Arduino Cw+Gps+Sd
Это QRPp CW-маяк, работающий на 160/80/40-метровом диапазоне. Автор скетча Клименко Максим.
Есть желание доработать этот скетч для вставки GPS-координат в текст посылки и параллельного логирования координат и времени фиксации на SD-карту.
Что скажите господа?
// Arduino simply CW beacon
// (c) 2012 Max Klimenko
// emaster [at] mail.ru
// Beacon message
const char message[] = "VVV CQ CQ CQ DX DE BEACON BAND 40M 8000KHZ";// Period of single point (ms)
const int point_time = 80;
// Carrier frequency divider.
// Carrier freq. (MHz) = 16 / (2 * (1 + freq_div))
const unsigned char freq_div = 1;//////////////////////////////////////////////////////////////////
struct s_abc
 char letter;
 char sign[7];
const s_abc abc[] = {
 'A',".-", 'B',"-...", 'W',".--", 'G',"--.", 'D',"-..",
 'E',".", 'V',"...-", 'Z',"--..", 'I',"..",
 'J',".---", 'K',"-.-", 'L',".-..", 'M',"--", 'N',"-.",
 'O',"---", 'P',".--.", 'R',".-.", 'S',"...",
 'T',"-", 'U',"..-", 'F',"..-.", 'H',"....", 'C',"-.-.",
 'Q',"--.-", 'Y',"-.--", 'X',"-..-", '1',".----",
 '2',"..---", '3',"...--", '4',"....-", '5',".....",
 '6',"-....", '7',"--...", '8',"---..", '9',"----.",
 '0',"-----", '.',"......", ',',".-.-.-", ':',"---...",
 '!',"--..--", '@',".--.-.", '\\',"..-.-" };unsigned char abc_size = sizeof(abc) / sizeof(abc[0]);
void setup()
PORTB = 0;
DDRB |= 1<<1;
OCR1A = freq_div;
TCCR1A = 0x48;
TCCR1B = 0x09;
pinMode(13, OUTPUT);
digitalWrite(13, HIGH); // set the LED on
}void send_letter(char l)
if (l == ' ')
delay(point_time * 7);
return;
unsigned char idx = 255;
for (unsigned char i = 0; i < abc_size; i++)
if (abc[i].letter == l)
 idx = i;
 break;
if (idx == 255) return;
const char *s = abc[idx].sign;
for (unsigned char c = 0; s[c] != 0; c++)
char q = s[c];
DDRB |= 1<<1;
if (q == '.') delay(point_time);
else delay(point_time * 3);
DDRB &= ~(1<<1);
digitalWrite(13, LOW); // set the LED off
delay(point_time);
delay(point_time * 2);
}void loop()
for (int n = 0; message[n] != 0; n++)
send_letter(message[n]);
delay(2000);
Изменено пользователем DJ_Wever
Вопрос стоит не в реализации, а в востребованности.
Есть-ли желание следить например за своими домашними питомцами или личным автомобилем?!
