Error: recipe for target 'library.o' failed
A1essandro
Atmel Studio 7.
Здравствуйте. Занимаюсь в свободное время небольшим проектом. Пару дней был перерыв, всё работало. Сегодня делаю ребилд, вот Output:
------ Rebuild All started: Project: RF, Configuration: Debug AVR ------
Build started.
Project "RF.cproj" (Clean target(s)):
Target "Clean" in file "D:\Circuits\AtmelStudio\7.0\Vs\Compiler.targets" from project "D:\Circuits\AvrProjects\RadioNanny\RF\RF.cproj" (entry point):
	Task "RunCompilerTask"
		Shell Utils Path D:\Circuits\AtmelStudio\7.0\shellUtils
		D:\Circuits\AtmelStudio\7.0\shellUtils\make.exe clean
		rm -rf  library.o
		rm -rf  library.d
		rm -rf "libRF.elf" "libRF.a" "libRF.hex" "libRF.lss" "libRF.eep" "libRF.map" "libRF.srec" "libRF.usersignatures"
	Done executing task "RunCompilerTask".
Done building target "Clean" in project "RF.cproj".
Done building project "RF.cproj".
Build succeeded.
Build started.
Project "RF.cproj" (default targets):
Target "PreBuildEvent" skipped, due to false condition; ('$(PreBuildEvent)'!='') was evaluated as (''!='').
Target "CoreBuild" in file "D:\Circuits\AtmelStudio\7.0\Vs\Compiler.targets" from project "D:\Circuits\AvrProjects\RadioNanny\RF\RF.cproj" (target "Build" depends on it):
		D:\Circuits\AtmelStudio\7.0\shellUtils\make.exe all --jobs 2 --output-sync
D:\Circuits\AvrProjects\RadioNanny\RF\Release\Makefile(79,1): error: recipe for target 'library.o' failed
		make: *** [library.o] Error 1
	Done executing task "RunCompilerTask" -- FAILED.
Done building target "CoreBuild" in project "RF.cproj" -- FAILED.
Done building project "RF.cproj" -- FAILED.
Build FAILED.
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
В ошибках:
Severity	Code	Description	Project	File	Line
Error		recipe for target 'library.o' failed	RF	D:\Circuits\AvrProjects\RadioNanny\RF\Release\Makefile	79
Что находится в Makefile строка 78-82:
78: ./%.o: .././%.c
79:	@echo Building file: $<
80:	@echo Invoking: AVR/GNU C Compiler : 5.4.0
81:	$(QUOTE)D:\Circuits\AtmelStudio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe$(QUOTE)  -x c -funsigned-char -funsigned-bitfields -DNDEBUG  -I"D:\Circuits\AtmelStudio\7.0\Packs\atmel\ATtiny_DFP\1.2.118\include"  -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -Wall -mmcu=attiny13 -B "D:\Circuits\AtmelStudio\7.0\Packs\atmel\ATtiny_DFP\1.2.118\gcc\dev\attiny13" -c -std=gnu99 -MD -MP -MF "$(@:%.o=%.d)" -MT"$(@:%.o=%.d)" -MT"$(@:%.o=%.o)"   -o "$@" "$<"
82:	@echo Finished building: $<
Перестало билдиться именно при ребилде. Если откатить изменения, и сделать просто билд - всё работает.
Запускаю студию от администратора, т.е. с правами проблем нет. Да и по логике, если хватает прав удалить при clean файлы, то должно хватать и на создание.
Вообще, мне не совсем понятна фраза recipe for target 'library.o' failed.
Изменено пользователем A1essandro
