STM32F107RCT6 + ADS1256
Гость remixx
Пытаюсь подключить ADS1256 (АЦП) к 107-мому по SPI .
Схему подключения, настройки МК и SPI, даташит АЦП - приложил.
Ну и собственно сам код:
* @file : main.c
* @brief : Main program body
** This notice applies to any and all portions of this file
* that are not between comment pairs USER CODE BEGIN and
* USER CODE END. Other portions of this file, whether
* inserted by the user or by software development tools
* are owned by their respective copyright owners.
* COPYRIGHT© 2018 STMicroelectronics
* Redistribution and use in source and binary forms, with or without modification,
* are permitted provided that the following conditions are met:
* 1. Redistributions of source code must retain the above copyright notice,
* this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright notice,
* this list of conditions and the following disclaimer in the documentation
* and/or other materials provided with the distribution.
* 3. Neither the name of STMicroelectronics nor the names of its contributors
* may be used to endorse or promote products derived from this software
* without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
* SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
* CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "stm32f1xx_hal.h"
/* USER CODE BEGIN Includes */
#include "stdio.h"
#include "math.h"
#include <string.h>
#include <errno.h>
#define CS_ON() HAL_GPIO_WritePin(CS_GPIO_Port, CS_Pin, GPIO_PIN_RESET) // Vkluchenie ADC
#define CS_OFF() HAL_GPIO_WritePin(CS_GPIO_Port, CS_Pin, GPIO_PIN_SET) // Vikluchenie ADC
#define ADS_DRDY (HAL_GPIO_ReadPin(DRDY_GPIO_Port, DRDY_Pin)==GPIO_PIN_SET) // Proverka gotovnosti ADC
/* USER CODE END Includes */
/* Private variables ---------------------------------------------------------*/
SPI_HandleTypeDef hspi3;
/* USER CODE BEGIN PV */
uint8_t aTxBuffer[1]={0}; // Buffer dlya otpravlyaemih dannih
uint8_t aRxBuffer[3]={0,0,0}; // Buffer dlya prinimaemih dannih
uint32_t result;
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_SPI3_Init(void);
/* USER CODE BEGIN PFP */
/* Funkciya inicializacii ADC */
void ADS1256_Init(void)
CS_ON(); // Aktiviruem ADC
HAL_Delay(100);
aTxBuffer[0]=0xFE; // Ukazivaem adres commandi RESET
HAL_SPI_Transmit(&hspi3, (uint8_t*)aTxBuffer, 1, 50); // Posilaem komandy RESET (sbrasivaem ADC k defoltnim nastroykam)
HAL_Delay(100);
aTxBuffer[0]=0xFC;// Ukazivaem adres commandi SYNC
HAL_SPI_Transmit(&hspi3, (uint8_t*)aTxBuffer, 1, 50); // Posilaem komandy SYNC (sinhronizaciya ADC s signalom na vivode SCLK)
aTxBuffer[0]=0x00; // Ukazivaem adres commandi WAKEUP
HAL_SPI_Transmit(&hspi3, (uint8_t*)aTxBuffer, 1, 50); // Posilaem komandy WAKEUP (v sootvetstvii s datasheet)
aTxBuffer[0]=0x50 | 0x00; // Ukazivaem adress registra s kotorogo nachinaetsa zapis (STATUS)
HAL_SPI_Transmit(&hspi3, (uint8_t*)aTxBuffer, 1, 50); // Peredaem adress pervogo registra
aTxBuffer[0]=3; // Ukazivaem kolichestvo registrov v kotorie budem zapisivat (zapisivaetsa 1 + TO KOLICHESTVO KOTOROE UKAZIVAEM, V DANOM SLUCHAE POLUCHAETSA 1+3=4)
HAL_SPI_Transmit(&hspi3, (uint8_t*)aTxBuffer, 1, 50); // Peredaem kolichesto registrov
aTxBuffer[0]=0x04; // Ukazivaem dannie, kotorie neobhodimo zapisat v pervyi registr (STATUS) - ustanavlivaem poryadok chteniya so starshego bayta (MSB), vkluchaem avto-kalibrovky, vikluchaem analogovyi buffer, dubliruem vivod DRDY
HAL_SPI_Transmit(&hspi3, (uint8_t*)aTxBuffer, 1, 50); // Peredaem dannie v registr STATUS
/* while(ADS_DRDY) {}; // Vozmojno nujno dlya ojidaniya zaversheniya avtokalibrovki */
aTxBuffer[0]=0x00 | 0x01; // Ukazivaem dannie, kotorie neobhodimo zapisat vo vtoroy registr (MUX) - vkluchaem vhod AIN0 kak POSITIVE, AIN1 kak NEGATIVE
HAL_SPI_Transmit(&hspi3, (uint8_t*)aTxBuffer, 1, 50); // Peredaem dannie v registr MUX
aTxBuffer[0]=0x00; // Ukazivaem dannie, kotorie neobhodimo zapisat v tretyi registr (ADCON) - otkluchaem CLK0/CLK1, otkluchaem datchik opredeleniya istochnika toka, ustanavlivaem vnutrennyi usilitel v 64 raza
