Замена Кт829
Detailed Darlington Transistors (TO - 220 & ) Description
ITO - 220 package main types:
a) 2SB975, 2SB1283, 2SB1282, 2SB1284
B) 2SC4350
c) 2SD1308, 2SD1740, 2SD1566, 2SD1788, 2SD1790, 2SD1789, 2SD1791, 2SD1793,
2SD1792, 2SD1794
a) 2N6043, 2N6045, 2N6044, 2N6386, 2N6388, 2N6387, 2N6530,
2N6532, 2N6531, 2N6533, 2N6666
B) 2SB601, 2SB669, 2SB668, 2SB673, 2SB750, 2SB727, 2SB751,
2SB791K, 2SB765, 2SB872, 2SB880
c) 2SC1880, 2SC1883, 2SC1881, 2SC2992, 2SC3146, 2SC4573
d) 2SD459, 2SD560, 2SD460, 2SD633, 2SD635, 2SD634, 2SD686,
2SD768, 2SD687, 2SD833, 2SD916, 2SD837, 2SD930, 2SD1532, 2SD970, 2SD1558, 2SD1565,
2SD1564, 2SD1572, 2SD1600, 2SD1599, 2SD1601
e) BD644, BD646, BD645, BD647, BD649, BD648, BD650, BD652, BD651,
BD895, BD896, BD895A, BD896A, BDT61, BDT60C, BDT61A,
BDT61C, BDT61B, BDT63B, BDW23, BDT65C, BDW24, BDW53, BDW40, BDW54,
BDW64, BDW63, BDW64A, BDW64C, BDW64B, BDW64D, BDW73, BDW93
f) BDX33, BDX34, BDX53
g) MJE700T, MJE702T, MJE701T, MJE703T, MJE801T, MJE800T, MJE802T,
MJE803T
h) TIP102, TIP112, TIP107, TIP117, TIP127, TIP122, TIP132,
TIP140T, TIP137, TIP141T, TIP142T
TO - 220F package main types:
a) 2SA1718
B) 2SB1098, 2SB1228, 2SB1223, 2SB1257, 2SB1568, 2SB1258, 2SB1626
c) 2SC4006
d) 2SD1309, 2SD1785, 2SD1392, 2SD1825, 2SD1830, 2SD1827, 2SD2014, 2SD2016,
2SD2015, 2SD2079, 2SD2081
TO - 220Fa package main types:
a) 2SB949, 2SB950A, 2SB950, 2SB1020, 2SB1022, 2SB1021, 2SB1023, 2SB1108,
2SB1024, 2SB1193, 2SB1551, 2SB1404, 2SB1616
B) 2SC3677, 2SC4574, 2SC4895
c) 2SD1275, 2SD1277, 2SD1276, 2SD1315, 2SD1357, 2SD1336, 2SD1358, 2SD1414,
2SD1413, 2SD1415, 2SD1417, 2SD1416, 2SD1510,
2SD1608, 2SD1591, 2SD1633, 2SD1764, 2SD1634, 2SD1765, 2SD1856, 2SD1773,
2SD1889, 2SD1891, 2SD1890, 2SD2108, 2SD2111, 2SD2110, 2SD2112,
2SD2113, 2SD2128
d) BD651F, BD652F
http://www.germes-online.com/catalog/87/38...0_and_126_.html
Изменено пользователем Патриот Ваня
    • Зачем? Это всего лишь буферная ёмкость между ИИП и платой усилителя, сглаживающая возможные просадки. А плёнка/керамика есть(должна быть) на плате, возле питающих микросхему "ног", как в этом варианте
    • Ну, обычное сложение диодным "ИЛИ" выходов интеграторов каналов стабилизации выходного напряжения и выходного тока, "кто перетянет". В чём вопрос-то? Будет ли работать? Ну будет работать. Или вам мнение про что-то другое надо?
    • Если плата односторонняя - поставьте заклёпку.
    • Очевидно, внимательно смотреть по всем цепям, которыми подключено, начаная с питания?
