Vhdl Testbench В Xilinx Ise Webpack
НеСказочник
Всем здрасьте. Только учусь работать с VHDL. Осваиваю Xilinx Ise WebPack (кажись он так называется). И при попытке сгенерировать эту отладочную доску на vhdl он мне генерирует её с ошибками:
-- Company:
-- Engineer:
-- Create Date: 22:53:00 01/26/2014
-- Design Name:
-- Module Name: E:/XProject/Adder_test1/adder_testbench.vhd
-- Project Name: Adder_test1
-- Target Device:
-- Tool versions:
-- Description:
-- VHDL Test Bench Created by ISE for module: adder
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
-- Notes:
-- This testbench has been automatically generated using types std_logic and
-- std_logic_vector for the ports of the unit under test. Xilinx recommends
-- that these types always be used for the top-level I/O of a design in order
-- to guarantee that the testbench will bind correctly to the post-implementation
-- simulation model.
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--USE ieee.numeric_std.ALL;
ENTITY adder_testbench IS
END adder_testbench;
ARCHITECTURE behavior OF adder_testbench IS
-- Component Declaration for the Unit Under Test (UUT)
COMPONENT adder
PORT(
A : IN std_logic;
B : IN std_logic;
C : OUT std_logic
END COMPONENT;
--Inputs
signal A : std_logic := '0';
signal B : std_logic := '0';
--Outputs
signal C : std_logic;
-- No clocks detected in port list. Replace <clock> below with
-- appropriate port name
constant <clock>_period : time := 10 ns;
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: adder PORT MAP (
A => A,
B => B,
C => C
-- Clock process definitions
<clock>_process :process
begin
<clock> <= '0';
wait for <clock>_period/2;
<clock> <= '1';
end process;
-- Stimulus process
stim_proc: process
begin
-- hold reset state for 100 ns.
wait for 100 ns;
wait for <clock>_period*10;
-- insert stimulus here
wait;
end process;
END;
Ругается на <clock>.
Кто знает что с этим делать?
Не убедительно. Все среды программирования всегда генерируют рабочий код. И даже, если он ничего не делает, то должен быть, по крайней мере без ошибок.