HAL_SPI_Transmit(&hspi3, (uint8_t*)aTxBuffer, 1, 50); // Peredaem dannie v registr ADCON
aTxBuffer[0]=0x82; // Ukazivaem dannie, kotorie neobhodimo zapisat v chetvertyi registr (DRATE) - zadaem skorost raboti ADC (kolichestvo viborok v sekundu), v dannom sluchae 100 SPS
HAL_SPI_Transmit(&hspi3, (uint8_t*)aTxBuffer, 1, 50); // Peredaem dannie v registr DRATE
HAL_Delay(100); //min=50*(1/fCLKIN)=50*(1/7.68MHZ)=6500ns;max=whatever
CS_OFF(); // Vikluchaem ADC
HAL_Delay(100);
/* Funkciya polucheniya rezultata ODNOGO preobrazovaniya */
uint32_t ADS1256ReadData(void)
uint32_t sum=0;
aTxBuffer[0]=0x01; // Ukazivaem adres commandi READ DATA
HAL_SPI_Transmit(&hspi3, (uint8_t*)aTxBuffer, 1, 50); // Posilaem komandy READ DATA (chtenie rezultata ODNOGO preobrazovaniya)
HAL_SPI_Receive(&hspi3, (uint8_t*)aRxBuffer, 3, 50); // Schitivaem poluchennyi rezultat (3 bayta)
sum = aRxBuffer[0];
sum = sum << 8; // Poetomy, posle kajdogo poluchennogo bayta provodim smeshenie na 8
sum |= aRxBuffer[1];
sum = sum << 8;
sum |= aRxBuffer[2];
return sum; // Vozvrashaem znachenie poluchennogo rezultata
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
* @brief The application entry point.
* @retval None
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/* MCU Configuration----------------------------------------------------------*/
/* Reset of all peripherals, Initializes the Flash interface and the Systick. */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
/* Configure the system clock */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_SPI3_Init();
/* USER CODE BEGIN 2 */
HAL_Delay(100);
ADS1256_Init();
HAL_Delay(100);
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
result = ADS1256ReadData();
while (ADS_DRDY) {}
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
* @brief System Clock Configuration
* @retval None
RCC_OscInitTypeDef RCC_OscInitStruct;
RCC_ClkInitTypeDef RCC_ClkInitStruct;
/**Initializes the CPU, AHB and APB busses clocks
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV5;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.Prediv1Source = RCC_PREDIV1_SOURCE_PLL2;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
RCC_OscInitStruct.PLL2.PLL2State = RCC_PLL2_ON;
RCC_OscInitStruct.PLL2.PLL2MUL = RCC_PLL2_MUL8;
RCC_OscInitStruct.PLL2.HSEPrediv2Value = RCC_HSE_PREDIV2_DIV5;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
_Error_Handler(__FILE__, __LINE__);
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
/**Configure the Systick interrupt time
HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
__HAL_RCC_PLLI2S_ENABLE();
/* SysTick_IRQn interrupt configuration */
HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
/* SPI3 init function */
/* SPI3 parameter configuration*/
hspi3.Instance = SPI3;
hspi3.Init.Mode = SPI_MODE_MASTER;
hspi3.Init.Direction = SPI_DIRECTION_2LINES;
hspi3.Init.DataSize = SPI_DATASIZE_8BIT;
hspi3.Init.CLKPolarity = SPI_POLARITY_LOW;
hspi3.Init.CLKPhase = SPI_PHASE_1EDGE;
hspi3.Init.NSS = SPI_NSS_SOFT;
hspi3.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_32;
hspi3.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi3.Init.TIMode = SPI_TIMODE_DISABLE;
hspi3.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi3.Init.CRCPolynomial = 7;
if (HAL_SPI_Init(&hspi3) != HAL_OK)
/** Configure pins as
* Analog
* Input
* Output
* EVENT_OUT
* EXTI
GPIO_InitTypeDef GPIO_InitStruct;
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOD_CLK_ENABLE();
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
/*Configure GPIO pin Output Level */
HAL_GPIO_WritePin(CS_GPIO_Port, CS_Pin, GPIO_PIN_SET);
/*Configure GPIO pin : DRDY_Pin */
GPIO_InitStruct.Pin = DRDY_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_IT_FALLING;
GPIO_InitStruct.Pull = GPIO_NOPULL;
HAL_GPIO_Init(DRDY_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pin : CS_Pin */
GPIO_InitStruct.Pin = CS_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
HAL_GPIO_Init(CS_GPIO_Port, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
* @brief This function is executed in case of error occurrence.
