min - 4095 max
int port[] = {
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
int faderNdx = 0; //counter used in this fading sequence
int fadeState[] = {
1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; //stores the direction of fading for each port 1,0,-1
//start with first port
int next; //used for limit checking in fading function
float prevMillis; //used for a timing delay
int myword[] = {0,0,0,0,0,0,0,0,0,0,0,0}; //temp storage for reversing bits in a word (for greyscale setting)
// Declare the RGB varables
double red,green,blue;
// Set up
void setup() {
// Assign the output pins
pinMode(VPRG, OUTPUT);
pinMode(SIN, OUTPUT);
pinMode(SCLK, OUTPUT);
pinMode(XLAT, OUTPUT);
pinMode(BLANK, OUTPUT);
pinMode(DCPRG, OUTPUT);
pinMode(GSCLK, OUTPUT);	 // Could also set DDRB directly
// Initalize Serial Connection
Serial.begin(9600);
// Initalize unused TLC5940 pins
port[13] = 0;
port[14] = 0;
port[15] = 0;
port[0] = 0;
preset(); //input �Dot Correction� data
// Main Loop
void loop () {
setGreys();
feedPorts();
// If have passed the interval
if (millis() > (prevMillis+MSINTRVL)){
// Set the RGB values
setRGB();
// Set new previous time
prevMillis=millis();
void setRGB() {
// If correct amount of serial is avaiable
if(Serial.available() >= 13 ){
// If we are at the first chunk of data
if(Serial.read() == 0xff){
 // Set the Left Side
 red = Serial.read();
 blue = Serial.read();
 green = Serial.read();
 // Get the percentage of each value then update port accordinly
 port[10] = (4095)*(red/255);
 port[11] = (4095)*(blue/255);
 port[12] = (4095)*(green/255);
 // Set the Top Left Side
 port[7] = (4095)*(red/255);
 port[9] = (4095)*(green/255);
 port[8] = (4095)*(blue/255);
 // Set the Top Right Side
 port[4] = (4095)*(red/255);
 port[6] = (4095)*(green/255);
 port[5] = (4095)*(blue/255);
 // Set the Right Side
 port[1] = (4095)*(red/255);
 port[2] = (4095)*(blue/255);
 port[3] = (4095)*(green/255);
//=======5940 control======================================
void setGreys() {
// For the each port (12 bit word * 16 ports =192 bits in this loop)...
for (int i=15; i>=0; i--) {
// Initalize the data
int datb = port[i];
// Load fade level bits into the temp array BACKWARDS
for (int j=11; j>=0; j--) {
 myword[j]=(datb & 1); //& bitwise AND
 datb >>= 1;	 //shift right and assign
 // (maybe there's a slicker way to do this!? but this works...)
// Send the data to the 5940
for (int j=0; j<12; j++) {
 digitalWrite(SIN,myword[j]);
 pulseSCLK();
digitalWrite(XLAT, HIGH);
digitalWrite(XLAT, LOW);
void feedPorts() {
// The actual sequencing of the PWM data into the LEDs, must do constantly...
digitalWrite(BLANK, HIGH);
digitalWrite(BLANK, LOW); //=all outputs ON, start PWM cycle
for (int i=0; i<4096; i++) {
pulseGSCLK();
//DOT CORRECTION...do once
void preset() {
//Input �DotCorrex� Data
//16 outputs, 64 posssible levels of adjustment, 6 bits/chan = 96 bits total
//[use if any LEDs in array are physically too bright]
digitalWrite(DCPRG, HIGH); //leaving it H is my arbitrary choice (="write to register not EEPROM")
digitalWrite(VPRG, HIGH);	 //=inputting data into dot correx register
digitalWrite(BLANK, HIGH); //=all outputs off, when this goes high it resets the greyscale counter
digitalWrite(SIN, LOW);	 //to start dot correction
//begin loading in the dot correx data, most significant bit first...
//but here we are not correcting anything, so LSB is going first!
for (int i=0; i<16; i++) { //16 ports
for (int j=0; j<6; j++) { //6 bits of data for each port
 digitalWrite(SIN, HIGH); //for now, 111111 for everybody
 pulseSCLK();
//----doing the FIRST GREYSCALE SETTING here becuz of the unique 193rd clock pulse
digitalWrite(XLAT, HIGH); //latch the dot data into the dot correx register
digitalWrite(VPRG, LOW); //entering greyscale mode
int datb = 4095;	 //using same fade level for all ports this first time
for (int j=0; j<12; j++) { //data for each port, all the same value to start
 digitalWrite(SIN, datb & 01);
 pulseSCLK();
 datb>>=1;
digitalWrite(XLAT, HIGH); //latch the greyscale data
pulseSCLK();			 //193rd clock pulse only need to do the FIRST time after dot correx
digitalWrite(BLANK, LOW); //=all outputs ON, start PWM cycle... moved here
//SCLK used in dot correx and greyscale setting
void pulseSCLK() {
digitalWrite(SCLK, HIGH);
digitalWrite(SCLK, LOW);
void pulseGSCLK() {
//ultra fast pulse trick, using digitalWrite caused flickering
PORTB=0x01; //bring PORTB0 high (pin 8), other ports go low [0x01 does only pin 8, 0x21 also lifts pin 13]
//16nanosecs is the min pulse width for the 5940, but no pause seems needed here
PORTB=0x20; //keep pin13 high [0x00 would be all low]
Изменено пользователем vasily_pupkin
  • 3 месяца спустя...
В MSP430G2553 нет такого разделения на PortB, PortC и PortD, это свойственно только для AVR. В Msp430 управление портами делается через PxDIR, PxREN, PxOUT, PxIN, PxSEL, PxIES, PxIFG. Где PxDIR - назначение портов входом/выходом, PxREN - включить/выключить внутренний(слабенький) подтягивающий резистор(внутри подключен к плюсу(ножка VCC)), PxOUT - регистр для записи данных в порт, если он настроен на выход, PxIN - соответственно для чтения из порта, PxSEL - переключение части портов переключает из I/O в вход АЦП или выход ШИМ, что то типа этого, PxIES PxIFG - вроде как отвечают за прерывание. Здесь вместо (х) ставится цифра порта. Соответственно если вместо PORTB записать P1DIR, то программа откомпилируется, но её правильная работоспособность будет под вопросом, т.к. в Avr portB это несколько портов(Atmega8 ножки 9,10,14-19), а вот насчёт LaunhPad-а я сказать не могу, но могу предположить что если Х=1, то это будет относится ко всем ножкам P1.x (т.е.P1.0-P1.7). Следовательно, нужно смотреть и сравнивать что у вас на этих ножках висит. Да и к стати 0x01 и 0x20, тоже имеют значение, так как это выражение записанно для ног AVR (например DDRD = B11111110). А вообще покурите Datasheet, и комментарии скетчу к там скорее всего всё написано. Ну и ещё можно почитать здесь, здесь, здесь ну и по AVR тут.
Изменено пользователем Pylypiuk
