Программатор На Arduino
Хочу использовать ардуину как программатор для avr, делал все как тут http://habrahabr.ru/post/144620/.
Не понятен 4 пункт! Как скомпилировать и чем залить прошивку не понял. Может кто разъяснить подробно?
Скомпилировать не вышло, скачал hex файл. Прошить не получилось
avrdude -C avrdude.conf -c arduino -P com1 -b 19200 -p t13 -U flash:r:"C:\Users\p\Desktop\t13pwm\Прошивка.HEX":i -q
avrdude: Can't find programmer id "arduino"
Valid programmers are:
 dasa3    = serial port banging, reset=!dtr sck=rts mosi=txd miso=cts [avrdude.conf:805]
 dasa     = serial port banging, reset=rts sck=dtr mosi=txd miso=cts [avrdude.conf:792]
 siprog   = Lancos SI-Prog <http://www.lancos.com/siprogsch.html> [avrdude.conf:779]
 ponyser  = design ponyprog serial, reset=!txd sck=rts mosi=dtr miso=cts [avrdude.conf:766]
 frank-stk200 = Frank STK200                   [avrdude.conf:731]
 blaster  = Altera ByteBlaster             [avrdude.conf:718]
 ere-isp-avr = ERE ISP-AVR <http://www.ere.co.th/download/sch050713.pdf> [avrdude.conf:708]
 atisp    = AT-ISP V1.1 programming cable for AVR-SDK1 from <http://micro-research.co.th/>  [avrdude.conf:698]
 dapa     = Direct AVR Parallel Access cable [avrdude.conf:687]
 xil      = Xilinx JTAG cable              [avrdude.conf:674]
 futurlec = Futurlec.com programming cable. [avrdude.conf:657]
 abcmini  = ABCmini Board, aka Dick Smith HOTCHIP [avrdude.conf:647]
 picoweb  = Picoweb Programming Cable, http://www.picoweb.net/ [avrdude.conf:637]
 sp12     = Steve Bolt's Programmer        [avrdude.conf:626]
 alf      = Nightshade ALF-PgmAVR, http://nightshade.homeip.net/ [avrdude.conf:610]
 bascom   = Bascom SAMPLE programming cable [avrdude.conf:600]
 dt006    = Dontronics DT006               [avrdude.conf:590]
 pony-stk200 = Pony Prog STK200               [avrdude.conf:578]
 stk200   = STK200                         [avrdude.conf:562]
 bsd      = Brian Dean's Programmer, http://www.bsdhome.com/avrdude/ [avrdude.conf:551]
 pavr     = Jason Kyle's pAVR Serial Programmer [avrdude.conf:543]
 dragon_dw = Atmel AVR Dragon in debugWire mode [avrdude.conf:536]
 dragon_hvsp = Atmel AVR Dragon in HVSP mode  [avrdude.conf:528]
 dragon_pp = Atmel AVR Dragon in PP mode    [avrdude.conf:520]
 dragon_isp = Atmel AVR Dragon in ISP mode   [avrdude.conf:512]
 dragon_jtag = Atmel AVR Dragon in JTAG mode  [avrdude.conf:504]
 jtag2dw  = Atmel JTAG ICE mkII in debugWire mode [avrdude.conf:496]
 jtag2isp = Atmel JTAG ICE mkII in ISP mode [avrdude.conf:488]
 jtag2    = Atmel JTAG ICE mkII            [avrdude.conf:480]
 jtag2fast = Atmel JTAG ICE mkII            [avrdude.conf:472]
 jtag2slow = Atmel JTAG ICE mkII            [avrdude.conf:464]
 jtagmkII = Atmel JTAG ICE mkII            [avrdude.conf:456]
 jtag1slow = Atmel JTAG ICE (mkI)           [avrdude.conf:449]
 jtag1    = Atmel JTAG ICE (mkI)           [avrdude.conf:441]
 jtagmkI  = Atmel JTAG ICE (mkI)           [avrdude.conf:433]
 avr911   = Atmel AppNote AVR911 AVROSP    [avrdude.conf:427]
 avr109   = Atmel AppNote AVR109 Boot Loader [avrdude.conf:421]
 butterfly = Atmel Butterfly Development Board [avrdude.conf:415]
 usbasp   = USBasp, http://www.fischl.de/usbasp/ [avrdude.conf:409]
 diecimila = FT232R Synchronous BitBang     [avrdude.conf:399]
 pinb     = FT232R Synchronous BitBang     [avrdude.conf:388]
 ftbb     = FT232R Synchronous BitBang     [avrdude.conf:377]
 ft245r   = FT245R Synchronous BitBang     [avrdude.conf:366]
 serjtag  = Serial JTAG Cable              [avrdude.conf:361]
 avr910   = Atmel Low Cost Serial Programmer [avrdude.conf:355]
 stk500hvsp = Atmel STK500 V2 in high-voltage serial programming mode [avrdude.conf:349]
 stk500pp = Atmel STK500 V2 in parallel programming mode [avrdude.conf:343]
 stk500v2 = Atmel STK500 Version 2.x firmware [avrdude.conf:337]
 stk500v1 = Atmel STK500 Version 1.x firmware [avrdude.conf:331]
 stk500   = Atmel STK500                   [avrdude.conf:325]
 avrisp2  = Atmel AVR ISP mkII             [avrdude.conf:315]
 avrispmkII = Atmel AVR ISP mkII             [avrdude.conf:309]
 avrispv2 = Atmel AVR ISP V2               [avrdude.conf:303]
 avrisp   = Atmel AVR ISP                  [avrdude.conf:297]
что не так делаю?
Изменено пользователем prsch
  • 1 год спустя...