* @param file: The file name as string.
* @param line: The line in file as a number.
* @retval None
void _Error_Handler(char *file, int line)
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state */
while(1)
/* USER CODE END Error_Handler_Debug */
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* USER CODE BEGIN 6 */
/* User can add his own implementation to report the file name and line number,
tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
/************************ © COPYRIGHT STMicroelectronics *****END OF FILE****/
В итоге во входной буфер приходят только нулевые значения.
Если посылать команду RDATAC (т.е. выполнять не единичное преобразование, а сделать так, чтобы АЦП постоянно слал 24 бита один за другим), результат такой же.
Не понимаю в чем проблема, не правильная инициализация или схема?
Помимо того, что указано на схеме, к питанию подключены SYNC/PDWN и RESET (в соответствии с дш).
А вот кварц отсутствует. Детали уже приобрел, во вторник протестирую вместе с ним.
А с кодом никаких проблем? Может быть какие-то грубые ошибки, которые сразу в глаза бросаются?
Код вообще редкостная гадость, что характерно для любителей калокуба - абсолютное непонимание  как и  С, так и самой периферии.
И еще ни один адепт калокуба не смог верно инициализировать SPI и плодотворно работать с ним, хотя работа с модулем абсолютно прозрачна.
Ну и сразу -
 (uint8_t*)aTxBuffer
Имя массива и есть указатель на его первый элемент.
Изменено пользователем dosikus
Ну и какая ж такая тайна в инициализации spi? У меня около 50 устройств работают около года на кубе, spi там используется для общения с flash и fram. На spi нареканий не было ни разу. А по поводу кода согласен, все в одном файле, куча дилеев. Может оно на данном этапе и проще, но я бы сразу отучивался от такой манеры написания...
Я планирую запустить SPI по прерываниям, но на данном этапе пока разбираюсь с самим АЦП проще делать в таком виде.Проблема была действительно в кварце, сегодня наконец-то добрался до платы, напаял его и все заработало! :yahoo:
Но сейчас появился следующий вопрос: как от кода АЦП перейти к человеческим значениям))
Придумал следующее:
//Провожу инициализацию АЦП
    HAL_Delay(100);
    HAL_SPI_Transmit(&hspi3, aTxBuffer, 1, 50); // Posilaem komandy RESET (sbrasivaem ADC k defoltnim nastroykam)
    aTxBuffer[0]=0xFC; // Ukazivaem adres commandi SYNC
    HAL_SPI_Transmit(&hspi3, aTxBuffer, 1, 50); // Posilaem komandy SYNC (sinhronizaciya ADC s signalom na vivode SCLK)
    HAL_SPI_Transmit(&hspi3, aTxBuffer, 1, 50); // Posilaem komandy WAKEUP (v sootvetstvii s datasheet)
    HAL_SPI_Transmit(&hspi3, aTxBuffer, 1, 50); // Peredaem adress pervogo registra
    HAL_SPI_Transmit(&hspi3, aTxBuffer, 1, 50); // Peredaem kolichesto registrov