    • Вот любительская конструкция в которой можно подглядеть интересную систему замера сопротивления и в целом возможную топологию.   Так же советую заценить мануалы на В7-38, В7-84 и особенно В7-87. Последние два весьма современные приборы, и из В7-87 по сути весь "фронтэнд" можно взять как базу. Однако, прежде чем начать разрабатывать конкретную схему, стоит уточнить требования к итоговому прибору, да и его конструктив в том числе. Настольный/переносной? Какая у прибора будет разрядность? Какой будет использоваться АЦП? На тему встроенных АЦП МК есть отличная статья от Леонида Ивановича, где описана проблема, которая возникнет при работе с ними, и метод её решения. https://leoniv.livejournal.com/194681.html С диапазонами непонятка. В параметре "10мВ-1В" что имеется в виду? Не понятно, почему все пределы не кратны по десятке (например, 1/10/100 или 5/50/500). С токовыми пределами тот же вопрос, 1мА-100мА что означает, и почему пределы 1А и 5А не кратны друг другу, скажем как 1А и 10А (ну или обратно, 5А и 500мА)?   Касательно входного делителя. Не обязательно делать его на все пределы индивидуально, поставьте туда перед АЦП усилитель-буфер с переключаемым усилением между х1 и х10, например, ведь в любом случае, от схемы требуется измерять ток, а для этого нужен будет усилитель сигнала с шунта. Поэтому можно использовать этот усилитель для добавления в делитель некоторых пределов. Делитель будет делать "шаг" в сто раз - х1 х100, а после него стоит усилитель, добавляющий, в данном случае, предел х10 и х0.1 Так, например, построен В7-38, разве что х10 усилителя там нет, это "усиление" реализовано за счёт переключения предела АЦП с 2В до 0,2В. Коммутаторов, в таком случае, в цепи напряжения будет два - реле переключающее х1 и х100 делитель, поскольку оно работает с возможными +/-500В по входу, и ключ на полевиках типа DG419/DG411/4052/4053/etc, переключающий усиление буфера между х1 и х10, работающий с +/-5В максимум. Обычно делители ставят по принципу R+9R+90R+... и тд, таким образом мы в любой точке включения получаем делитель, дающий одну десятую/сотую и тд от входного напряжения. От этого метод с усилителем в 10 раз и кажется мне более логичным - нужно реализовать всего один делитель 99:1 (например из двух резисторов МРХ 10 МОм и 100кОм, параллельно 100кОм прицепить цепочку настройки, которая собьёт его сопротивление до 90к), после чего уже индивидуально подстраивать х10 усилитель и входной делитель. Плюс, получаем узел, который можно использовать для усиления сигнала с шунта. В целом, так же можно снизить и число шунтов, в "крутых" приборах я видел их от силы два, на "много ампер" и на "всё остальное", что реализуется усилителями после них. Тут уже вопрос стоит в том, какое падение напряжения на шунте максимально допустимо для конструкции. Я в своих мыслях по измерителю на ICL7135 пришёл к выводу, что пожертвовать 0,1В...0,2В на амперметр это максимум, который можно себе позволить.   PS На всякий случай, а то может кто прицепится Я не предлагаю использовать такие экзотические вещи, как сборки согласованных резисторов, а так же сильно запариваться над эффектами, которые по-хорошему надо бы учесть при финальном проектировании - навроде дрейфа коэффициентов деления/усиления от температуры, потому что не тот уровень конструкции. Исходя из скромного ТЗ, как я понял, задачи получить какой-либо серьезный измеритель не стоит, чисто прибор уровня детешки +/-, с возможностью вывода значений во внешний мир через USB. PPS Мануалы на вышеназванные мультиметры со схемами: v7-87.pdf v7-84-тпг.pdfВ7-38 - ТОИЭ (вариант 1).djvu
    • Не совсем вас понял, я предложил пересчитать резисторы в делителе и оптрон запитать от ваших 12 В, что не так?
    • Прощу высказать мнение насчет схемы управления, в части регулировки тока, . Схема собрана автором и лежит в интернете.  LM358 universal.rar
