Жк Pic
Vasily437
Здравствуйте!
Никак не получается работать с ЖК на pic16f676.... На других некоторых пробовал (pic16f628, pic16f877, pic16f874), а на этом нивкакую.... А мне надо бы на нем...
Библиотека hi-tech
Вот коды.
Ну это сама программа
#include <pic16f676.h>
#include "lcd.c"
void
main(void)
   lcd_init();
   lcd_goto(0);    // select first line
   lcd_puts("12345678");
   lcd_goto(0x40); // Select second line
   lcd_puts("Hello world");
   while(1){}
lcd.c:
#ifndef _XTAL_FREQ
// Unless specified elsewhere, 4MHz system frequency is assumed
#define _XTAL_FREQ 4000000
#endif
#include    <htc.h>
#include    "lcd.h"
#define LCD_RS RA0
//#define   LCD_RW RB1
#define LCD_EN RA1
#define LCD_DATA    PORTC
#define LCD_STROBE()    ((LCD_EN = 1),(LCD_EN=0))
/* write a byte to the LCD in 4 bit mode */
void
lcd_write(unsigned char c)
   __delay_us(40);
   LCD_DATA = ( ( c >> 4 ) & 0x0F );
   LCD_STROBE();
   LCD_DATA = ( c & 0x0F );
   LCD_STROBE();
*  Clear and home the LCD
void
lcd_clear(void)
   LCD_RS = 0;
   lcd_write(0x1);
   __delay_ms(2);
/* write a string of chars to the LCD */
void
lcd_puts(const char * s)
   LCD_RS = 1; // write characters
   while(*s)
    lcd_write(*s++);
/* write one character to the LCD */
void
lcd_putch(char c)
   lcd_write( c );
* Go to the specified position
void
lcd_goto(unsigned char pos)
   LCD_RS = 0;
   lcd_write(0x80+pos);
/* initialise the LCD - put into 4 bit mode */
void
lcd_init()
   char init_value;
   ADCON1 = 0x06;  // Disable analog pins on PORTA
CMCON=7;//выключаем компараторы
   init_value = 0x3;
   TRISA=0;
   TRISC=0;
   LCD_RS = 0;
   LCD_EN = 0;
   //LCD_RW = 0;
   __delay_ms(15); // wait 15mSec after power applied,
   LCD_DATA	 = init_value;
   LCD_STROBE();
   __delay_ms(5);
   LCD_STROBE();
   __delay_us(200);
   LCD_STROBE();
   __delay_us(200);
   LCD_DATA = 2;   // Four bit mode
   LCD_STROBE();
   lcd_write(0x28); // Set interface length
   lcd_write(0xF); // Display On, Cursor On, Cursor Blink
   lcd_clear();    // Clear screen
   lcd_write(0x6); // Set entry Mode
lcd.h:
extern void lcd_write(unsigned char);
/* Clear and home the LCD */
extern void lcd_clear(void);
/* write a string of characters to the LCD */
extern void lcd_puts(const char * s);
/* Go to the specified position */
extern void lcd_goto(unsigned char pos);
/* intialize the LCD - call before anything else */
extern void lcd_init(void);
extern void lcd_putch(char);
/*  Set the cursor position */
#define lcd_cursor(x)   lcd_write(((x)&0x7F)|0x80)
Ну из lcd.c видно на каких выводах у меня что подключено.
Вот.
Код один и тот же, что сама программа, что lcd библиотека.
Подключил к одним и тем же выводам. Результат
Попробуйте у себя пожалуйста. Мои коды в первом посте.
Все так... RA0 на RS, а RA1 на E
C0-C3 на последнии выводы ЖК.
И порт С настроил как цифровые выходы?
На форумах принято общаться на "ты", что не является оскорбительным и подразумевает равноправие
Решение -- включить порты как цифровые, отключить компаратор, MCLR на +.
Как программно отключить MCLR? пробовал поразному - не выходило. Надеюсь на вас, а то мне нужен этот вывод.....
Алекс, почему-то при попытке подключить lcd.h выдает ошибку.
+ подскажите пожалуйста как отключить курсор. Он по умолчанию включен, и никак не могу найти его отключения....
MCLRE=0
Ну-ка угадай какую ошибку у него выдает компилятор?!
Пошли дисплею код "1" - очистка и убрать курсор
Ну какую... Наверное не найдены функции. Ибо в проект то он по-любому .c-файл не добавляет.
Не любит народ читать литературу, хотят чтобы всё и сразу...
Алекс, спасибо - помогло. при .h так ошибку не выдает.
Вова, на MCLRE=0 ругается(нет такого индефикатора) и как послать 1 дисплею?
Не могу сделать, чтобы выводились данные когда C0-C3 на выводы данных индикатора, а C4, C5 на RS, E....
Ответ тут: #include <pic16f676.h>
послать 1 дисплею?
У тебя уже есть функция lcd_clear() или она курсор не отключает?:
И не получится:
#define LCD_RS RA0
#define LCD_EN RA1
Вова, в pic16f676.h смотрел и даже оттуда вставлял строку по отключению MCLR -но почему-то не отключается...
lcd_clear() -очистка дисплея
Разумеется я правил на RC4 и RC5, но толку нет.
Алекс, а вы сами эту библиотеку пробовали? Чем она лучше обычной? Те же функции, так же не понятно как отключить курсор, так еще и разбираться в назначении выводов....
Какой "обычной" ? И что значит "лучше" ?
1. Вы хотите отключенный курсор, там он отключается.
2. Вы хотите указывать различные выводы МК для дисплея, там это делается с лёгкостью.
3. Я не то что её пробовал, я - автор этого произведения.
Я не знаю, что у Вас за стандартная библиотека, не разбирался. Я просто предложил Вам альтернативу, исходя из Ваших запросов, т.к. Ваша не удовлетворяет Вашим требованиям, по Вашим же словам.
Чем она Вам не угодила ?
А вообще, в качестве чего собираешься использовать пин MCLR? (как вход,выход?)
вход.
Вот это вставлял.
// RA3/MCLR pin function is digital I/O, MCLR internally tied to VDD
#define MCLRE_OFF 0xFFDF
А что такое "#define" ? И как этим пользоваться?
Как только ответишь сам на эти вопросы, так нога и заработает!
Забыл видимо про это)
Но я все же не понял как объявлять...
#define CONFIG 0x2007
CONFIG MCLRE_OFF;
ошибки, ошибки, ошибки...
P.S: не хотелось бы через __CONFIG, хотя так: __CONFIG MCLRE_OFF; тоже ругается
Для того, чтобы понятно было другим нужно писать через конфиг!
А если так:
__CONFIG (MCLRE_OFF);