    aTxBuffer[0]=0x05; // Ukazivaem dannie, kotorie neobhodimo zapisat v pervyi registr (STATUS) - ustanavlivaem poryadok chteniya so starshego bayta (MSB), vkluchaem avto-kalibrovky, vikluchaem analogovyi buffer, dubliruem vivod DRDY
    HAL_SPI_Transmit(&hspi3, aTxBuffer, 1, 50); // Peredaem dannie v registr STATUS
    HAL_SPI_Transmit(&hspi3, aTxBuffer, 1, 50); // Peredaem dannie v registr MUX
    HAL_SPI_Transmit(&hspi3, aTxBuffer, 1, 50); // Peredaem dannie v registr ADCON
    aTxBuffer[0]=0xD0; // Ukazivaem dannie, kotorie neobhodimo zapisat v chetvertyi registr (DRATE) - zadaem skorost raboti ADC (kolichestvo viborok v sekundu), v dannom sluchae 7500 SPS
    HAL_SPI_Transmit(&hspi3, aTxBuffer, 1, 50); // Peredaem dannie v registr DRATE
    HAL_Delay(1);
uint32_t ADS1256ReadData()
    uint8_t i=0;
    uint32_t sum=0;
    uint32_t r=0;
    aTxBuffer[0]=ADS1256_CMD_RDATA; // Ukazivaem adres commandi READ DATA
    for(i=0;i<3;i++) // Sozdaem cikl, t.k. ADC 24-bitnyi, to polnyi rezultat odnogo izmereniya budet predstavlen v vide 3 baytov (3 raza priydet po 8 bit)
        HAL_SPI_Receive(&hspi3, (uint8_t*)aRxBuffer, 1, 50); // Schitivaem poluchennyi rezultat (bayt)
        r = aRxBuffer[0]; // Priravnivaem peremennuy r k poluchennomy baytu ot ADC
        sum |= r; // Summiruem poluchennyi bayt s tem, chto uje imeetsa
    /* OTRICATELNOE CHISLO PREDSTAVLENO V DOPOLNITELNOM CODE, 24yi BIT UKAZIVAET ZNAK, 23 OSTLANIH ETO CHISLO */
    uint32_t negative = (sum & (1 << 23)) != 0; // Proveryaem znak poluchennogo chisla (esli 24yi bit raven 1, to chislo otricatelnoe, a esli on raven 0, to chislo polojitelnoe
    uint32_t result;
    int MAXnegative = 0x800000; // Ukazivaem maximalno vozmojnoe OTRICATELNOE znachenie
    if (negative) // Esli chislo otricatelnoe, to vosstanavlivaem PRYAMOY KOD
        if (sum != MAXnegative) // Esli ono ne maximalno otricatelnoe
            sum = sum ^ 0x800000; // Iskluchaem 24yi bit
            result = sum - 1; // Vozvrashaem edinicy v mladshyi razryad
             result = result ^ 0xFFFFFF; // Vozvrashaem inversiy i 1cy v 24 bit
         else // Esli ono maximalno otricatelnoe, to vivodim 0x800000, tak kak pryamoy kod etogo chisla vosstanovit nevozmojno
             result = MAXnegative;
    else // Esli chislo polojitelnoe, to vivodim ego bez kakih libo preobrazovanyi
        result = sum;
    return result; // Vozvrashaem znachenie poluchennogo rezultata
Результат преобразования вывожу в соответствии с картинкой 1 (Data format, страница 23 дш)
После чего пытаюсь преобразовать код АЦП к человеческому виду и вывести его на ЖКИ.
На странице 24 (рисунок 2), написана формула выходного кода АЦП (с учетом калибровки). Соответственно если выразить оттуда Vin = ((Output/(FSC*beta))+OFC/alfa)*(2*vref); то я и получу нужное мне значение.
Для этого после калибровки я считываю регистры FSC и OFC, затем подставляю только что измеренное значение АЦП и опорное напряжение (мерил осциллографом = 2,48 В).
/* Chtenie znacheniya ukazannogo registra */
uint8_t ADS1256RREG(uint8_t regaddr)
    aTxBuffer[0]=0x10 | (regaddr & 0xF); // Ukazivaem adres registra s kotorogo nachinaetsa chtenie
    HAL_SPI_Transmit(&hspi3, aTxBuffer, 1, 50); // Peredaem adress nachalnogo registra
aTxBuffer[0]=0; // Ukazivaem kolichestvo registrov iz kotorih budut schitivatsa dannie (zapisivaetsa 1 + TO KOLICHESTVO KOTOROE UKAZIVAEM, V DANOM SLUCHAE POLUCHAETSA 1+0=1)
    HAL_SPI_Transmit(&hspi3, aTxBuffer, 1, 50); // Peredaem kolichestvo registrov
       HAL_SPI_Receive(&hspi3, aRxBuffer, 1, 50); //Schitivaem dannie iz registra
       return aRxBuffer[0]; // Vozvrashaem peremennoy znachenie vibrannogo registra
//Считываю значение регистров OFC
uint32_t ADS1256OFCCalibration()
    uint32_t number1=0;
    number1 = ADS1256RREG(0x07); //Считываю значение из регистра OFC2
    number1 = number1 << 8; // posle kajdogo poluchennogo bayta provodim smeshenie na 8
    number1 |= ADS1256RREG(0x06); //Считываю значение из регистра OFC1
    number1 |= ADS1256RREG(0x05); //Считываю значение из регистра OFC0
      return number1;
//Считываю значение регистров FSC
uint32_t ADS1256FSCCalibration()
    uint32_t number2=0;
    number2 = ADS1256RREG(0x0A); //Считываю значение из регистра FSC2
    number2 = number2 << 8; // posle kajdogo poluchennogo bayta provodim smeshenie na 8
    number2 |= ADS1256RREG(0x09); //Считываю значение из регистра FSC1
    number2 |= ADS1256RREG(0x08); //Считываю значение из регистра FSC0
      return number2;
Для вывода на жки преобразую переменные в строку и вывожу её.
//Funkciya vivoda stroki//
void PrintStr(char* str)
    uint8_t i = 0;
    while (str[i] != 0)
        SendByte(str[i], 1);
        HAL_Delay(10);
        i++;
//Преобразование переменной double
void PrintFlt(double test)
char output[50];
snprintf(output, 50, "%f", test);
PrintStr(output);
Ну и собственно main:
/Переменные
uint32_t result1;
uint32_t OFC;
uint32_t FSC;
double beta=1.8639f;
double vref=2.48f;
uint32_t alfa=0x400000;
double OTVET;
int main(void)
  HAL_Init();
  MX_GPIO_Init();
  MX_SPI3_Init();
      HAL_Delay(100);
    InitializeLCD();
      HAL_Delay(100);
      ADS1256_Init();
      HAL_Delay(100);
      FSC=ADS1256FSCCalibration();
      OFC=ADS1256OFCCalibration();
  /* Infinite loop */
  while (1)
      ClearLCDScreen();
      SetCursor(0,2);
      PrintStr("Result");
      SetCursor(1,3);
      result1=ADS1256ReadData();
      OTVET=((result1/(FSC*beta))+OFC/alfa)*(2*vref);
      PrintFlt(OTVET);
      HAL_Delay(1000);
В итоге на ЖКИ вижу значения по типу 0.3xxxxx 0.5xxxxxx 0.1xxxxx , которые меняются хаотично.
PS: инициализация ЖКИ точно выполнена правильно, т.к. использую его уже давно.
проблема у тебя в арифметике. И в первую очередь почитай где нибудь как избавится от таковой с плавающей точкой. Поубирай все свои даблы и замени на целые типы. Приведи все вычисления к одному основанию. Глядишь, чего нибудь и получится
При использовании дискретного источника данных (в данном случае АЦП) применение математики с плавающей точкой не требуется никогда
рецептов на эту тему уже милиард, только сиди и читай. Заодно почитай про мультисэмплинг. Поможет избавиться от скачущих цифр
@mail_robot Ну и как же обойтись без плавающей запятой, например, у меня диапозон ацп 0 - 1024, после калибровки рабочий диапозон шкалы 4 - 1022, шкала 20 - 120 °С. Ну вот как?
очень даже запросто. Дискретной арифметике плавающая точка не требуется, еще раз повторю.
Вернулся к работе, но после всех корректировок так ничего и не изменилось)
Может быть я неправильно настраиваю CPOL и CPHA?
Приложил картинку передачи сигналов из ДШ.
По-моему в настройках SPI нужно устанавливать CPOL - 0, CPHA - 1Edge.
Еще кстати заметил, что в настройках выводов SCK и MOSI настраиваются как AF, а MISO как Input. А разве MISO не должен тоже задаваться как AF?
9 часов назад, Гость remixx сказал:
MISO - Input floating / Input pull-up.
CPOL - 0, CPHA - 1 да так правильно.
На HAL все очень сложно и запутанно, какие-то лишние сущности. Там настроек на 4 строчки.
